Results 1 to 11 of 11
    Aug 26 2012
    UK
    I'm using the cvt auto as a manual/stick
    As I'm sick of it revving high when cold and being a pita changing gear in general....if I'm doing damage then so be it, I wanted an auto but this is worse auto box I've ever had....how many others with stupid cvt box
    Oct 24 2015
    Perth, WA
    Mine works flawlessly.
    My respray thread
    Oct 24 2015
    Crestview, FL.
    My car has 156,000 miles and hot or cold you cant feel it shift. On normal driving it wont rev up past 2300.
    Veteran Member Four Rings dalmation53's Avatar
    Aug 20 2013
    Miami
    95k miles on mine and I always drive it in tip mode 100% of the time. Changed trans fluid at 86k and mine works great.sometimes i even forget it's a cvt because I always shift it No issues here.
    Sent from my C5306 using Tapatalk
    Ivan
    Aug 26 2012
    UK
    Quote Originally Posted by Okedokey View Post
    Can you explain what you mean
    I thought I'd have had more than just 3
    When it's crap what mean is most of the time yes I don't feel it changing but (in my opinion) revs far to high when cold ie up to 3 grand plus hence start with it in "manual/stick" mode. If I'm damaging the the box, to bad as I'm fed up with and hate the way it changes. Any autos I've had in the past (and I've had few) haven't been like this plus it's instant when pulling away, this things got a kind of elastic band effect for want of a better word, it's weird.
    I'm saying its cvt, I think it is if I move the lever to the left (I'm in uk) and can use up/down, no levers on the steering wheel, I was asking the mechanic I use about it, says it's one of the worse auto box made and that Audi should have used ZF and the make that's in it (he couldn't remember the name).
    Veteran Member Four Rings 80sGuy's Avatar
    Oct 09 2007
    Miele S7
    Not the best drivetrain I agree, but never have problems in the cold with this transmission. Had it replaced under warranty for 'bucking' even though I think a simple fluid change and/or replacing the snub mount would of probably fixed the problem, but hey the dealer ok'd it and I have nothing to lose, beats gambling it further. It's been working flawlessly ever since.
    Quote Originally Posted by Stu63 View Post
    2008 A4 2.0T | Dolphin Gray Metallic/Dk Gray | multitronic | Bluetooth | Dk Wood | Convenience. | Premium. | Sprt Susp. | Bare-bone 100% factory stock!
    Veteran Member Four Rings B-Time's Avatar
    May 03 2009
    East
    Certainly the worst one audi has sold. Snowmobiles use CVTs and need to be revved a bit until they actually move, that's part of what you described as the elastic band effect. Also used in public transport buses.
    Oct 09 2007
    Miele S7
    Quote Originally Posted by B-Time View Post
    ...and golf carts.
    Feb 24 2004
    Minneapolis
    The truth is, I don't believe anyone makes a reliable CVT yet. There are only two kinds of Mini's with CVT's. Those that have been replaced, and those will have to be replaced.
    11 A4 Q, Prestige, Black
    207,000 miles, APR Stage 1
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    Quote Originally Posted by mtroxel View Post
    I think Nissan/Infiniti are close to perfecting it..... After working out a million issues since they introduced them.
    Feb 24 2004
    Minneapolis
    Quote Originally Posted by Sanjman View Post
    Good for them. Someone will get it right. It's too good of an idea to just drop it. Keep in mind, the first hydraulic brake systems were a nightmare.
