Im a still new to these cars as I got mine about 2 weeks ago but this is pretty simple to search for...
2000 Tip S4 = B box ECU (interchangeable with J Box but requires VAGCOM engine recode and a Hitachi MAF and housing)
2001 6 speed S4 = H box ECU (interchangeable with M Box but requires VAGCOM cluster recode)
2001 Tip S4 = J box ECU (interchangeable with L Box)
2001.5 6 Speed S4 = M box ECU
2001.5 Tip S4 = L box ECU
2002 6 Speed S4 = T box ECU (Interchangeable with M Box)
2002 Tip S4 = AA box ECU (Interchangeable with L Box)
Also this has enough information as well...
http://s4wiki.com/wiki/Generations
With that being said I assume the APR 2001 is an H box and your car is an M box (assuming its a 2001.5) so there looks to be a compatibility issue with the clusters aside from that it is plug and play. Check your ECU and see what letter it has on the end of it.
Again I am new to this so if its incorrect please feel free to correct it! Hope this helps
