    Veteran Member Four Rings R490's Avatar
    Mar 04 2014
    2024 Ford Bronco
    Northern Virginia
    Readiness Test Help! Fails.
    So, emissions are due soon and I decided to run a readiness test. I have had two codes in the past for 02 sensors. Those two are 17539 and 17521
    Catalyst- Fail
    EVAP Sys- Fail
    02Sensor- Fail
    Heated 02- Fail
    Can somebody make sense of this? I'm not sure what needs to be fixed or replaced just relying off this.
    2003 Audi S6 Avant
    2005 Audi S4 6MT SOLD, 2001.5 S4 6MT SOLD, 2001.5 S4 Tip SOLD, '00 A6 2.7t Quattro 6mt SOLD, '97 A4 2.8 Quattro 5mt SOLD
    Veteran Member Four Rings vwblackb5's Avatar
    Jun 26 2007
    New Jersey
    Did you recently clear your codes and if so what were they? Your monitors reading "Failed" or "Not Ready" can be caused by an actual problem (which should have stored a code) or due to recently clearing and needs to go through start/stop drive cycle for the monitors to clear.
    16 B8.5: S4 | Premium Plus | Ibis White | PNY | PPS | GH2 | 1BL | Black Nappa | CTS
    99.5 B5: K04-015 / GIAC PC-16 / 315cc Genesis / Custom FMIC / 034 TP / TT Downpipe / Jetex Catback / Forge 007P / ECS AFPR @ 2.7Bar / ABD Tuning Intake / Blinktek Heatshield / Koni FSD / Eibach Pro Kit / SouthBend Stage 2 Endurance OFE HD / 312mm Slotted A8 BBK
    Mar 04 2014
    2024 Ford Bronco
    Northern Virginia
    Quote Originally Posted by vwblackb5 View Post
    17539 and 17521. Now that I think of it, I cleared them a few minutes before I did the readiness test.
    2003 Audi S6 Avant
    Jun 26 2007
    New Jersey
    Quote Originally Posted by R490 View Post
    Quick google shows they are 02 Sensor codes as per RossTech WIKI http://wiki.ross-tech.com/wiki/index...9/P1131/004401
    Do you have a full registered version of VCDS? If so, you can force readiness to see if the bank1 and bank2 codes pop back up. If you don't, you will have to drive "X" amount of time and get the EGT's hot enough for the Cat and 02 monitors to go through their cycle. The Evap one will take a lot longer.
    Mar 04 2014
    2024 Ford Bronco
    Northern Virginia
    Thanks. Bit of a n00b when it comes to that kind of thing, but would you recommend replacing the 02 sensors? My fuel economy has been not-so-great.
    2003 Audi S6 Avant
