Anyone know if it is possible to set the trunk so that when using the trunk release button either on the fob or in the car, the trunk will just pop open just a tiny bit and require manual intervention to lift it fully open or manual intervention to lift it so the hydraulic shocks lifts it all the way open? Right now, my trunk flings all the way open and the concern here is accidental pressing of buttons on keyfob opening the trunk somewhere without me knowing it. My previous car was a MKIV Jetta which would just pop the trunk slightly, so even if you were looking at the car, it was hard to tell if the trunk was even popped but if you went and lifted it up after popping the trunk, you were good to go. Nice and stealth.
I saw this on the Audi website and I think I might have read this in the owners manual too, but it doesn't work for me:
Press the close button in the open rear lid. The trunk lid moves to the closed position by itself and soft close locks it automatically. To set the height of the trunk, bring the rear lid manually or automatically to the desired opening position and leave it in this position. Press the rear lid button for at least four seconds in order to save the desired opening position. The position can only be saved starting at a certain level.
