Results 1 to 13 of 13
    Veteran Member Four Rings GRUMPY-S4's Avatar
    Nov 16 2015
    DFW
    P3 Gauge with Boost Sensor
    Anyone running a boost tap instead of reading boost from ODB2 on their P3?
    Is this the part (sensor) that is needed? I had it from my previous car and wonder if its the same for our version of the P3.
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Yes, that is the part that you need.
    You will also need to grab a signal from the supercharger. Eurocode has a handy dandy boost tap just for this
    http://www.ecodetuning.com/store/aud...boost-tap.html
    Senior Member Three Rings madman4you's Avatar
    Oct 13 2009
    07 GSX-R 750
    Ontario
    Yes. That's it! As mentioned above, make sure you get a boost tap for the elbow in the engine bay. I would recommend getting a couple O rings also and replacing them when you install the boost tap.
    Nov 16 2015
    DFW
    So from the boost tap I run a hose to the sensor that in turn is connected to the P3?
    Veteran Member Four Rings infinkc's Avatar
    Feb 14 2004
    S Ã C, CÃ*
    Quote Originally Posted by GRUMPY-S4 View Post
    yup, there is a connector on the p3 harness that you plug that sensor into. you then need to go into the settings, change it for an analog sensor and do an initial calibration of the sensor.
    There are 10 kinds of people in this world, those who know binary and those who don't.
    Nov 16 2015
    DFW
    Did you guys find any hole in firewall to run the boost line into the cabin?
    Jul 16 2015
    Scarborough, Me. NorthEast.
    I drilled a hole through the double sided grommet where the clutch peddle would be..
    BILL
    2012 S4 DSG, Phantom Black............................................. ...........................
    mods; StaSiS WC Sport Exhaust, gmg downpipes, StaSiS Challenge Suspension Kit, gmg WC Swaybar KIT front and rear, Adjustable front control arms, StaSiS 390-32mm mono6 BBK
    Revo Supercharger pulley, APR Coolant Performance System, Roc Euro intake, Revo Stage 1+, FORGELINE SC1 19x9 wrapped in Michelin PSS 255/35/19's
    1/[email protected]/[email protected]
    More to come, work in progress.
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Run it through the ECU box, you can place a hard line right under the rubber grommet for the engine wiring harness.
    Mar 21 2015
    There are directions on the sites that sell the taps
    Oct 13 2009
    07 GSX-R 750
    Ontario
    Quote Originally Posted by 500HPS5 View Post
    Do this method, you don't need to drill a hole in firewall. Just replace the supplied line with one that can stand heat, and zip tie to prevent it from dangling.
    2012 S4 - Phantom Black w/ a bunch of good stuff done to it
    Best 1/4 =[email protected] Until next year...
    Veteran Member Three Rings JayCar's Avatar
    Dec 13 2015
    2023 Tesla Model Y Performance, 2022 MINI Cooper S Countryman, Specialized Tarmac SL4 Sport :-)
    Houston, TX
    Other than faster response, why not just use the OBD port?
    2014 SQ5/Monsoon Gray
    Go: APR Stage 2+ w/ SC pulley, Airbox mod w/ aFe hi-flow filter
    Ride: H&R Street Performance Coils, RS6 reps in Gunmetal 21x9.5 w/ Michelin PSS 285/35/21
    Look: P3 vent gauge, HID fogs, E-code heads and tails, Many VCDS mods
    Rebuild Thread
    Mar 21 2015
    Quote Originally Posted by JayCar View Post
    Obd is requested boost not actual.
    Dec 13 2015
    Houston, TX
    No kidding... Guess I need to redo mine then. Especially with pulley and stage 2 tune. I was under the impression it was actual boost. Thanks for the info!
    Rebuild Thread
