Results 1 to 7 of 7
    Active Member One Ring Oldmoney's Avatar
    Apr 29 2014
    00' s4, 05' 5.9 cummins
    Virginia
    B5 s4 ECS Silicon Hose Kit???
    Does anyone have any experience with the ECS silicon hose kit??
    00' S4 stage 2
    Jun 08 2014
    Vancouver, Washington
    Pretty sure ECS themselves dont make one, but from what I see theres SAMCO, and Forge. I've never read anything bad about Samcos, but also never even heard of Forge before. Just dont cheap out on the TBB and you should be good.
    Apr 29 2014
    Virginia
    Thanks for the reply marlin, I have the APR bi-pipe so we are good on TBB. I was looking at the autobahn88 ebay kit that I've seen people use, just not perfect fit but I can trim. Reason I brought up ECS is because I saw they have a kit on their website stamped "ECStuning" for about ~$200.
    00' S4 stage 2
    Aug 06 2008
    Canadia
    Autobahn88 for 8 years, lobster claws need some trimming, eveything else fits fine
    Apr 29 2014
    Virginia
    Sweeetness, that may be the route that I go then. Does the autobahn88 kit come with clamps, if so, are they any good or should I source new clamps from somewhere else?
    00' S4 stage 2
    Aug 06 2008
    Canadia
    No clamps, i re used stock worm clamps, i'd probably leave the stock lobster claws in place if they arent cracked or anything then you dont need to worry about anything except the elbows off the bi pipes, for those i used oem style since i have the cv clamp crimp tool.
    Oct 02 2006
    Wadsworth,OH
    We do have our own kit available. These are made to our specific specs so it's not just some off the shelf kit with our name stamped on them.
    Jason
