Originally Posted by
fast377
It's frustrating there aren't many bearing options for these engines. I built a 403 stroker for a z06 back in the summer, and I had tons of options for bearings. I was able to get the exact clearance I wanted.
Looking at ECS tuning's choices for mains, I see three choices for select fit bearings. Unfortunately, I can't find a chart that says what size each bearing is. Basicly, the factory select fitted the upper mains to optimize the clearance, but dumbed it down to just replacing the color bearing you had with the same one that came out. I would consider buying one of each color to see if it helps. They show Blue, Red and Black. I think black is standard blue red and yellow will reduce clearance. I would love to find a chart with some numbers.
It sounds you're not just trying to meet spec, but within nominal. Personal preference is to hit around .0014", I totally understand what you're shooting for a good build, not i got kind of close, should be OK. On the engine I built for my truck , I had the opposite problem, ( another turbo motor), I ended up sending the crank back for polishing to take it down to bit the clearances where I wanted them. I had the crank cut and polished and sent it out for Ion Nitriding. It was a learning experience and the first crank I ever sent out for heat treating. It turns out the the nitriding process grows the OD of the crank a few tenths (per side), that got my bearings clearances out of spec. The deeper the hardening goes, the more it adds. I ended up gaining about .0008". An extra polishing got me back to where I needed to be. The block had been line honed and the bores were to the tight side of spec. When the tolerance stackups all go one way, you can have problems.
BTW, the crank looked amazing when it was done, I had never seen as shiny bearing journals, with a super hard surface that was a lot tougher and scratch resistant. The machine shop I used was impressed and started sending their cranks to out to the same nitrider. The results was very different than the cranks that were salt bath nitrided. that and the risk of warping is a lot lower. I'm not sure if the VW part is hardened from the factory or not. On my Mitsubishi, it was an option but the factory hardened cranks were no longer available, so I ended up making my own. On that engine, I intentionally set the mains to the low side of spec. It was also on a motor that's know to have oiling problems with the rods so I was being extra careful on my bearing setup. Ten years of hard running and no issues.
I picked up that crank used and had it cut undersized so I could get the journals where to match up with availible bearings.
One thing that I have always struggled with is getting good measurements. Personal experience is that my Mitutoyo dial bore gauge has a bit too much spring pressure for measuring bearing inserts. The contact balls indent the bearing slightly and causes the gauge to indicate that you have more clearance than you actually do. I have had better, more consistent results using snap gauges and a set of mikes. The upside with that method, is its a comparative measurement and not affected by the temperature of your shop or the calibration of your micrometers. Despite have a nice set of bore gauges and micrometers, I still double check with Plastigauge. The bore gauges are great on the cylinders and the bearing housings ( no inserts, good to verify if the big ends of your rods are still round).
Funny thing, if you look at ARPs instructions for using their stud kit with the 1.8t motor, the mention that the increased clamping force of their stud kit will distort the bearing housing, and that it should be verified and probably line honed when converting to studs. That seems to say that you want to have the actual clamping force the motor is going to run with when making your measurements.
http://arpinstructions.com/instructions/204-5402.pdf
http://arp-bolts.com/kits/ARPkit-det...?RecordID=1190
EDIT: See Matt's post below, the stud kit needed is a different part number. :)
