Results 1 to 9 of 9
    Aug 13 2012
    Can I use a battery charger to test a motor?
    If all I want to do is test a 12v motor see of its working, is a regular battery charger a suitable source of 12v for that instead of running test wires to the battery or finding another battery? I searched and found no clear answer. Perhaps a battery charger does not actually deliver 12v?
    Mar 21 2015
    What charger are you using. It comes down to amps.
    Jun 08 2008
    Calgary AB Canada
    If it's a smart charger than likely not, as it will not deliver power before analyzing the battery. One of those basic $20 chargers will work fine.
    edit: Google search for "battery charger as power supply". You'll find tons of info on this topic. eg. http://ask.metafilter.com/63454/Batt...V-power-supply
    2011 Audi A4 Avant // quattro // Garnet Red
    Stock. For now...
    1989 Porsche Carrera 4 // 5 Speed // Guards Red
    Aug 13 2012
    Says 10 Amps on it. This is to test an SAI pump motor.
    Aug 13 2012
    I don't think it's smart. It's about 25 years old.
    Jun 08 2008
    Calgary AB Canada
    You're good to go in that case
    Stock. For now...
    Aug 13 2012
    Thanks. I wish every car forum was even half as good as this one.
    Mar 21 2015
    I thought you were talking about trying to crank over an actual motor. Thanks for clarifying.
    Apr 15 2014
    Ottawa/Gatineau Canada
    I carry 9v battery's with me to the werckers to test parts. 9v will work for a short test.
