Results 1 to 4 of 4
    Dec 05 2015
    Staten Island NY
    No electric to the engine
    Hi ,
    I have a 2005 a4 3.2L Quattro with 105k.
    I pulled into a gas station to fill up and I turned the car off. When I went to start it it did not start.
    All the electrical is working. There seems to be no electric going to the engine. There is no clicking, cranking or turning. Complete silence.
    Any Ideas?
    Veteran Member Four Rings Biged243's Avatar
    Mar 27 2013
    Vr6 gti
    Metro Detroit Michigan
    Probably starter
    What ever makes sense go with the opposite and you got it
    Feb 24 2004
    Minneapolis
    That would be my guess. Would be nice to do a test and see if you get 12 volts at the starter.
    11 A4 Q, Prestige, Black
    207,000 miles, APR Stage 1
    Active Member Two Rings Sodium's Avatar
    Dec 25 2015
    '06 A4 Avant Quattro 3.2 FSI, '95 Jaguar XJS convertible, '95 Diesel Dodge (Train Driver)
    Austin, TX
    What did this turn out to be?
    My first guess would be the starter and then possibly the key switch.
    Maybe try wiggling the key when trying to start it. That can engage a worn contact.
    Also, the neutral safety switch may be slightly out of alignment. On an automatic try starting in Neutral instead of park. On a manual fiddle with the clutch pedal and brake and be sure the shifter is not in gear.
    Getting out further to the edge cases it's possible there's a faulty power relay but I would expect it to crank.
