Results 1 to 8 of 8
    Nov 20 2015
    West Palm Beach FL
    Drivers side head question
    so I recently picked up an 01 avant and started a timing belt job because the passenger side cam was 19 degrees off. After getting everything apart I noticed there was some silicone on the front part of the driverside head. It was covering what looks like a ball bearing in between the screw holes. Not really sure what that is or why it would have silicone all over it. Passenger side is bone dry and has none. I haven't seen anything about this in any TB threads. Anyone have any info?
    Dec 04 2008
    5 audis and an f250
    Cresco PA
    thats how you block off the sai port if you don't get block offs.
    Mine - Silver 01.5 S4 stage 2 - st - apr - ssac - apikol
    Wife - Imola 00 S4 stage 2 - st - ssac - podi - usp - 034
    Ours - Silver 92 S4 custom coilovers - 3 inch exhaust - ak motorsports
    Indigo Pearl 92 Coupe
    White 07 Q7
    Nov 20 2015
    West Palm Beach FL
    Quote Originally Posted by audacity View Post
    This is the front of the motor. Wouldn't that be on the rear?
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    It is how they do it at the factory also. I think the factory usually staked them like the others though.
    Both heads are the same casting and can be used on either side.
    What makes them different is where they put the plugs.
    The front of the dside is the back of the pside, and vice versa.
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesn’t move and it should - WD40.
    Nov 20 2015
    West Palm Beach FL
    So basically that metal ball I see is a factory plug and there's no need for someone to put silicone there
    Nov 16 2010
    WetSide, WA
    Probably.
    I dont remember ever seeing one leak, but there might be a reason somebody put the silicone on there.
    Odds are it was just somebody that didnt know any better playing it safe though.
    Here is one I did myself.
    Aug 04 2013
    Pennsylvania
    lol I always wondered what was up with those balls
    I'm like a tree. I'm all root
    Nov 20 2015
    West Palm Beach FL
    Yeah the plug did have a little crud build up around it but my guess is it came from the leaky valve cover and got trapped by the silicone. Either way we will see because I already started to put it back together without silicone. Thanks for the help
