I took my car for a trip to Arizona the past week. Temperatures were in the high 20's, low 30's. When I returned, I noticed some fluid underneath the vehicle which I think is transmission fluid. The temperature here is in the low to mid 50's. The leak occurs just forward of the cross bar between the 2 under belly covers under the transmission. There is also 2 small metal tubes running across. I attempted to tighten the bolts on the transmission around the leak. They are already very tight. The slow leak doesn't seem to happen while the car is idling. After a long drive, I also don't observe any leak/wetness. However, I observe a leak/wetness between the 2 under belly covers and small oil puddles underneath the following morning.
I am not observing any driving issues with the transmission but I do notice slipping under heavy acceleration going up a steep hill. I have not got any warnings of low transmission fluid. Will the ECU warn me when the fluid is low?
Not sure what the CVT fluid looks like. The liquid under the vehicle is clear and slippery and sort of pinkish.
Would appreciate guide any guidance/suggestions.
