Results 1 to 26 of 26
    Established Member Two Rings ARoach04's Avatar
    Jul 17 2015
    '15 Q5 Prestige TDI
    Masshole
    ECS Vag Com cable
    I just received my USB Vag-Com cable from ECS and have just about given up on getting it working. I consider my self very proficient with computers, it's how I make my living, but for the life of me I can't get the drives installed, all Windows sees is a "USB2.0-serial" device. I've tried multiple computers, multiple versions of Windows, and even tried to get it running on my Mac. Am I screwed? Anyone else run into this issue and successfully get it resolved?
    '16 Audi S4 Premium + | DSG | Florett Silver | Sport Differential | MMI+ | BO | Black Optics | ECS | V1 | AWE |
    '15 Audi Q5 Prestige TDI | Glacier White | MMI+ | BO | Black Optics |
    Jan 24 2014
    United States
    Needs to use a virtual com port iirc
    Mar 21 2015
    What type of computer afe you using and what software? Won't work on mac unless running parallels or bootcamp I believe.
    Jul 17 2015
    '15 Q5 Prestige TDI
    Masshole
    Ya,
    I followed the directions and pre-install the drives linked on the ECS site, but no joy.
    Jul 17 2015
    '15 Q5 Prestige TDI
    Masshole
    I am using an HP laptop, Windows 7, just trying to get Windows to not fail during the driver install.
    I gave up on the Mac for now.
    Mar 21 2015
    Delete what you have restart and try directly from ross tech here
    http://www.ross-tech.com/vcds/download/index.php
    http://www.ross-tech.com/vag-com/vag-com-faq.php
    Jul 17 2015
    '15 Q5 Prestige TDI
    Masshole
    Thanks for the ideas, but tried all those steps already with no luck.
    Veteran Member Four Rings infinkc's Avatar
    Feb 14 2004
    S Ã C, CÃ*
    Delete the generic device that Windows see and make sure you install the software and drivers before you ever plug the vagcom in.
    There are 10 kinds of people in this world, those who know binary and those who don't.
    Mar 21 2015
    You only want to plug in the usb after the software is installed and it asks you to do so.
    Jul 17 2015
    '15 Q5 Prestige TDI
    Masshole
    Ok, I'll try it all again tomorrow. Is anyone successfully using the ECS cable?
    Apr 11 2012
    "ECS does not offer tech support on this product....."
    lol, I wonder why.
    I have the ross-tech cable, it just works.
    Jul 17 2015
    '15 Q5 Prestige TDI
    Masshole
    Is a full Ross package really gonna cost me hundreds of dollars? Sometimes you get what you pay for.
    Mar 21 2015
    I thought you bought a genuine ross tech cable from ecs, is that not what you have? Yes it will cost you 350 unless you find a used one here in the classifieds.
    Veteran Member Four Rings GRUMPY-S4's Avatar
    Nov 16 2015
    DFW
    How much cheaper is this vs Ross Tech?
    Jul 17 2015
    '15 Q5 Prestige TDI
    Masshole
    Negative. It's a $25 cable.
    Mar 21 2015
    Quote Originally Posted by ARoach04 View Post
    Ahhhh, can't help you there. Id return it if I were you. What exactly are you trying to do with this cable? Carista is another option if you're trying to read codes and tweak some things.
    Jul 17 2015
    '15 Q5 Prestige TDI
    Masshole
    Understood, onto investigating Carista.
    Mar 21 2015
    Buy the dongle on Amazon for 40 and buy the pro app for 20. It's pretty easy and there are a few threads on it to help you.
    Jul 17 2015
    '15 Q5 Prestige TDI
    Masshole
    I've scrolled through them a few times, thanks for your help. Merry Christmas!
    Mar 21 2015
    No problem, Merry Christmas to you too my friend.
    Jun 12 2015
    CA
    I opened my ross-tech under the tree and was up and running in 15 minutes. It would have been faster but there was a lot of commotion. It works like a charm too.
    Mar 21 2015
    ^ Ross tech was easy but op's issue wasn't with ross tech cable.
    Oct 02 2006
    Wadsworth,OH
    What version of VCDS do you have? This cable works with VagCom-Lite 409.1 & earlier software releases. If you have a later version it may not be compatible.
    Jason
    Jul 17 2015
    '15 Q5 Prestige TDI
    Masshole
    I haven't even got to the VCDS part yet, my issue is with Windows assigning the proper drivers to the cable.
    Apr 19 2014
    Long Island
    I have both but prefer the ross tech for the more in depth and I just use carista for the simple mods or codes on friends nonaudi cars
    Mar 21 2015
    Quote Originally Posted by homelessNY_LI View Post
    I'm in the same boat as you.
