Results 1 to 11 of 11
    Dec 28 2015
    Sacramento
    Droning noise from front end at 45 and 65mph
    I'm getting this droning noise that gets quite loud at 45mph and around 65mph, it goes away during other speeds. At first I thought it was one of the front wheel bearings, so I replaced both of those and it didn't change anything. I've also swapped the spare tire for the left and then the right separately and didn't find any changes (The front tires are quite worn and they are a cheap brand).
    I'm wondering what other common areas can make this noise? Thanks!
    Senior Member Three Rings diuvic's Avatar
    Feb 15 2012
    Indiana
    It may sound dumb but I had a screw in a tire that I could only hear at high speeds. But if you're tires are really worn, they might be at fault.
    Senior Member Three Rings B6ayfour's Avatar
    Jun 21 2015
    2014 S4 6MT, 1989 535i5
    LI, NY
    also having the right psi/ the same psi in each tire is key. i was driving to work in a car im selling and it sounded very similar to a wheel bearing. turned out the back right tire was low.
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    Axle?
    2019 SQ5 Prestige
    Aug 19 2013
    minnesota
    Quote Originally Posted by kevmor99 View Post
    Cv joint
    APR exhaust, HFC, 225 injectors, APR II program, KO4, South Bend II endurance clutch and SMFW, Forge Tip+piping, Apikol SMIC, Stern motor+trans mounts, Stern Snub, 034 street density arms, Hotchkis sway bars, Lemforter links, Bilstein B8, B7 S4 calipers, powerstop braided lines, Centric drilled rotors, PowerStop Carbon Fiber pads, Timken bearings, Gates racing timing belt, DENSO IQ01-27 plugs, R8 coils, Motul Xcess 5w40, MANN 950/4 filter, gear300, CHF202, Motul RBF 660.
    Dec 28 2015
    Sacramento
    Can a front axle or cv joint make that steady type of noise? I thought they were more rhythmic with the rotation?
    Veteran Member Four Rings Molotov's Avatar
    Feb 24 2007
    2005 USP 1.8TQM Avant
    Burlington, Vermont
    Probably due to your tire wear. How are the rear tires in comparison to the fronts? AWD or FWD? Are all 4 the same brand? Difference in noise when turning left or right at those speeds (on/off ramps to load up either side)?
    - Scott
    Das Build Thread
    Performance parts for sale:
    MagnaFlow Race Muffler - Vibrant 4" Filter - MAF 4" Housing
    Dec 28 2015
    Sacramento
    The previous owner put 4 new Ironman tires on it right before selling, the fronts are almost in need of replacing but the rears have a ways to go. It's a quattro AWD. There doesn't seem to be any difference when turning at all at those speeds.
    It's also really difficult to tell which side (left/right) it's coming from, but it sounds like it's from the front... I can try swapping the front tires with the rears, maybe both front tires are making noise? I don't know, it seems like I would've noticed a change when I swapped out with the spare though.
    Veteran Member Four Rings MacFady's Avatar
    Aug 10 2011
    330i ZHP
    Prince Edward Island
    Just a thought down another route, any chance you have an exhaust leak? Might be worth a look around your flex pipe and between the legs of your "Y", car running obviously. Might also be worth noting if the drone is truly speed dependent or if it is actually RPM dependent instead.
    Dec 28 2015
    Sacramento
    Here's a video I got with the noise, it's a little hard to tell though.
    https://www.youtube.com/watch?v=GgDtS_HII7I
    Senior Member Three Rings GTA's Avatar
    Feb 08 2013
    2003 Audi A4 1.8TQ, 5-Spd
    Toronto, Ontario
    Funny. I'm getting a similar noise as the OP at around the same speeds and it's been driving me bat-shit. It's not the tires (moved them around and also changed to winters) and not the right front wheel bearing (changed out last month with SKF one). Front drive shafts are sound with no tears or excessive play. Front suspension is solid as well.
    I was thinking about replacing the left front bearing but want to confirm it's that before changing out. The noise sounds like it's coming from the front of the car but hard to pin point with any accuracy.
    I ran my car at those speeds on a hoist just yesterday but didn't notice the noise which tells me that it's only apparent when the suspension is loaded. I'm stumped and that noise taunting me to drive it off a cliff. Tabernack!!!
    EDIT 2017, 07-31: It seems that noise was FROM the tires. I needed new rubber anyways and picked up a set of Pirelli P-Zero A/S in stock size and immediately the noise went away. Now I can hear my exhaust leak .
