Results 1 to 3 of 3
    Dec 26 2015
    Dalarna/sweden
    Rain/lightsensor problem
    Hi!
    My light/rain sensor is not working at all. No ''regular'' fault codes stored, no warnings on the onboard computer, 12V to the sensor, but when i hook it up to Auto-com and read real time data it says following
    ''Rain sensor internal fault''
    ''Light sensor internal fault''
    ''Rain/light sensor adoption error''
    ''Rain/light sensor communication failure''
    ''Sensor rain/light-sensing: function limited by undervoltage''
    ''Sensor rain/light-sensing: function limited by overvoltage''
    Ch/lh does not work either, because the sensor think its daylight all the time.
    Any ideas? The sensor that's malfunctioning? Or something with the central electronic module?
    Feb 24 2004
    Minneapolis
    Did a lot of work on mine. I don't know this for sure but with so many errors I would think your rain/light sensor is either dead or there's a problem with the wiring to it. I might at least start by removing the trim behind the mirror to see if the plug and wiring there look OK. If you're interested, I could send you a diagram of that wiring so you can do continuity tests back to the Cent4al Electric Module. I have an extra Cent Elec Module I'd let you try, but it looks like you live about 4,000 miles from here. :)
    11 A4 Q, Prestige, Black
    207,000 miles, APR Stage 1
    Dec 26 2015
    Dalarna/sweden
    Sorry for really late reply but yes im intrested in wiring diagram! If you could send it over to [email protected] i would be happy:)
