Results 1 to 13 of 13
    Jan 13 2015
    kansas city
    Suggestion: Best Fixes to make for cars with more than 100k
    I have an Audi A4 3.0 B6 and it sits at more than 100k. Received fairly recently. I was wondering what changes can I make to improve the performance drastically. Like with computers a small upgrade to SSD will improve speed by 2x and is easily the best upgrade you can make.
    For example, I know ATF alone would make my car feel much better at shifting.
    Any other thoughts?
    And Merry Christmas everyone!
    Mar 28 2015
    1987 Dodge Raider G54B Turbo
    Portland OR, United States
    Bleed/ flush the brakes, fresh fluid is good.
    Jan 06 2009
    Search for user name A4darkness and Engine Strengthening.
    B6 2.7t BEL tuned by Bische
    B7 2.0t
    Jan 06 2009
    B7 2.0t
    Veteran Member Four Rings imnuts's Avatar
    Aug 12 2009
    '21 F-150 Powerboost Lariat & '14 Acura RDX
    Dirty Jerz
    Quote Originally Posted by ADCS View Post
    That thread won't do much good for the OP since it is all 1.8T stuff and they have a 3.0.
    OP, worry about doing all the routine maintenance first, then worry about go fast stuff. For the V6, there isn't too much you can do to drastically change performance with an engine swap, but you can make it more fun to drive. It should also be a fairly reliable car if you take care of it.
    Sent from my DROID Turbo 2
    Jan 06 2009
    Sure it will. Lots of the ideas/intent are transferable. OP will just need to figure out the details specific to the 3.0
    B7 2.0t
    Aug 12 2009
    Dirty Jerz
    Just a quick browse of the links at the start of the thread, there were a lot of 1.8 specific things there. It'd probably take less time finding and filtering through the handful of 3.0 specific threads.
    Mar 28 2015
    Rear sway bar :)
    Active Member Four Rings alien_brain's Avatar
    Jun 04 2013
    SE MI
    1.8t swap and BAT
    Feb 22 2008
    03 A4 3.0 6MT
    The Meadows, NV
    compression test to see how much life has been removed from the engine up until now.
    check the records to see if the timing belt service was ever done...
    make sure you have the OEM spark plugs. Probably need replacing if originals, definitely need replacing if not OEM.
    If you decide to go the tranny fluid route, make sure you buy audi fluid. I don't have a tip, but from reading other threads, it seems the tip is a bit picky about its fluid.
    easiest performance upgrade: buy a rabbit diesel from the 80's and drive it for a week. then when you jump in your audi it will seem really peppy.
    Aug 26 2005
    Quote Originally Posted by alien_brain View Post
    1.8t swap and BAT
    A 1.8T + BAT = headaches from reduced reliability, increased maintenance, frequent repair requirements and compromised daily street driveability generally.
    Vorsprung durch Technik
    Jan 13 2015
    kansas city
    Thank you for all the awesome replies. Definitely doing compression test. I have a P0441 and P0421 and I am pretty sure that Evap purge valve is gone bad. Seems easy to fix. I am not sure when was timing belt replaced so I am doing that for sure after winter as that would be a lot of working outside in cold.
    Do you guys recommend getting Denso PK20TT spark plugs for this?
    Feb 23 2004
    2004 A4 1.8T Ultrasport 6MQ
    Stow, OH
    Work on reliability maintenance items first to make sure you have a solid platform for any performance improvements.
    Do a full fluid flush - power steering, brakes (DOT 4), coolant, transmission, and differentials.
    If you're not sure when the timing belt was replaced, then get a full kit that includes the timing belt, accessory belt, tensioner, coolant, water pump, and valve cover gaskets.
    Look into getting a fresh set of ignition coils and spark plugs.
    Check all vacuum lines and check valves for any signs of wear/cracks/etc.
    Check front control arms (upper and lower) for excess play. The bushings tend to go bad, get chewed up, and will cause uneven tire wear and sloppy steering.
    Check CV boot for any signs of cracks and grease seeping onto the brakes/wheels. If you hear any chirping noises when going over bumps, it may be the CV joints that need replacing.
    If you don't have the full history of the car, also look into getting a new air filter and charcoal cabin filter to complete the overall tune up.
    Once you've checked these items, then you can look into doing compression testing if you intend to do anything with the engine for more power. There's not a lot of options off the shelf for the 3.0. There is a supercharger kit out there, but many have had issues with it (blowing up the engine). All other tweaks will yield very mild gains (5-10hp).
    USP CLUB MEMBER #34
