I am looking at buying a 2001 Allroad.
Black 2.7T Automatic with 93,000miles
Has had brakes replaced with ECS cross drilled rotors and Hawk pads, brake fluid flush, replaced all the control arms, outer tie rods, replaced the timing belt last year, replaced the air suspension with coil overs, both front CV axles were replaced, rear diff fluid has been changed and magnetic plugs installed. Newer tires.
Car looks very well taken care of. Owner has a 3 ring binder will all the service reciepts of everything he has done to it. He also has both keys and the valet key, original window sticker.
Interior look mint, Took it for a test drive and it drives smooth.
Has a pixelated instrument cluster.
Has the 3rd row seat. As well as the seat cover to go with it.
Scanned it for codes.
Address 01: Engine Labels: 078-907-551-AZA.lbl
Part No: 4Z7 907 551 K
Component: 2.7l V6/5VT G 0001
Coding: 06752
Shop #: WSC 02325
10 Faults Found:
17834 - EVAP Purge Valve (N80)
P1426 - 35-10 - Open Circuit - Intermittent
17865 - Exhaust Gas Temp Sensor 2 (G236)
P1457 - 35-10 - Open or Short to Plus - Intermittent
17887 - Brake Boost Vacuum System
P1479 - 35-10 - Mechanical Failure - Intermittent
17869 - Exhaust Gas Temp Regulation for Bank 1
P1461 - 35-10 - Implausible Signal - Intermittent
16805 - Warm Up Catalyst; Bank 1
P0421 - 35-00 - Efficiency Below Threshold
16815 - Warm Up Catalyst; Bank 2
P0431 - 35-10 - Efficiency Below Threshold - Intermittent
17868 - Exhaust Gas Temp Regulation for Bank 2
P1460 - 35-10 - Limit Reached - Intermittent
17521 - Oxygen (Lambda) Sensor; B1 S1
P1113 - 35-10 - Internal Resistance too High - Intermittent
18032 - MIL Request Signal Active (Check TCM for errors too!)
P1624 - 35-10 - - Intermittent
18010 - Power Supply Terminal 30
P1602 - 35-10 - Voltage too Low - Intermittent
Readiness: 0000 0000
Address 02: Auto Trans Labels: 01V-927-156.lbl
Part No: 4Z7 927 156 A
Component: AG5 01V 2.7l5VT USA 1414
Coding: 00002
Shop #: WSC 00000
VCID: 4487149554D0F21E15-5140
1 Fault Found:
17125 - Torque Converter Clutch
P0741 - 35-00 - Stuck OFF / No Power being transferred
I knew about the EGT, & torque converter codes. It seams like there is something going on with the O2 sensors? Is anyone familiar with these codes?
I just want to get an idea what these items will run to fix before I buy the car.
I should be able to pick it up for $3500 is that too much with the items that need to be fixed?
After getting the Torque Converter replaced I plan to Have a tune added to it coding out the EGT, & secondary 02 sensors.
What should it take to get the Torque converter replaced? $1,500-$2,000?
Thanks in advance for your input.
