Results 1 to 37 of 37
Thread: 50k Service?
    Veteran Member Three Rings TTRStud's Avatar
    Jul 12 2013
    Jacksonville, FL
    50k Service?
    Folks,
    About the only thing that did not come with my car was the owners/services manual. I searched online and there doesn't seem to be anything too involved for when the car hits 50k miles. My car was a CPO car, but unfortunately the CPO did not transfer to my name because well, that's just how Audi works. That said, the car was maintained meticulously prior to my ownership, and since I became the owner, it has undergone 2 oil changes (roughly every ~5000 miles). Visually I know that I will need tires and possibly brake pads/rotors within the next 5-10k miles. Outside of that, anything else that's necessary?
    Also, how long do the original pads and rotors last, on average? I know this question is entirely dependent on the driver and how the car is driven. I have the feeling that my car is still on original pads and rotors.
    Thank you everyone, and happy holidays! :)
    '10 Meteor Gray Metallic S5 Prestige Loaded 6MT - AWE Track - PCed OEM Rotors
    Veteran Member Four Rings i1overice's Avatar
    May 09 2013
    Loads of junk.
    Northern Virginia
    How hard did you search?
    It's every 10k miles starting at 5K.
    https://www.audiusa.com/content/dam/...-Year-2010.pdf
    Your 55k is next.
    I would do the cabin air filter too, it's quite simple. The other things to look out for is the battery since you are getting just around that time.
    Pads/Rotors all vary but if it is your original set you should be due for a new set of both.
    Current - 2017 Honda Civic EX-T
    Sold - 2010 Ibis White S5
    Jul 12 2013
    Jacksonville, FL
    Quote Originally Posted by i1overice View Post
    Your 55k is next.
    Apparently not hard enough or maybe the results I got were useless (I googled "audi s5 service intervals")...thanks for the info! I will review it in detail.
    May 09 2013
    Loads of junk.
    Northern Virginia
    Quote Originally Posted by TTRStud View Post
    Hehe no problem. just a heads up, its a funky chart to dissect.
    Mar 21 2015
    I just googled that for the hell of it and 2012, 2013 popped up first, lol.
    Jul 12 2013
    Jacksonville, FL
    I appreciate your help, thank you. I'm good with charts! :) Merry Christmas/Happy Holidays!
    Indeed...not exactly what I expected. I got a bunch of a4 results too...oh well. Merry Christmas/Happy Holidays!
    Mar 21 2015
    If you do go for the service I highly recommend printing it out and highlighting everything that pertains to your car. Make sure the SA gives it to the tech so everything gets done. I didn't do that on my first visit and went home and checked everything and the tech missed a few. Audi doesn't really give the techs a guideline on what is supposed to be done for each cars service appt.
    Veteran Member Three Rings PlainOleS5's Avatar
    Apr 05 2015
    Ellicott City, MD
    I think Sparkplugs are on the list for 55K service on an S5 as well. Just had mine done a few months ago.
    2010 S5 Prestige | 6MT | Phantom Black | Sports Rear Diff | B&O
    Ziza LED Conversion/LP Lights | Windfire LED Projectors | 30% LLumar Pinnacle & Air Blue 80 WS | RS5 Grille
    Autostyle UK Floor Mats | AWE Touring/Non-Res DP | APR Carbonio | 034 Trans/Rear Diff | MRR GF9 19x10 ET25 | 255/35/19 Michelin Pilot Sport A/S 3
    Build Thread | IG
    Jul 12 2013
    Jacksonville, FL
    Based on the list provided above for all 2010 models, this is what I gathered that applies to the S5 for the 55k mile service:
    Engine Oil/Oil Filter – change oil and replace filter
    Cooling System – check level, add if necessary
    Engine Compartment – check for leaks
    Battery – check and replace if necessary
    Dust and Pollen Filter – replace
    Spark Plugs – replace at 55,000 miles or 6 years, whichever occurs first. Thereafter, every 60,000 miles or 6 years, whichever occurs first.
    Air Cleaner – clean housing, replace filter element
    Snow Screen for Air Cleaner – clean
    Plenum Panel – remove cover for plenum panel to check water drain and clean if necessary
    Tires and Spare Wheel – check for wear and damage, check tire pressure and renewal date of tire repair set (where applicable), reset Tire Pressure Monitoring System (TPMS)
    Wiper Blades – check condition and replace if necessary
    Wiper/Washer/Headlight Washer – check adjustment and function, add fluid if necessary
    Service Reminder Display – reset
    Horn – check function
    Brake System – check for damage, leaks, pad thickness, fluid level
    Exhaust System – check for damage, leaks
    Drive Shaft Boots – check
    Manual Transmission and Final Drive – check for leaks
    Underbody – check for damage and leaks
    Road Test – check braking, kick-down, steering, electrical, heating and ventilation systems, air conditioning, ASL Automatic Shift Lock, power accessories and reset driver information display
    Brake Fluid – replace every 2 years regardless of mileage.
    I have two more questions:
    1) Does anyone know why my car is telling me that the service is due now (51,900 miles) and not at 55k? It started to count down from 1000 until it got to this point. Since I'm doing 5k-mile oil changes, I'm sure I'll be ok if I wait it out to 55k to do it all. Last oil change was at 47-48k.
    2) Also, what is it running people to have this performed at the dealer? I've heard some outrageous prices before, and if that's the case I may do it all myself or have a certified independent shop do it.
    Veteran Member Four Rings Sgibb16's Avatar
    Jul 02 2012
    2012 A5 & 2002 Passat Wagon
    Fredericksburg, VA
    How long ago did you service it? There is a number of days that are associated with it as well.
    2012 A5 P+ | Sports Package | 6MT | 35% Tint
    REVO Stage II | AWE Quad Exhaust | 034 HFC | E-Codes | FK Silverline Coils | JHM Short Throw Shifter | Eurocode HFIC Pipe | Roc Euro Intake
    TR8 Intercooler | CTS Silicone Hose Kit & Turbo Outlet | CR-15 Strut Brace | Alu Kreuz | S-line Front & Rear Bumper Conversion
    Jul 12 2013
    Jacksonville, FL
    Quote Originally Posted by Sgibb16 View Post
    I purchased the car late June last year, and after 3 months of ownership I had an oil change performed (small service). Maybe it's the fact that the car is 6 years old (a time milestone) but not quite at 55k miles yet (but close).
    May 09 2013
    Loads of junk.
    Northern Virginia
    It's based on when the tech reset the maintenance check up. It will count down from 1 year and 10,000 miles.
    Jul 02 2012
    Fredericksburg, VA
    The interval is every 10k miles after the initial 5K but there is time like a year or so that goes along with that.
    For example my car always tells me in early spring to change the oil because i don't ever hit the 10k miles. I'm guessing that maybe the service interval wasn't reset last time you got the oil changed and the car is thinking you are near the 1 year interval.
    Jul 12 2013
    Jacksonville, FL
    It's interesting; the oil change is counting down appropriately, so it seems like it was reset. The inspection/service interval says it's due for service.
    May 20 2015
    Watertown, MA
    The time thing is definitely a bit annoying. My 2011 has 35k miles and it will be up for its 65k service this year. Not sure what happens when i max out the maintenance schedule. I am barely putting miles on it.
    Jul 12 2013
    Jacksonville, FL
    Does anyone know what it runs to perform the 55k service on average? My local dealer quoted me $722 plus $189 if the brake fluid needs to be flushed. This is outrageous, specially for things that I can do myself. Or is there a shop that sells a 55k mile bundle for the DIYers?
    Jul 02 2012
    Fredericksburg, VA
    https://www.europaparts.com/ultimate...-s5-b8-v8.html
    Jul 12 2013
    Jacksonville, FL
    Thank you sir!
    Senior Member Three Rings ChipB's Avatar
    Nov 04 2009
    '21 BMW X5, '16 BMW M4
    Morristown, NJ
    Quote Originally Posted by Atmmac View Post
    +1. I did the 65K service on my '09 last April, with less than 28K miles on the odometer! I estimate I will be at just about 32K miles for my 75K service in three months.
    '24 RS5
    Jul 12 2013
    Jacksonville, FL
    Reviving this thread - I'm getting ready to purchase the stuff I need, and was wondering what the consensus is of LiquiMolly oil versus the OEM Castrol used by the dealers? The EuropaParts kit linked above doesn't give me the option to select an oem oil. Where is everyone getting their kits from for the 55k service?
    Mar 21 2015
    Personally LiquiMolly is better. I'm getting an oil change next week and my shop uses LiquiMolly. The kit you are looking into is great. You shouldn't have any issues with it. If you can swing it go with Motul, top of the line. Make sure to get a new drain gasket too.
    Jul 12 2013
    Jacksonville, FL
    So if you click on that link, there are multiple types of LiquiMolly...the premium and another 5w40 right underneath. Do you know the difference? Also, what advantage would Motul offer? I'm doing 5k miles oil changes so I'm not sure that going with a super oil would make much of a difference. About the drain gasket, should I get a new plug or does the dealer usually just replace the gasket? It appears I can buy a plug, a gasket, and a "kit" which I don't know what it encompasses.
    Are the spark plugs and filters (air and cabin) the recommended ones? I'm planning on doing oil, spark plugs, air/cabin filters, brake fluid flush.
    Veteran Member Three Rings wangshuo1989's Avatar
    Jan 09 2016
    I personally just grab M1 0W-40, which is dirty cheap in walmart and of very great quality. Dealer will never touch your drain plug, they just suck old oil from dip stick.
    2013 S5 Misano Red, DSG, B&O, Sport Diff, MMI+, JHM 207mm crank pulley (7PK1370 Contitech belt), APR Stage II Dual Pulley, APR TCU tune, APR CPS, CR15, IE CAI
    2018 XC90 Inscription, B&W sound, Convenience Pkg, Air suspension
    2014 Mercedes E350 rwd
    2021 BMW 540i
    Mar 21 2015
    Quote Originally Posted by wangshuo1989 View Post
    Varies by the dealer. Mine drainds from the plug. OP isn't going to the dealer though.
    Jul 12 2013
    Jacksonville, FL
    Does anyone know or have a link where the part numbers have been specified? I need the following:
    OEM oil (Castrol 5w40) part number
    OEM drain plug gasket part number
    OEM oil filter part number
    OEM air filter part number
    OEM cabin filter part number
    OEM spark plug part number
    What type of brake fluid is used/recommended by Audi?
    Thanks! A local VW dealer is sourcing everything for me, and asked me for specific part numbers. I will then compare between buying all OEM or from Europaparts.
    Jan 09 2016
    I suggest you go to ECSTuning and check it out, they have Audi OEM part number as well. And our car is using DOT 4 fluid. You can also get this fluid's part number from ECS.
    2021 BMW 540i
    Jan 09 2016
    Well elsaWin recommends suck oil from the dip stick and I know at least two dealerships I went to follow that method. Your dealer seems go an extra step, which is good. Also if you read carefully, OP does mention oil change at dealer in post #22.
    2021 BMW 540i
    Mar 21 2015
    I think he is referring to the dealer as the best thing to follow and he should do the same in that post. No big deal though
    Jul 12 2013
    Jacksonville, FL
    Great suggestion, thanks! I just got everything for $285, all OEM components.
    Jan 09 2016
    No problem! That's a great price;) For me I also have transfer case and rear diff fluid changed. The ATF in rear sport diff is like $40 a quart, it's like liquid gold!
    2021 BMW 540i
    Jul 12 2013
    Jacksonville, FL
    I've heard about the infamous ATF pricing! How many quarts does it take? I'm waiting until the next major service for that, as I will also be doing tires and brakes shortly!
    Jan 09 2016
    Fortunately it only takes 1 qt.
    2021 BMW 540i
    Established Member Two Rings 8T_BoCO's Avatar
    Mar 23 2015
    2012 A4 Avant S-Line
    Colorado
    I'm pleased with the Europaparts ultimate service kit (and copious oil selection).
    My independent V.A.G. guru only charges $30 labor if I supply the oil change supplies, which saves a significant amount over the $550 my dealer wanted for the 55k service.
    The cabin air & engine air filter changes are easy enough to DIY. When I had more time (fewer other hobbies) I used to do topside oil changes myself with a Pella on previous V.A.G. vehicles.
    2019 MT6 Golf Sportwagen S 4motion | Dark Blue
    Jul 12 2013
    Jacksonville, FL
    Quote Originally Posted by 8T_BoCO View Post
    I hear ya! I'm very mechanically inclined myself and the simplicity of the service makes me want to do it all...it's things like not having a lift or a bleeding kit that made me go out and look for estimates. $550 for a 55k service is the lowest I've heard of coming from a dealer. Mine wanted $912, and they said they could only knock off 10% off that...sacrilegious to say the least.
    I think I'll handle the spark plugs and both filters myself, then have my independent mechanic perform the oil change and brake fluid flush.
    Jan 09 2016
    Their kit looks great, only thing that bothers me is the shipping costs. I rather buy filters and washers on amazon, and buy oils at local wally world.
    2021 BMW 540i
    Mar 23 2015
    Colorado
    TTRStud, your S5 calls for plugs @55k (not due at that interval for my 2.0T), so I'd guess that 'justifies' the dealer increased cost over the quote I got, but almost a grand is wicked steep.
    Jul 12 2013
    Jacksonville, FL
    Yes sir, correct on both accounts. My car calls for more parts and labor, but that shouldn't be almost double! Apparently a spark plug change on the 4.2 is not all that simple, since there are some things on the way that need to come out of the engine bay. I had not looked into it, since I usually do my own plug changes and in most of my prior cars (except Porsches) it's usually a walk on the park. There aren't any DIY's for the 4.2 that I could find either.
