Results 1 to 3 of 3
    Nov 17 2015
    vancouver/bc/canada
    Question Q5 - 3 questions about the climate Control Fan Speed
    Hi,
    I have had an Audi Q5 for a month. Every time I start the car the fan is at 11. Really noisy and unnecessary. So I click the fan button and bring it down to 4 or 5. I do this every time I turn on the car...put on seat belt...adjust the fan.
    I went through the MMI settings and couldn't find anywhere I could set the default fan speed.
    I read here http://www.audizine.com/forum/showth...trol-Fan-Speed that if I take climate control off automatic then the fan won't go up to 11.
    Three questions:
    1) Is there a way to set the default fan speed? (I think the answer is no)
    2) Is there a work around for this, or do I have to manually adjust the fan speed every time I turn the car on?
    3) How can I make sure that my climate control is not on auto?
    Houman
    Veteran Member Four Rings boomtime's Avatar
    Apr 22 2013
    Audi, BMW, Ford
    Rocky Mountains
    I found that by leaving it on auto and then setting the temperature I want the fan will slow down by simply raising or lowering the temp knobs closer to ambient.
    There is probably a way to vagcom these settings but I have not tried to change the defaults myself yet. The next time I use my cable I will poke around in there and look.
    The eventual supremacy of reason.
    CPMB K04+e85
    Twin Turbo 391
    E36 Drift Queen
    Senior Member Three Rings Drichardson72's Avatar
    Apr 11 2015
    Vancouver, Canada
    I'm on my second Q5 and have never had this problem. I keep mine set to 22.5° calculus and on auto. The only time my fan spins up like you mention is when i select front window defrost.
