Results 1 to 23 of 23
    Apr 15 2014
    Ottawa/Gatineau Canada
    my fuel pump just gave up the ghost on way home from xmas vacation.
    Fuel pump died on the highway.
    The pump started to make noises when we left my grandmas to come home (5h drive) and gave out about 150 KM later.
    No CEL, but vag com had a fault under the engine for fuel trim lean or something like that. I can get it to start, but it sputters out even when gas pedal held down.
    SOOOOO...
    I got towed to my Father in laws and will open it up tomorrow. No parts stores open until Monday.
    I have found the DIY on A4 MODS and I am wondering if if anyone has any other links to fuel pump DIYs or any other things I need to look out for while I am in there.
    Basically if anyone has any input on this fuel pump swap, please share as I have all day tomorrow to prepare for the job.
    2004 A4 Avant Quattro. (H&R springs, S100 Nav unit, Neuspeed Cat back, Torque solutions Snub mount, Thor Skid Plate, APR Stage 1, 18" S4 Rims, 2X Podi / Oil Press / Oil Temp / Boost/VAC, Full LED interior, Backup Camera/Screen, Upgraded 2.0 Coil Packs, Vag-Com, B7 Center console/B7 Hand Brake, B7 Aero wiper arms B7 rear headreasts,APR Carbonio intake, Fan washer sprayers,
    2014 VW Tiguan. (bone stock)
    Feb 17 2004
    Liberty Hill, TX
    the DIY on A4mods is all you need, it's pretty easy as long as you don't have a > 1/2 full tank
    2012 TT-RS | Sepang/Ebony
    Sold: 2007 RS4 | Sprint/Ebony
    Veteran Member Three Rings Lornnn's Avatar
    May 01 2011
    Pe
    Sorry to hear that man... what a pain. I recently changed mine out with the help of that A4Mods DIY and its all pretty straightforward.
    Cleanliness is probably most important here. The locking ring on mine was caked with all kinds of shit so you'll probably want to spend a good amount of time making sure any surfaces near the opening are as clean as you can get them. Quite a bit of debris was knocked loose while using the tools I had. The last thing you want is to go through all of this and possibly burn out a brand new pump because some trash got knocked in there. As the DIY states you should have your tank as close to empty as possible so you can also clean the cage out with paper towels or a rag.
    One thing that I had trouble with was getting the old pump to unlock from the plastic cage. The DIY says "It only takes a little effort to move the fuel pump" but I really had to work the thing out with the hammer+flathead technique (I didn't have the VAG tool) because the pump wouldn't budge without causing the entire cage to rattle to the point where I thought I might damage something. It eventually came loose, though... hopefully its easier for you. Locking the new one in shouldn't be much of an issue at all.
    Overall its a very easy job while following the DIY. Might also be a good idea to change out your fuel filter as well.
    Good luck, no sweat.
    Veteran Member Three Rings Let it snow's Avatar
    Aug 24 2014
    02 1.8TQ Sport 5 speed, 05 1.8TQ 6 speed
    Vermont
    I made a cheap tool to remove the pump from the basket. If you can find 1/2" O.D. copper pipe or something similar. Two 1 foot pieces or longer for better torque. Hammer the ends down about 1". Bend flat part about a 45 degree angle. When you get to the pump removal from the basket sit flat parts in notches on opposite sides and twist. I made it because i did not like the hammer method. Good luck.
    Veteran Member Four Rings A4OrlandoB6's Avatar
    Aug 03 2008
    Philadelphia, PA
    awesome ^ are the two pieces fused/welded together or does it just look like that?
    -Kyle
    2005 Audi A4 Avant USP / 1.8T / Brilliant Red
    2004 Audi A4 1.8T - big turbo and some stuff - gone
    2003 Audi A4 1.8TQM - gone
    Aug 24 2014
    Vermont
    Quote Originally Posted by A4OrlandoB6 View Post
    Nope not welded or secured at the middle. A good idea though. When i twisted the torque kept them together. Some tape wrapped around the crossing section would be an easy cheap way to go. I just grabbed some scrap pipe hoping it would be one time use. Good luck Luxus.
    Apr 15 2014
    thanks all.
    Super pain in the ass.
    I can not order parts today (Sunday) so I will get everything clean and apart today. I will also empty my gas tank as I am JUST over 1/2 full.
    I will keep everyone posted. Yes, I got my 1st b6 on a flatbed pic...will post as soon as I get it off my wife's phone.
    Now, as to brands I see this VDO unit. Is VDO OEM??
    http://www.autopartsway.ca/partdetai.../pagenum1/tabs
    Apr 15 2014
    while I wait.
    Where is my fuel pump relay and is there a reliable way to test it?
    Jan 06 2009
    If I had to guess I would guess Bosch for the OEM pump but looking at all the parts websites VDO seems correct.
    Dead fuel pump really sucks though...happened to me several years ago. This would be a great time to replace your fuel filter as well. You can pick up a MANN filter from AutoPartsWay.
    B6 2.7t BEL tuned by Bische
    B7 2.0t
    Aug 24 2014
    Vermont
    Quote Originally Posted by Luxus Panzer View Post
    while I wait.
    Remove electrical connector from fuel pump. Terminal 1 and 4 is pump supply voltage. turn key but don not start you should have battery voltage for a few seconds. Try to start the car you should have constant battery voltage. If you have both relay should be okay.
    Apr 15 2014
    Quote Originally Posted by ADCS View Post
    Fuel filter was the first thing I did when I bought the car :)
    Apr 15 2014
    Quote Originally Posted by Let it snow View Post
    Thanks man!
    I am away from home and my Bently....where exactly is the fuel pump relay is case I have to diagnose it ?
    And here it is....my first B6 on a flatbead pic :(
    Feb 17 2004
    Liberty Hill, TX
    yes
    Apr 15 2014
    well pump is out while I await a new one.
    The pump did not prime with key and would spit a bit of fuel out when key held to start (had a clear pipe to a gas can hooked up to the pump)
    How many PSI are supposed to be coming out of the fuel pump?? I do not think I had more than 20-30 PSI when I got the pump running (guesstimate)
    Veteran Member Three Rings john_gonzo's Avatar
    Feb 03 2009
    Florida
    A failing fuel pump can produce fragments, etc. that end up in the filter. Not a bad idea to put a new one on after you get the new pump installed.
    Also, 4B0886373 01C is the part number for the rear seat retainer. This clip can break during seat removal when gaining access to the fuel pump. Same part number should be available at VW dealer. Info from this thread: Part-Number-Rear-Seat-Hold-Down-Retainer.
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    The fuel filter regulates the fuel pressure to 4-bar (58 psi).
    Apr 15 2014
    So what PSI does the pump produce before the fuel filter ?
    Dec 28 2006
    Western Maryland
    Good question! All I can say for sure is that it is more than 4-bar. I'll check the Bentley and see if it lists anything for the pump itself.
    Apr 15 2014
    Wish I could but I am stranded away from home and away from my Bentley.
    Apr 15 2014
    Drove to Newmarket today and picked up a pump Pfaff had in stock. Going to return the one I ordered whenever it gets here.
    Put the new pump in...she fires right up :)
    She lives!!!
    Thanks all.
    Feb 03 2009
    Florida
    She lives!!!
    Thanks all.
    Congrats! That's a fine looking beast.
    Nov 11 2010
    Rochester, MN
    Isn't that a fun job in the cold and snow? I had to do the same thing last winter.
    19" B8 S5 Peelers
    Apr 15 2014
    Quote Originally Posted by SlickFix View Post
    Painful
