Results 1 to 27 of 27
    Senior Member Two Rings Gotpsi2008's Avatar
    Mar 24 2015
    YFZ 450, Beer Fridge
    Sebago, Maine
    Fuel cut/miss fire?
    Hey all, so a few weeks ago I was driving home and came up to a passing lane, dropped to 4th and gave her full throttle. When I got on it as soon as I hit boost, the car jerked then continued pulling normal, fast forward two weeks, everything had been running fine since that day, just did the motor mounts, timing belt, Trans mount, and intercooler hoses (man did that suck), and everything went great til I was on my way home from the shop and the same thing, once in 3rd, once in 4th, jerked under high boost, mid rpm. I was thinking it felt like a quick misfire, but it didn't throw any cel, anyone have any suggestions? I'm probably going to order new packs and plugs regardless but figure id post this so if there is something else I'm missing here. Thanks!
    2008 A4 S-Line Grille 2.0T 6MT Quattro | JHM Stage 2 93 | Autotech HPFP Internals | JHM 3" TP | OBX 2.5" DP | JHM LWFW | RS4 Clutch Pressure Plate Combo | 034 Motor Mounts | 034 Snub | 034 Density Trans Mount | Red Top Coils | AFE Pro Dry S | CTS Silicon Turbo Hoses | ECS Intake Boot | P3Cars Boost Gauge | BSH PCV Revamp | EBC Reds | Ziza
    Mar 24 2015
    Sebago, Maine
    **update** took her out for a solid test run, during a full
    Throttle pull from 1 up to 3, it gets a little backfire around 5500k in first, and backfired a few time during the second gear pull, the violent jerk seems to be more from a 2500k pull in 2nd or higher gears
    Dec 27 2014
    Statesville
    I was noticing something similar. The only thing I could find was folks saying it was the high pressure fuel pump. I didn't believe that it could be that for me.
    Fast forward a while... My timing belt broke because a mechanic left a torx screw behind the timing cover and it eventually found its way between the belt and the crank pulley.
    So I end up having to pull the head. Among other things, I found that the cam follower was worn and the tips of the cam lobes were wearing away significantly. Apparently enough to cut down on peak fuel pressure and make the car miss.
    That's the first place I'd look. Unless, of course, you've replaced it recently.
    Sent from my SM-N910V using Tapatalk
    '08 Audi A4 2.0T M6 Quattro - APR Stage I, H&R Sport Springs, Bilstein Shocks
    '05 Pontiac GTO M6 - Bone Stock
    '67 Pontiac Firebird 400 - Roller Cam, Rockers, Offy Intake, MSD
    Mar 24 2015
    Sebago, Maine
    https://youtu.be/88EYoOJoVi8
    Small clip of what it's doing
    Mar 24 2015
    Sebago, Maine
    Quote Originally Posted by cpaugh View Post
    I did my follower at 85k, I'm at 98ishk now, and it seems that after I shut the car off and turned it back on, I did a pull, no problems, then the second pull it started again
    Jun 17 2013
    jersey city nj
    maybe a weak or failing in tank lpfp. Im just guessing at it thou. Mite want to get someone with a vag-com to runs some data logs and check fault codes
    Dec 27 2014
    Statesville
    We're you able to inspect the lobes on the cam when you replaced the follower? If they were wearing, they could tear up a new follower. If not, then I'd say you dodged that bullet.
    What is the status of your diverter valve?
    Maybe some other guys with more experience with these engines will chime in soon.
    Dec 27 2014
    Statesville
    FYI... I really noticed the lobe tips worn when I saw the new cam. It became very clear then. Might be hard to see down the follower hole.
    Mar 24 2015
    Sebago, Maine
    The follower I took out wasn't in that bad of shape but I can check it out tomorrow at work and check this one, and as far as the diverter valve, it's completely stock
    Dec 27 2014
    Statesville
    New cam:
    Old cam:
    Dec 27 2014
    Statesville
    My follower was replaced at 95k. I started cutting out under high load around 120k.
    Mar 24 2015
    Sebago, Maine
    How do you post pics again?
    Mar 24 2015
    Sebago, Maine
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    - - - Updated - - -
    Am I drunk or does that lobe look cracked??????
    Dec 27 2014
    Statesville
    Seems less than optimal... Looks pitted. The follower is definitely better than mine.
    Dec 27 2014
    Statesville
    May wait for some other opinions. I don't want to get you spun out.
    Mar 24 2015
    Sebago, Maine
    Already looking at cam prices haha, fml, I just did the timing belt yesterday too, but I guess if I do end up having a shit cam then I get to carbon clean the head and do the timing chain....but I am definitely going to pull the hpfp again tomorrow and inspect the cam a little better, it could have been the way the camera took the pic to make the lobe look cracked, I've never heard of a cracked lobe b4
    Mar 12 2015
    Northern Virginia
    Coil ? that's what was happening to me turned out to be an ignition coil
    Mar 24 2015
    Sebago, Maine
    Quote Originally Posted by Zanny9060 View Post
    Were you getting any cel?
    Mar 24 2015
    Sebago, Maine
    Thinking about it, this problem was pretty much non existent until I did the timing belt, mounts, turbo hoses, during which process the top of the engine got filthy and during the coolant bleeding process, got covered in some coolant, so I sprayed the top down with engine cleaner and rinsed it off, maybe this could have messed with the coil packs? It seems this only happens at 3/4-full throttle, I can ease into 1/2 throttle, hitting mild boost and hold it at that and it goes great, but as soon as I throttle into her a bit more the fuel cuts or misfire picks up
    Veteran Member Four Rings BenMTL's Avatar
    Dec 19 2012
    Europe
    Your cam looks fine to me but your follower has uneven wear....Not usually a good sign.
    Wear should be even, can mean the end of your HPFP is damaged?
    Race: 2006 A4 2.0 T / Quattro + 6 Speed / JHM Stage 2 93 w/HPFP / Custom 3" Turbo back exhaust / AWE Boost Gauge / JHM Short Shifter + Intercooler / White CF Trim / S4 Door Blades / DTM Conversion / RS4 RSB / HFC
    Daily: 2012 Audi A7 3.0 TDI / Twin Turbo / True Sline / Quattro + 8 Speed ZF / HUD + ACC + Sunroof / APR Stage 1 / Eurocode Alu Kreuz + Mounts / 034 RSB
    Mar 24 2015
    Sebago, Maine
    Quote Originally Posted by BenMTL View Post
    I'm going to post pics in good lighting of everything today so y'all can take a peak, thanks for all the input so far everyone
    Mar 24 2015
    Sebago, Maine
    Veteran Member Three Rings swaggerwagon's Avatar
    Sep 28 2012
    NC
    When was the last time you replaced your plugs? I was having misfires that weren't triggering a CEL (flashing or constant) so I ended up replacing my plugs. I couldn't remember the last time I did so I put in 4 new BKR7E and no misfire. $10 fix.
    B8.5 3.0T/ B5.5 1.8T
    Veteran Member Four Rings klrider44's Avatar
    Aug 20 2014
    Doylestown PA
    Quote Originally Posted by swaggerwagon View Post
    ^^^^^^ had the same issue. I don't know if the plugs were ever changed on my car. I put 4 new ones in and the fuel cut like feeling was gone.
    Veteran Member Three Rings Luis_Heineken's Avatar
    May 28 2012
    Bayamon, Puerto Rico (USA)
    Having the same problem. P0192 is the code, replacing both pressure sensors this week end
    Mar 24 2015
    Sebago, Maine
    Haha well now I feel like a dumb ass...so I pulled my cool packs today, 1&2 were soaked, like a half inch of water in each hole, 3&4 both dry, the coil seals are dry rotted so when I rinsed the coolant off the top of the block, some water must have run down in, I dryer everything, applied dielectric grease, and runs fine now!
    Dec 27 2014
    Statesville
    Quote Originally Posted by Gotpsi2008 View Post
    Glad you got some more input before diving into that cam replacement.
