Results 1 to 13 of 13
    May 05 2015
    Got the new RS7 - think I have a problem...
    I finally took dlivery of my new 2016 RS7 and it is everything I expected and more.
    [IMG][/IMG]
    When I took it from the dealership, the car drove great. On the same day, i swapped the tires for the winter ones. It seamed fine, however, later that day, car started feeling a bit wobbly on smal steering inputs. Almost like the back is sliding out a bit and reminds me of the feeling in driving on the snow covered road.
    - car details: DRC suspension
    - winter rims and tires: nokian Hakapelita R2 255 35 R20 and Hartman wheels.
    Had a dealer technitian test drive it and confirm something felt wrong. His superior drove it subsequntly and claims nothing wrong with the car and it is because of the tires.
    Behaviour is there irrespective of the drive mode or other settings.
    Question: any thoughts on this issue? Similar experiences? Do you guy think that tires could be less supportive due to warm weather at te moment (10+ celcius).
    Any sugstions would be appreciated.
    Dec 20 2006
    CAN
    Suggestions:
    1. don't believe what the dealer tells you, they'll tell you anything to get you out of there so you can't blame anything on the vehicle. this is pretty much a truism.
    2. if something is this obvious to you and the dealer then something is clearly amiss. maybe take to an indy shop for a more realistic opinion.
    good luck!
    emilyPay.com - Payment Processing for Professionals
    2025 RS6 Performance - Florett Silver, Blue Plus RS Design Pkg, Carbon Matte Optics Pkg, Dynamic Pkg, Black Dinamica Healiner.
    Wife - 2024 SQ8 - Chili Red
    Old Friends: 2021 RS6 Nardo Grey, 2021 Cayenne GTS, 2018 Panamera 4S ST, 2016 RS7, 2014 RS7, TT/RS, E90M3, B7RS4, B7S4
    Sep 10 2015
    VA
    I have heard winter performance tires feel different to summers depending on temps. I'm about to put my winter tires on next week so will know for sure then. Had new tires on my truck today too and they felt totally different too as they were different model.
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    They are studless snow tires right? Not performance winter tires. I suspect in warmer weather they would be quite "squishy". I'm sure on snow and ice they will be great but in the mean time maybe not the best unfortunately. Sorry.
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II 12.868@107.8 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I 14.746@95.29 3944lbs
    Established Member Two Rings justcured's Avatar
    Oct 15 2015
    2025 Porsche 718 GTS 4.0 Coupe; 2013 S7 and 2000 Jaguar XKR Coupe (both lost to Helene surge)
    FL Gulf coast; CA Bay area
    Sasha,
    It is unlikely that swapping wheels did anything to your car.
    When warm, those large square tread blocks that do such a good job cutting through snow will "squirm" particularly when subjected to lateral loads. For a real thrill, drive across a metal grate bridge deck on new winter tires -- it is worse than driving on ice because the car wants to go both left and right at the same time and without warning.
    That said:
    All lugs tightened to correct torque specs?
    Wheel width compared to stock? Overwide or too narrow wheels can enhance the feeling described above.
    Offset of the wheels compared to stock? Have you widened or narrowed the track of the car with offset?
    Last edited by justcured; 12-23-2015 at 06:01 PM. Reason: Edited to add: Until recently, a northeastern and midwest snow belt resident.
    Veteran Member Four Rings Sd76's Avatar
    Feb 01 2009
    Pa
    Quote Originally Posted by Barritia View Post
    Agreed. What's the temp in your area. Clearly when temps drop the winter tires stay pliable so they can grip the road vs. summer tires that get super hard and lose grip. If it's still too warm those winter tires can feel like bubble gum in the summer and feel like your moving more than you should be. Easiest way is just out your OEM WHEEKS back on and see if this solves problem and confirms that the tires can be it ... I'm not surprised with the amount of power your car has. I had out winter tires on bf a little too early and had a similar feeling until the temp dropped. Hope it works out.
    May 05 2015
    Quote Originally Posted by Sd76 View Post
    Thanks! It is unseasonably warm here in Toronto. Temps are supposed to drop by Sunday so I will see if anything changes.
    It is not as easy to get the tires swapped as I have them stored through a dealer but will do that to confirm if I don't figure it out within a week. My winter setup is same as some of the forum members here so I don"t think it would be offset or tire size (winter 255s vs summer 275s). Thank you all for suggestions!
    Oct 13 2014
    In addition to "squirm" being more pronounced with winter tires, new tires also have a greasy compound on them that allows it to come free from the mold during the manufacturing process. It can take several hundred miles of driving before this compound is completely worn away. I would suggest just driving cautiously for the next 500 miles or so and the tires should feel much better by then.
    10°C isn't really too high for winter tires so I wouldn't be concerned there.
    Veteran Member Three Rings Ensoniq's Avatar
    Jul 12 2014
    Raleigh NC
    Put the war, weather tires back on and see if the problem goes away or persists. Will rule the tires in or out anyway
    2014 Phantom Pearl Black RS7
    2014 Mercedes ML350 4Matic AMG package
    2008 Corvette Z06 (Sold)
    1996 Corvette Collectors Edition (Sold)
    Veteran Member Four Rings HyperM3's Avatar
    Mar 20 2004
    Lawrenceville, NJ
    It's the tires.
    21 S5 Coupe - RacingLine strut brace/034RearSwayBar/CTSTransMount/034 tune/VPS Res Delete/CTSIntake
    10 S4 (gone),13 S6 (gone),14 S6 (gone),14 S6 (gone),16 S6 (gone),17 A4 (gone),19 S4 (gone)
    20 BMW R1250RS
    ACNA Lifetime Member - 26690
    Respond to a post with an answer, they will keep asking questions. Teach them how to RTFM, they will learn to help others.
    Veteran Member Four Rings zee007's Avatar
    Jan 12 2010
    2012 C63; 2017 X5M
    RVA
    Quote Originally Posted by HyperM3 View Post
    It's the tires.
    I agree.
    - Zee
    Current: MY22 RS6 | MY19 Q8 | MY74 50
    Past: MY09 TT | MY10 S5 | MY13 AllRoad | MY15 S6 | MY16 RS7 | MY17 911TT | MY17 X5M | MY17 Q7
    Jun 19 2014
    2000 Audi TT Quattro Coupe
    Milwaukee, WI
    My S7 felt the exact same way once I put my snows on this winter. It's the tire being more squishy, seem to flex more and feel like the car "wonders" a bit more on the road. I mounted Dunlop WinterSports in 265/35/20 on my factory rims. Granted I have all sorts of issues with tires lately :) I moved my stock Pirellis to new 20x10.5 rim and with the stretch they SUCKED in the rain. Planning to replace those though next summer since they are near their end of life and I don't like that amount of stretch.
    Oct 25 2007
    Scottsdale AZ
    i've had the same experience with an S5, it's the tires + warm temps
    16 Glacier S6 - Sport, Black Optic, Layered alum, Bloze
    13 Orca Black Q7 - TDI Prestige - S-line - S-line Plus - Air Suspension - B&O - Tech - Towing
    16 Nardo Gray RS7 - GONE
    11 Ibis S4 - Prestige - Titanium - Sport Diff - APR Stage 2+ - 35% Huber Optik - Black BBS CH-R 19x9.5 - KW SC coils - E-codes - RS6 Air Shifter - AK and USS sway-bars and end-links, GONE
    08 GMG S5 - GONE
    01 Casa S4 - GONE
