Results 1 to 40 of 41
    Established Member Two Rings Cbotello's Avatar
    Apr 29 2014
    Bellingham wa
    B5 s4 brake upgrade
    Might be buying full front and rear s4 brakes with uprights for 300 is that a good price ? Don't really need them now but probably in the future so I don't want to pass on them if the price is good, but don't really know what s4 brakes go for.. I believe they are off of a 2001.. Is that all I would need to do the swap I have a 2000 1.8t manual trans.. I would be getting calipers rotors pads and uprights front and rear for 300.
    Dec 10 2013
    Borden, Ontario, Canada
    1. You don't need uprights for the rear. They bolt right up
    2. If the uprights are aluminum, you will need a new lower straight control arm because the balljoints are different between steel and aluminum uprights.
    3. You will need either 2001 1.8T front axles or V6 axles to mesh with the upright since the wheel bearing goes from 75mm to 82mm.
    $300 is a fair deal for all that. Get him to take out the rear uprights and seal the deal for $200-250. Make sure you get the rear caliper carriers with that otherwise your upgrade won't work as planned
    Everything graciously mispelled by Android
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
    May 17 2014
    Raleigh, NC
    Not worth it. At all!
    you are going to be $300 + LCAs and still have really heavy 2 piston cast calipers...and the rears are really not worth the investment. you can get some w8 / c6 v8 rears and have larger (10.5in) VENTED rears.
    So, for $500 you can source yourself some; OEM Porsche Boxster calipers, brackets, lines, and a8 rotors and actually have a REAL upgrade.
    I wouldnt have anything else on there. not to mention Worlds lighter and more efficient.
    Apr 29 2014
    Bellingham wa
    Ok thanks I won't be getting them in that case.thanks for the info guys
    Jan 17 2007
    2001 A4 1.8TQM, 2009 GSX-R 1000, 1995 Dodge Dakota Sport, 2015 FFR 818
    It's a fine setup, better than what you have from the factory (they put it on the S4's for a reason).
    Yes you can go bigger, "better", etc., and pay through the nose if you want (the whole "source it yourself" doesn't work as well once everyone is trying to get the same used Porsche parts).
    If I recall corectly the A8 stuff is actually in between the A4 and S4 for size.
    The biggest bang for your buck you can get is really aggressive pads, just be prepared for more wear.
    But if you do go with bigger brakes, whether it be S4 or not, be prepared to face wheel to caliper clearance issues, measure and test for that first.
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Quote Originally Posted by DND View Post
    Oh, really?
    You need to know where to look
    As for S4 brakes, I wouldn't waste my time on them. If you want something better than stock, go A8 upgrade. If you need something cool, go 17/18z, or wait for a decent deal on a used brembo set or something.
    2020 SQ7- Wife's ride
    2000 S4- Working?
    Apr 29 2014
    Bellingham wa
    Redline where should I look ?
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Quote Originally Posted by Cbotello View Post
    Well, I got s4 uprights from another member on here. They weren't cheap, but he didn't screw me either. I paid $300 for 17z calipers shipped from Rock Auto. They didn't come with crossover pipes, so I had to get some from ECS for $50. I think I bought some cheap pads and rotors from Rock Auto with intentions of upgrading later on, as well as stainless lines from Rock Auto.
    So basically, Rock Auto is the answer. Prices for everything now-
    17z calipers- $142/piece, so $284
    Pads- Lots of options $40 or less, so $40
    S60r rotors- There are cheaper options, but I'd go with the high carbon ones for $65/piece, so $130
    B7 RS4 Stainless lines- $40
    Crossover Pipes- $50 from ECS
    We are just shy of $550, make it $600 with shipping. You will also need some bolts and sleeves, so add another $50. So, $650 for the brake setup alone
    You will also need brackets or s4 uprights, and depending on the year and engine of your car, you may need axles as well. I think I have about $1000 into my brakes, but that includes the 300mm rear setup as well. Now, if you have time, you can wait for good deals, sales, or your price could go up or down depending on the quality of parts you buy. But there is zero question that I could put 17z calipers on your car for less than $1000, most likely around $800. JHM sells everything listed (not s4 uprights and axles since their kit is for an s4) plus a liter of fluid for $1950. True, they include higher quality parts, but I can piece it together for $1300 less, give or take of course.
    2000 S4- Working?
    Dec 09 2015
    neither here nor there
    Quote Originally Posted by rodgertherabit View Post
    What year Porsche Boxster do I need to source these parts from?
    Anyone have any info on rear upgrades too?
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Quote Originally Posted by Kronprinz View Post
    Pretty sure they use 986 boxster front calipers. not sure though.
    What info on rear upgrades do you need? You have two options, essentially- stick with a b5 s4 caliper and the appropriate bracket to go from b5 s4 stock up to 300mm, or go full custom and four piston brembo's from something else. The latter will take your parking brake away though, which is why sticking with b5 s4 calipers is nice.
    2000 S4- Working?
    Dec 09 2015
    Quote Originally Posted by redline380 View Post
    the guy above mentioned something about w8 / c6 v8 rears and have larger (10.5in) VENTED rears
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    he meant c5 a6 4.2, btw.
    Pretty sure b5 s4's are 256mm for rear brakes, and then you have a few options ranging from s8, w8 passat, 4.2 a6, etc.
    Some of these options, and I am not sure which, are not awesome solutions because of slight difference between calipers and such. That is why it is best to stay with s4 claipers, which are essentially the same as a4 rear calipers, only wide enough to fit the vented rotor. Off the top of my head, b5 s4 rotors are 256x22mm. You can freely go up to b6/b7 s4 rear rotors which are 300x22mm with the associated brackets.
    2000 S4- Working?
    Dec 09 2015
    ^Thanks.
    What is the going rate for both 986 front calipers?
    Dec 10 2013
    It's funny because B5 S4 rear rotors are vented haha.
    Simplest upgrade is the S4 rear upgrade. It's a direct bolt on. From there I would jump straight to the B6/7 S4 rear 300mm rotors like redline380 mentioned. All you need is the brackets (if coming from an S4 upgraded rear)
    I would personally (because I eventually will) get the front spindles with some V6 A4 axles, and go straight to 18z calipers with ML55 AMG rotors and a mild pad to compliment it. Track car status haha
    IG: 24_et
    Sold:
    RIP:
    Veteran Member Three Rings Wrath And Tears's Avatar
    Apr 03 2014
    17 GTI Sport
    The A8 upgrade is pretty simple. You just need TT caliper hangers and you use the B5 calipers and pads, with the A8 rotors.
    2017 MK7 CSGM GTI Sport DSG
    PP (Golf R Brakes, +10HP, VAQ LSD), LP, Kessey
    LW 17" Sparco Assetto Garra's, 034 Res-X resonator Delete
    Nov 11 2010
    1994 Lancer, 2007 Fortuner 4x4, 2009 Corolla, 2010 Hilux 4x4, 2012 Lancer GT-A, 2014 Montero 4x4
    Philippines / Australia
    I got the 17z Brembo calipers from the Cayenne. For the pair, you'll probably get it for $450-500 used.
    Apr 01 2011
    B5 on jack stands
    charlotte
    The tt\a8 combo with boxter calipers compared to stock calipers is night and day
    Fairly inexpensive upgrade too
    powered by
    Hot Boi parts
    Apr 01 2011
    B5 on jack stands
    charlotte
    Unless you just like the look or you're pushing a lot of hp big brakes are overkill imo
    powered by
    Hot Boi parts
    Dec 10 2013
    Mostly for looks haha
    IG: 24_et
    Sold:
    RIP:
    Jan 17 2007
    Oh, really?
    The Cayenne calipers have always been about $500 but then you are pretty much stuck with 18 inch wheels or larger (and despite all the rage, taller wheels are not better for a number of reasons...).
    The six piston Touareg calipers are the same but shorter so they will clear some 17 inch wheels but as soon as word got out that you could put them on S4's the price went from $150 to $350 etc. and all the ones in wrecking yards were quickly grabbed up.
    S4 rears are a great option, as you yourself mentioned. S4 fronts are better than A4 fronts which is all I stated. Since the OP was mentioning buying the full deal for $300 I simply stated that it was a better setup than he has now and technically it is a good deal.
    I bought S4 rears off a salvage company through eBay and the calipers were in need of a rebuild so I kept the carriers and used new calipers instead that JHM gave me a great deal on.
    Since I have the aluminum uprights from an early 2000 S4 I just used some cheap S4 fronts rather than deal with the extra cost of fancier calipers and spacers and different rotors etc. etc.
    Plus I can still run some 17 inch wheels.
    I may not be remembering correctly but aren't the A8 rotors like 288mm vs the S4's 321mm? It's been years since I messed with my brakes.
    I've got some of the highest performance street tires out there and I can still get ABS to kick in if I want to do full force braking so any more clamping force isn't going to stop me faster since I'm already at the limit of traction. I also don't have to worry about messing up the braking bias much since I'm running a balance Audi setup (it was quite noticeably rear biased when I only had the S4 rears on and people who have done a front only BBK have mentioned the potential front bias issues). My 2 cents.
    Apr 01 2011
    B5 on jack stands
    charlotte
    ^Thanks.
    300-350
    And get the brackets from usrt..
    powered by
    Hot Boi parts
    Veteran Member Four Rings nynoah's Avatar
    Jan 16 2006
    01.5 A4 avant Past cars: 95 S6, 85 Golf II VR6, 2 sciroccos, 92 Corrado VR6, 86 Euro BMW 535 Alpina
    LA CA
    For anyone that wants S4 rears. Just go to Autozone and buy rebuilt S4 Brakes and then turn in your A4 ones for the deposite back. You will need S4 rear rotors and new pads. But its a cheap upgrade.
    The fronts require a lot more work. I have the S4 brakes all around on mine and I really like them. Though I am debating upsizing to the Toureg brakes.
    2001.5 black on black avant 5spd, EFR 6758, Pag Parts band manifold, Vibrant GESI High flow CAT, 2.0L 06A, IE intake manifold, built AEB head, 1000cc Boosted Euro Tune, bosch 044, Ringer Racing stage 3 hybrid Organic/Cerametalic 240mm clutch, S4 interior upgrade, full S4 brakes front and rear with lines, 17in OZ Racing Ultraleggera, 034 HD suspension arms, Stern soft mounts, mirimoto bixenon etc. http://www.audizine.com/forum/showth...s-Build-thread
    Apr 01 2011
    B5 on jack stands
    charlotte
    ^^you pulled it off?
    powered by
    Hot Boi parts
    Jan 16 2006
    LA CA
    I just had to replace my rear brake caliper because the parking brake part was seizing. Autozone sent me a caliper with the mounting bracket attached. They took the box back (deposit) with barely even a look. The just looked to see there was a caliper in there. Heck I think I am going to try the same thing with the Taureg brakes and S4 calipers... lol
    Dec 09 2015
    Quote Originally Posted by demonmk2 View Post
    300-350
    I didn't see any brackets for an A4 on their site.
    Quote Originally Posted by nynoah View Post
    ...essentially beating them for rear S4 cores. LOL
    Jan 16 2006
    LA CA
    Go to Autozone directly and ask them when you buy if it comes with the brakets. Mine did and when the guy sold them to me he said that the ones I was ordering came with the brackets. He was quite proud to tell me because it was a selling angle to get me to buy it. I was like hmmmmmm. I bet some people would like S4 rears
    Apr 01 2011
    B5 on jack stands
    charlotte
    Look up mk1 Audi TT
    - - - Updated - - -
    You got my wheels turning
    powered by
    Hot Boi parts
    Oct 10 2013
    98 Civic CX Hatch, 2012 CBR250R
    State College PA
    the ebrake cable lines right up?
    Jan 16 2006
    LA CA
    Ebrake lines line up. I have S4 brakes all the way around right now.
    Established Member Two Rings DarthWinja's Avatar
    Jul 09 2012
    Denver
    +1 for the A8 brakes, I love mine.
    Dec 09 2015
    So, 312mm rotors, boxster calipers, brackets from usrt(any where else to get brackets, oem or aftermarket?)
    TT carriers?
    Apr 03 2014
    17 GTI Sport
    http://www.usrallyteam.com/index.php...oducts_id=1893
    I think these are the brackets made to fit the TT spindle (upright I assume) also assuming its the same as ours. I did no research as I am not looking to do the upgrade, just went to their site and clicked on the Mk.IV/TT category for braking.
    Apr 01 2011
    B5 on jack stands
    charlotte
    Apikol but a lot more money wise...
    powered by
    Hot Boi parts
    Apr 01 2011
    B5 on jack stands
    charlotte
    Quote Originally Posted by Wrath And Tears View Post
    They'll work, I've done an upgrade using them for the 986 calipers
    powered by
    Hot Boi parts
    Dec 09 2015
    With TT carriers?
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    The six piston Touareg calipers are the same but shorter so they will clear some 17 inch wheels but as soon as word got out that you could put them on S4's the price went from $150 to $350 etc. and all the ones in wrecking yards were quickly grabbed up..
    Dude, v6 Cayenne calipers and any touareg calipers are the same (within a certain amount of years). Those are called 17z calipers and are available rebuilt from rock auto for $142 a piece. And yes, they do fit some 17" wheels. I know because mine fit under my 17" celebration wheels.
    The v8 cayenne calipers are called 18z's and use 20mm larger rotors than the 17z's.
    2000 S4- Working?
    Jan 17 2007
    Yes and no, the Touareg had two 6 piston caliper sizes, one the same as the Cayenne and one with shorter mounting tabs for a smaller rotor that would fit in a 17 inch wheel, those became scarce and expensive when I was trying to find them, so I gave up. JHM uses the longer mounting tab calipers from/for the Cayenne in their kits, thus the 18 inch wheel restriction. I spoke with them when they were originally building their kit and thinking they could make it work with 17 inch wheels but when all was said and done not only was it 18+ inch only but it also ended up costing about 70-80% more than when I first heard about it. Oh well, like I said, my S4 brakes can do more than the best tires can handle so I don't need more.
    Apr 01 2011
    B5 on jack stands
    charlotte
    With TT carriers?
    If you want to use your stock calipers the TT carriers will work, if your using 986 calipers the TT adapter carriers will work.
    They're two different carriers but both will bolt up to your uprights depending on which caliper you use.
    powered by
    Hot Boi parts
    Oct 10 2013
    State College PA
    What years exactly should we be looking for those 17z's?
    Jan 16 2006
    LA CA
    I am just going to write this because I know someone on here (lurking newbie) is probably thinking about this. So just to be clear 17z WILL NOT FIT AN A4. They must be used with S4 uprights or adapter plates. I would suggest researching a lot before you jump into them.
