Results 1 to 9 of 9
    Active Member Two Rings Ramzi's Avatar
    May 28 2015
    Oakville ON
    How Much are these worth?
    Hey guys,
    Sorry I am an A4 owner but I want to know how much these 2010 S5 rims cost. One of the rims is dented but the guy is selling the whole set for $450 CAD. Hoping I could fix it and either use them or sell for more.
    I know this isnt the right place to post but I need to know asap.
    please let me know the price range for these. Thanks!
    Oct 09 2008
    450 cad? that's like 10 freedom bucks. If you want them that's a decent price as long as the 4th is fixable.
    The Awesome™
    May 28 2015
    Oakville ON
    Quote Originally Posted by JoshDub View Post
    Do you know how much they go for? I cant seem to find them anywhere
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    The sell for $567.00 each at the dealership and another $42.00 for the center caps.
    Veteran Member Four Rings SLU_S5's Avatar
    Sep 06 2014
    Rochester, NY
    I've seen them go for anywhere between $500-$1000 for a set of 4 with no tires. Add $200 more if the tires are in decent shape.
    2010 S5 Prestige 6MT: B.Black:
    APR: Intake // AWE: Touring + non-res DPs, S-Flo filter // CR-15: Brace // ECS: LWFW, Diff Mounts, SS Brake Lines // Eurocode: AK, Sways // JHM: Tune, Short Shifter // KW: H.A.S. // OEM+: B8.5 S-Line Competition+ Bumper, BO S5 Grille, Ecodes, RS5 BBK, 20" RS5 Rotors// SBC: Stg 2 Daily // 034 Motorsport: Intake Pipe, Trans & Motor Mounts, ACAs // Others...
    IG: @SLU_S5
    May 20 2010
    I got a set of S5 reps about 3-4 years ago with nearly new tires for $600, so that's not horrible. Plus if it's repairable, should not cost you terribly much. Most repairs by me are about $150 USD, so.. give or take a few.
    Veteran Member Three Rings szaer's Avatar
    Mar 14 2013
    Greater Toronto Area
    Are you in a B7 a4? Centre bore is diff if it's off the b8 S5 I believe
    2014 Lava Grey S5
    May 20 2010
    Quote Originally Posted by szaer View Post
    True, but he can get hubcentric rings to go from 66.6 to 57.1 mm. Not terrible expensive either.
    Mar 14 2013
    yes yes, just wanted to make sure he knew :)
    2014 Lava Grey S5
