Results 1 to 13 of 13
    Veteran Member Four Rings BenMTL's Avatar
    Dec 19 2012
    Europe
    Exclamation Non Bose tweeters?
    Has anybody else noticed that the non bose tweeters are really bad in terms of sound quality?
    Depends on the song but basically, if you turn it up any reasonable amount (60-70% of max) all the tweeters start scratching/buzzing if you know what I mean....I thought it was only 1 that was defective that I could replace with OEM non bose again but after inspecting further I realized ALL 4 tweeters make the same noise on some types on songs. Oddly enough, I find even the non bose lower speakers to be good quality and no buzzing/scratching from them at all during those same songs.
    As a general question, is it possible to replace all 8 speakers in our doors with non OEM? For example, 4 x Alpine lower speakers and 4 x some other name brand tweeters? Not sure what else I can do here, without changing out my headunit or wiring harness
    Race: 2006 A4 2.0 T / Quattro + 6 Speed / JHM Stage 2 93 w/HPFP / Custom 3" Turbo back exhaust / AWE Boost Gauge / JHM Short Shifter + Intercooler / White CF Trim / S4 Door Blades / DTM Conversion / RS4 RSB / HFC
    Daily: 2012 Audi A7 3.0 TDI / Twin Turbo / True Sline / Quattro + 8 Speed ZF / HUD + ACC + Sunroof / APR Stage 1 / Eurocode Alu Kreuz + Mounts / 034 RSB
    Oct 24 2015
    Perth, WA
    Are you playing mp3s? What quality. I found that lower quality mp3s and similar are terrible sounding. Try a full bit cd or dvd and see if they still do it.
    My respray thread
    Feb 24 2004
    Minneapolis
    If it makes you feel any better, my Bose tweeters suck too. No distortion - but no treble either. I miss the factory radio from my B5. Much better highs. Wish I knew of a good replacement for those tiny little tweeters in the door.
    11 A4 Q, Prestige, Black
    207,000 miles, APR Stage 1
    Nov 16 2011
    Sweden
    I use my concert with DCM II playing from spotify or mp3 on sdcard. Never experienced what your talking about.
    The M.Costa DCM II is a great bluetooth, aux, sdcard and mic unit plugged in to the cd changer slott. From what i heard its hard to come by in the us
    Oct 24 2015
    Perth, WA
    Quote Originally Posted by mtroxel View Post
    This Polk system fits perfectly both in the doors and the tweeters.
    http://www.polkaudio.com/db6501/d/1099
    My respray thread
    Feb 24 2004
    Minneapolis
    Nice Okedokey. Does it fit behind the OEM grilles? Have you heard it?
    Active Member Four Rings waiapasi2006's Avatar
    Feb 01 2011
    Suzuki Alstare RIP
    SFL
    I'm non bose. Teamed up with the S100 head unit and sounds amazing. I can't complain. And of course with kotix's skin, you get a really good built in EQ. I wanted to change mine, but so far so good.
    Sent from my SM-N900P using Tapatalk
    Waiapasi2006
    Oct 24 2015
    Perth, WA
    Yes they clip straight in. Take out old tweeters and fitting and just clip them in. With the speakers, I did the cut away the old speaker and install using OE mounting. Yes I have heard them as I have them in my car right now. ;)
    My respray thread
    Feb 24 2004
    Minneapolis
    Okeydokey is yours BOSE? Did you notice a big difference when you went to these?
    Oct 24 2015
    Perth, WA
    Non-bose and yes, massive difference. Once you look at the OE woofers you'll see why ;) Also the crossovers help!
    My respray thread
    Dec 19 2012
    Europe
    Quote Originally Posted by Okedokey View Post
    Did you have to do any vagcom coding to get them to work? Wire harness splicing? Fit in OEM mounting holes? Fit behind tweeter and lower grill covers?
    Think I just found the non OEM (but better sound quality) replacement sent I was looking for
    Oct 24 2015
    Perth, WA
    Nothing of the above. I just cut into the existing wire harness above the connector into the stock mount. I cut the speaker cone out and mounted the new speaker in that allowing me to wire it up and then reconnect the stock connector. I then ran the speaker wires to the crossover and then through the door to the head unit. The tweeter just clicked in.
    My respray thread
    Veteran Member Four Rings Shanster's Avatar
    Jun 02 2011
    2014 B8.5 Allroad, 2016 5th Gen Toyota 4Runner
    Maine
    Would this DIY apply with the polk speakers?
    http://www.audizine.com/forum/showth...teup-%28BWW%29
    Would one order two pairs/sets of the polk DB6501's in order to do the front and back speakers? I'm a total audio noob, so forgive me.
    Brent
    2014 B8.5 Ibis White Alload
    Sold: 2007 B7 A4 Avant 2.0T 6MT
