Results 1 to 12 of 12
    Feb 24 2013
    CA
    i need help!! please!!!!
    So on sunday night, car started over heating :( i thought it was the water pump but i came to realize that my radiator fans stopped working. Its throwing code p0691 and its says there a short to ground for fan 1 but i have checked all connections with no luck. Ive been at it since monday morning and i cant figure it out. I replaced the fan control module and that set me back 450 bones as it is. Please, if you guys have any idea, comment up. I have checked fuses aswell but if you guys no if there is a fan relay let me know. Thank yoi
    Veteran Member Three Rings STA4's Avatar
    Jan 12 2012
    Mississauga, ON, Canada
    Maybe you should check the resistance across the fan motor. Maybe it's shorted internally?
    Peter
    2009 A4 2.0T Quattro Premium 6MT
    Meteor Grey/Black | B&O | STaSIS Tune/Exhaust/Springs/RSB/Wheels | K&N Filter | Eurocode TIH/HFIP/IHK/HFC/Alu Kreuz | GFB DV+ | R8 Coilpacks | Strat O2 Spacer | BFI OCC | Podi Boost Gauge | Rieger Rep Spoiler | RS4 Rep Grille | A4L Foglight Grilles | LED Interior/Puddle/Plate/Signals | Morimoto 5500K HID Foglights
    Veteran Member Three Rings GilliamOS's Avatar
    May 26 2015
    2013 A6 3.0T Prestige | 2013 Elantra GT
    Mormon Country
    I cannot find a P0691 in ElsaWin. Giving zero info on your car is not helping anyone either. You replaced the fan control module, but did you verify either or both fans are working with a 12v power source?
    2013 A6 3.0T - Slightly better than poverty package.
    2009 A4 2.0T Avant - Totaled
    2000 A4 1.8T - Sold
    1999 Millenia S - Sold, though it should've been crushed 'n cubed
    1997 A4 1.8T - Totaled, repaired, sold years later better than before
    1990 Maxima - Totaled from hail dents
    1987 Maxima - Sold
    1986 Golf Diesel - Rusted and fell apart
    Feb 24 2013
    CA
    So heres alittle more info. The car is 2009 audi b8 a4. Both fans were checked and they both spin freely with a 12v battery source. How do i go about checking resistance of fans? I think if they were bad they wouldnt spin with the 12v source
    May 26 2015
    Mormon Country
    What module did you pull that code from? I couldn't find it in the ECU list.
    2000 A4 1.8T - Sold
    1987 Maxima - Sold
    Feb 24 2013
    CA
    I got it from the wngine module off vagcom
    Feb 24 2013
    CA
    Also, when i clear that fault, its fine. But as soon as i start the air conditioner at lo temps, it comes right back up.
    Feb 24 2013
    CA
    Feb 24 2013
    CA
    So... This morning i turned on my car and the fans came on when i put the temperature all the way down to low. Now i turned off the ac and that stopped the fans but when i turned it back on, they didnt come back on
    Veteran Member Three Rings Fburg A4's Avatar
    Oct 06 2012
    Fredericksburg, VA
    Quote Originally Posted by Slick_B8 View Post
    There is a relay (J317) in the circuit. But if it were bad (by bad I mean relay is not energized and allowing power to go to fuse SB11), power would not be applied to fuse SB11 which is located under the hood. From the looks of it, that power wire eventually goes to the coolant fan control module (terminal 2, it is a red/green wire). So maybe check that fuse SB11 under the hood and see if it is receiving power when it should (problem is I don't know when exactly it is supposed to receive power from the relay, when AC is on perhaps?). There is another wire supplying power at terminal 1 of the fan control module, it is the thicker red wire if the diagram is accurate.
    Not sure if you can do this with VCDS but its worth a shot, see if you can enter into special functions and perform an output test and see if it activates the relays and all that good stuff. Probably a better way to check out the wires compared to when to engine is running and things are hot and moving around.
    Feb 24 2013
    CA
    Is there a diagram for the fuses under the hood? I couldnt find a diagram at all for them unfortunately. Also, where can i find relay j317? I really appreciate the help fellas.
    Oct 06 2012
    Fredericksburg, VA
    I sent you a message with a link to a document I uploaded
