Results 1 to 10 of 10
    Apr 02 2013
    above top secret
    Changing the half moon top cover gasket without cam tensioner tool
    Hello Guys,
    Just wondering whether it is possible to lift the intake, exhaust cam and cam tensioner simultaneously without using the can tensioner tool?
    Feb 05 2014
    BROOKLYN
    If you are just changing the gasket, you can do it with out the too. All you have to do is remove the 3 t30 screws that are directly on top of the chain tensioner, then loosen the 4th screw that's associated with the tensioner. A) pry tensioner upwith screw driver. B)remove old gasket set kit. C) spray some brake parts cleaner, wait a few seconds, put in new gasket kit, replace screws, 're-tighten torque spec and Done!
    Apr 02 2013
    above top secret
    Thanks Weslife. In doing so do you need to also remove the cam caps? I can't imagine lifting the tensioner alone without the cams but i might be wrong.
    Feb 05 2014
    BROOKLYN
    Quote Originally Posted by maxiz1 View Post
    Touch nothing more than what I explained in my first post. Just pry the tensioner up and slide the gasket out. Oh....and don't forget Toto remove the valve cover gasket. You will be fine. Just take your time. I'm sure you will be completely done within 30 min!
    Veteran Member Three Rings Wrath And Tears's Avatar
    Apr 03 2014
    17 GTI Sport
    Yeah the easiest way is with the tool, but sometimes its a bitch with the tool and you have to do it how Weslife described.
    2017 MK7 CSGM GTI Sport DSG
    PP (Golf R Brakes, +10HP, VAQ LSD), LP, Kessey
    LW 17" Sparco Assetto Garra's, 034 Res-X resonator Delete
    Veteran Member Four Rings nynoah's Avatar
    Jan 16 2006
    01.5 A4 avant Past cars: 95 S6, 85 Golf II VR6, 2 sciroccos, 92 Corrado VR6, 86 Euro BMW 535 Alpina
    LA CA
    Do yourself a favor, just buy the tool its cheap. Keep it for another day. Trying to change that without the tool will drive you insane. Its a pain even with the tool. Without the tool, I would say its virtually impossible for garage mechanic to get the half moon seal traded out too.
    http://www.amazon.com/AUDI-Chain-Ten.../dp/B007C8G4FS
    2001.5 black on black avant 5spd, EFR 6758, Pag Parts band manifold, Vibrant GESI High flow CAT, 2.0L 06A, IE intake manifold, built AEB head, 1000cc Boosted Euro Tune, bosch 044, Ringer Racing stage 3 hybrid Organic/Cerametalic 240mm clutch, S4 interior upgrade, full S4 brakes front and rear with lines, 17in OZ Racing Ultraleggera, 034 HD suspension arms, Stern soft mounts, mirimoto bixenon etc. http://www.audizine.com/forum/showth...s-Build-thread
    Apr 02 2013
    above top secret
    Thank you all for your thoughts and support!!
    Veteran Member Three Rings b5a4erik's Avatar
    Apr 22 2014
    Aptos, CA
    Yo, so I was using the CCT tool, on a car with like 210k, and there are two prong like things that you connect the tool to.
    I broke 1 of teh 2 prongs.
    Be careful in the man.
    Senior Member Three Rings Quattro420's Avatar
    Apr 08 2015
    2003 Jetta tdi 5peed 2000 b5 a4 1.8t 5aq, 2005 Passat tdi wagon2.0l, 2000 sierra 5.3l
    Ontario Canada
    I've done 30 plus with the tool never had a problem and never touched the cams just compress it and use a wrench under the tensioner and pull the gasket and half moon super easy
    Jan 16 2006
    LA CA
    The reason the ears broke off is that people over tighten the tool. Its a very easy mistake to make. I have broken 2 of these tools over the last decade and a half of working on the 1.8T.
