Results 1 to 3 of 3
    Veteran Member Three Rings Rons01B5's Avatar
    Oct 17 2005
    Long Island, NY
    Headlights aimed too high after hit a bump
    I was driving in an unfamiliar area last night and I went over railroad crossings a little too fast but I didn't bottom out. Immediately after a saw my headlamps adjusting. Now they are aimed too high! They are shooting up in the trees. No fault codes in the "xenon range" module with vag com, I even did an adaptation to factory settings but no luck.
    Anyone ever experience this?
    Thanks
    2012 A5 2.0T QUATTRO 6-SPEED
    GIAC Stage 1---R8 Coilpacks---H&R Coilovers---S5 Speedline Wheels---H&R 20mm Spacers---Ecode Alu Kruez---H&R Sway Bars---034 Trans Insert---P3 Cars Gauge---JHM Shifter---GFB DV+--S-Line Front Bumper---Black Optics Grille
    2003 Amulet Red Audi A4 1.8TQ 5-Speed - SOLD
    Feb 18 2015
    Milpitas, CA
    There is a rod that is bolted to the drivers side straight control arm that connects to the headlamp leveling sensor. Perhaps the rod came disconnected or broke when you hit the bump. It is easy to see the end that connects to the control arm without jacking up the car or removing the wheel.
    http://www.jimellisaudiparts.com/sho...t control unit
    -Michael
    Oct 17 2005
    Long Island, NY
    Thanks! I'll check that out.
