Greetings B5ers. I haven't been active in a long time but I thought I'd pose a question for y'all.
Issue: Mysterious coolant leak
Symptoms: Low coolant, heater not working
Tests performed
Compression test: 170, 170, 170, 175
Visual: no external leaks, pass floormat dry
Coolant: Dark colored, smells like rust. No oil in the coolant.
Oil: Normal
I ruled out a bad headgasket. Does coolant always circulate through the heater core even when the heater is off? I haven't used it in over a year until a few days ago and discovered that it wasn't blowing warm air. Is it possible for coolant to leak inside the K03? Any thoughts on where the coolant went?
Thank you for your input!
