Results 1 to 4 of 4
    May 24 2008
    cornish,me
    2002 a 4 window not working
    I 'm rebuilding a 2002 1.8 a 4 that the timing belt broke in. The rear window regulators were gone in it and you could push the windows up and down. I have a 2004 parts car so I thought that I would change out the rear doors and the drivers door because of a rust issue now the windows don't work. When I check for codes with VCDS I get no communication with control module any thoughts on the issue would be greatly appreciated thank you.
    Oct 02 2006
    Wadsworth,OH
    There's a split between model years for the main window switch. So if you have individual switches from a newer model they may not communicate properly with the main switch. Which would make sense why you're getting the error.
    Jason
    May 24 2008
    cornish,me
    The car is a 2002 the master switch is from a 2004 the drivers door motor/control module is from a 2004 the rear doors motor /control module is from 2004, and the front passenger door is original. Any way to make the parts work together
    Oct 02 2006
    Wadsworth,OH
    I'd assume you would need to swap everything over to 2002 parts.
    Jason
