Results 1 to 20 of 20
    Veteran Member Four Rings Acejam's Avatar
    Dec 22 2009
    MA
    Factory tire wear marks
    Hey all,
    I swapped over to my winter setup today, as it appears we finally might get some snow later on this week. When I had my summer tires/wheels off, I noticed some odd wear marks/bars on my tires within the middle of the tread. The tires in question are the factory 255/35/19 Continental ContiSportContact 3's.
    I always run proper tire pressures (39/33) and as best I know, the factory alignment on my 2014 should be OK.
    Has anyone ever seen lines like these before? These tires do have the typical tire wear bars as well, but these seem different. In addition, more than one tire has these lines.
    2014 Brilliant Black S4
    DSG / Prestige / Black Optics / Sport Diff / B&O / Carbon Atlas Inlays / Magma Leather
    Modifications: APR Stage 2 Dual Pulley + TCU, JHM 187mm Crank Pulley, APR Open Intake, APR CPS, AWE Touring Exhaust (90mm Silver), KW HAS, 034 Rear Sway, 034 Mount Inserts, Hawk HPS 5.0, S5 Rotors w/ PS4S (Summer), Peelers w/ LM-32's (Winter)
    Deactivated Three Rings
    Aug 24 2015
    How many miles you got on them? They look pretty worn.
    Sent from my iPad using Tap,Tap,Tapatalk
    Dec 22 2009
    MA
    Quote Originally Posted by jimblkmazda View Post
    The car has just under 23k miles, bought brand new in October of 2013. However I also run dedicated winter tires/wheels for a few months of each year. I'd say the Conti's have about ~12-15k on them.
    Aug 24 2015
    Yea, they're done bro. The stock ****is are garbage.
    Apr 19 2014
    Long Island
    Def agree those are at the end of their life
    Dec 22 2009
    MA
    Quote Originally Posted by homelessNY_LI View Post
    I agree. However, I'm more curious about what these odd lines are.
    Established Member Two Rings r32breeze's Avatar
    Sep 18 2010
    2011 Audi S4
    Seattle,WA
    Those marks are the wear marks. If threads reach there it means they are done. My stock pirellis are done around 20K miles with couple track use..
    Dec 22 2009
    MA
    Quote Originally Posted by r32breeze View Post
    I see wear bars - those are obvious. I'm talking about the small lines which are not perfectly straight that run parallel with the tire tread.
    Veteran Member Four Rings blackfunk's Avatar
    Jul 12 2012
    Looks like your tires were over inflated, not saying they were but it looks that way. I say that because there still appears to be some meat left on the outsides of the tires.
    Life has taught me never try to make something idiot proof, they'll simply come up with a better idiot.
    I'd agree with you but then we'd both be wrong.
    I have neither the time, nor the crayons to explain this to you properly.
    Senior Member Two Rings Sudz's Avatar
    Apr 19 2014
    Beer Fridge
    Houston, Texas
    Those center tire marks are different then I have seen. Soft areas wear away and leave the strong areas, but this is new to me.
    It's more like the tire is rubbing on something all the time, or Continental is doing some weird shit / innovative stuff with their tire tread.
    2004 A4 Avant USP 6mt, Motoza Tuned
    2015 BMW M4, 6mt, Mineral White Metallic, BPMSport Tuned
    2016 Z06/Z07 Vette
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    They are sipes. They are built into the construction of the tire, Most tires will not have them visible with that little tread left. In fact , most tires wont have them at all.
    Veteran Member Four Rings Brother Owl's Avatar
    Mar 24 2015
    Denver
    Quote Originally Posted by blackfunk View Post
    +1. Those lines are weird but this is far more important
    B8.5 S4 Estoril Blue Crystal 6MT : IE DP 3.2PR
    Denver to Vegas in 9:26
    Active Member Two Rings simulacrum's Avatar
    May 21 2010
    Phila PA
    same here...failed PA state inspection to my surprise, with 16k on the car, including about 5k of times on Blizzaks. And I haven't even been driving very aggressively, not track days, kids in the back seat kind of driving. Conti's or alignment (which doesn't make sense as i had even wear) or something else is seriously amiss.
    2011 S4 - 7 Cogs - Meteor - Black/Magma - SDiff - Nav (unless it's hot out) - Bangin' Olufsen
    Aug 24 2015
    I have no idea how Audi gets away with putting Cüntis on these cars. I wonder what the 335's get...
    Established Member Two Rings paulo6's Avatar
    Apr 17 2014
    Ford Explorer, Honda Element. retired a Cobb Tuned E60 535xi for the S4
    Ann Arbor, MI
    Horrendous ! Mine lasted 14k and should have been replaced 2k earlier!! Audi should have never sourced them as OEM for this car
    Paul. S4 Prem+, Grey, Optic Black, Sport Diff, Nav+, BO
    Veteran Member Three Rings Reckon's Avatar
    Jul 16 2015
    St. Petersburg, FL
    Those are weird lines...I don't recall seeing that on my stock conti's before they were trashed. Could be something to do with the sipe lines but who knows.
    2014 Estoril Blue Audi SQ5 Prestige
    2017 Ebony Black Jaguar F-Pace Prestige
    Oct 11 2012
    San Martin CA
    I have a 2014 S4 and the OEM conti's looked just like that at 11k miles of spirited commuting. I always wondered what those lines were. My tires had over inflation wear running 36/33psi front/rear, driving 95% alone, empty trunk.
    I had something very similar on a set of Pirelli P Zeros on my R32 several years ago. I was completely baffled by it so posted a thread on VWVortex and got an explanation from someone in the tire industry. Can't remember exactly what it was but I'll see if I can find it. This was after only about 5k miles. Loved the tires up to that point but when I remounted them the next spring they needed to be rebalanced every few hundred miles which was getting annoying and expensive. Threw them in the trash at 7k.
    [IMG][/IMG]
    Found the post after a bit of searching. This was well over 5 years ago. Here's the explanation I got which I found believable. I have no idea if the pattern had any relation to the balancing issues or not. May have just been a crap set of tires. I was surprised after that to see the same tires become OE on so many new cars.
    OK......I will start by admitting I design tires for a living for Goodyear. The blistering is not blistering. It is a different rubber compound that has carbon black in it to conduct electricity to ground the car and keep you from getting shocked from static electricity build up when you get out of your car. The main tread compound likely uses silica for the filler / reinforcement. Silica = Great wet traction....usually faster wear. You can see something similar on many tires, but this is the most noticeable I have ever seen. The wear on the outer edge looks to be more of a fast center line wear issue. The groove you are measuring in for the outer shoulder is actually close to the center of the tire. Very round footprints could do this. Could be high inflation pressures, or just the design of the tire and the footprint that is has.
    Dec 22 2009
    MA
    Quote Originally Posted by Ruprecht View Post
    Wow, great information!
