Results 1 to 10 of 10
    Aug 19 2013
    minnesota
    Brakes barely working
    My brakes are acting like the booster is at 50% or there is a vacuum leak. Pads have life in them and rotors too. So everything looks fine but it isn't fine. I have to press the brake pedal pretty hard to stop. The pedal is not firm like a bad booster or a vacuum leak. It's somewhere in between. No fluid leaks, any ideas? It's been this way for about three months and today the abs circle within in parentheses came on.
    APR exhaust, HFC, 225 injectors, APR II program, KO4, South Bend II endurance clutch and SMFW, Forge Tip+piping, Apikol SMIC, Stern motor+trans mounts, Stern Snub, 034 street density arms, Hotchkis sway bars, Lemforter links, Bilstein B8, B7 S4 calipers, powerstop braided lines, Centric drilled rotors, PowerStop Carbon Fiber pads, Timken bearings, Gates racing timing belt, DENSO IQ01-27 plugs, R8 coils, Motul Xcess 5w40, MANN 950/4 filter, gear300, CHF202, Motul RBF 660.
    Aug 19 2013
    minnesota
    I wonder if my calipers are just worn out or if I stopped too hard and glazed my pads?
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Sure sounds like a loss of vacuum to the brake booster. with the engine at idle try wiggling all the hoses from the brake booster back to the intake manifold and listen for any hissing indicating a leak.
    Nov 11 2010
    Rochester, MN
    If the things old guy recommended don't turn out to be the cause, have you replaced the fluid any the last couple of years? Maybe you have air in the system and need to bleed them?
    19" B8 S5 Peelers
    Aug 19 2013
    minnesota
    Thanks for the responses. I have done a bit of a shakedown of the vacuum line which connects to another thing a majig. I don't hear any hissing or suction. I have replaced the fluid with brand new Audi dot4 last summer, I did a complete bleed. Manually pumping the brake pedal for each caliper, starting with rear right, front left, rear left, front right. This literally began one day, and since then hasn't gotten better.
    Aug 19 2013
    minnesota
    How does the brake booster connect to the manifold? I've looked and it looks like there's a miniature suction jet pump in there before it connects to the manifold? With a check valve on it? Would something further down that path cause this problem?
    Senior Member Two Rings Captain_Panic's Avatar
    May 01 2015
    B6 A4T, VS800, C6 A6, Conversion Van
    Dublin, Ohio
    Have you tried pushing the calipers back in? Sometimes if they are seized, you can get lucky and free them up like this.
    Aug 19 2013
    minnesota
    I haven't. Calipers are so cheap I'll just replace them soon.
    Veteran Member Three Rings chad99's Avatar
    Apr 22 2012
    Fremont, CA
    If you hit the brakes hard and come to a near complete stop does the engine bog down slightly and sound like its struggling to stay running? That was the symptom I had when my SJP failed internally, plus I also had the weak brakes
    Aug 19 2013
    minnesota
    Quote Originally Posted by chad99 View Post
    That hasn't been symptoms thus far. I might get some time tomorrow to investigate. We're getting a foot of snow, I might get a snow day.
