Originally Posted by
markreed
I have searched and found a thread or two about this idea. I have not found any real concrete data backing it is an improvement, but would like to know if anyone has done the swap with any reportable results?
Seems like many vendors are offering the RS7 intake along with the RS7 turbo upgrade for the S6.
So does anyone have input to this?
Sent from my SAMSUNG-SM-N910A using Tapatalk
Whether or not this, or any other intake, which improves airflow to the turbo will lead to an increase in power all depends on the specifics of the tune. If the tune is such that the wastegates will open once a certain manifold pressure is reached, then the intake will be of no benefit in terms of peak power. If the extra airflow is used to allow higher boost and a resultant higher manifold pressure, then it will make a difference. In any case, better airflow to the turbo is still beneficial. Firstly, it allows specified pressure to be reached with less mechanical strain on the turbo, and secondly, it will allow your specified pressure to be reached slightly more quickly. The latter may allow you to reach peak power at a slightly lower rpm (hence an advertised power gain at a given rpm, although no difference in peak output)
Of course, this is the theory. How it all plays out in the real world may be different. Maybe some of the tuners can shed some light ????
