Results 1 to 31 of 31
    Sep 20 2015
    2014 Audi S4, 2014 Mercedes E550, 2011 Toyota Tacoma
    Nokesville, VA
    15,000 mile service - $700-900?
    OK, I'm only at 10,000 miles, but it's been a year since my 5,000 mile service so it's time. I just moved back to the DC area so I'm away from the dealer that sold me the car, which I trusted.
    I called Audi of Tysons Corner, which would be most convenient for me - they want $913.19 for this service. No joke. More than the cost of buying Audi Care.
    I called Audi of Arlington, which advertises a $69.96 oil and filter change, and an $89.95 "executive service" described like this: "Oil change, multi-point inspection, and car wash. Any 5k through 25k service completed in 90 minutes or less, including complimentary car wash and vacuum." They said, no both of these are "just" oil changes, you need the 15,000 mile service. We charge $725.97 for that. I said, but it's just an oil change with some visual checks. They said, well, we lubricate some joints.
    I called a local independent shop that gets great ratings for German cars (and does some motorsports work). They said they'd do the oil change and every check in the official list for $265.00, with another $110.00 if I need a brake flush.
    I like to do my service at the dealer during the warranty period. My last car was an Infiniti - they never charged me more than $150-200. So I'm tempted to just buy Audi Care and go with the most convenient dealer, but I'm not sure if I trust them. WWYD?
    Veteran Member Four Rings schirm's Avatar
    Apr 23 2009
    1999 bmw z3coup M with 5,000 miles Mint
    Forked River nj
    Audi care is nice. Covers up to your 45,000 mile service. The service the dealership does though is a joke IMO, I doubt they even check anything. If did not have Audi Care I would go to a local reputable shop.
    2004 A4 1.8t | Avant | 6MT | Stock | Atlas gray |
    2010 S4 | Ice Silver Metallic | Sport Diff | 6 speed | 19 5-Tri-Spoke Wheels | Audi Drive Select | B&O | Silver/Black Nappa Sport Seats | Navigation Pkg | Brushed Aluminum Trim | APR Stage 2+ | Hoen Xenonmatch Fogs | 034 Motor mounts | Roc Euro | black RS4 Grille |
    Past
    2007 A4 | Revo Sg 2+
    2005 Subaru Legacy GT 365WHP
    Veteran Member Four Rings jygesq's Avatar
    Aug 22 2014
    1986 Honda CH 150 D scooter bought new
    bloomfield,ct
    If you have a DSG car audi care is worth it as DSG service is about $800. You can buy audi car right before for second service. the second service is just an oil change and brake fluid flush. You certainly can get just that from Audi dealer at much cheaper price, but buying audi care before the service is worth it
    2015 S4, P+, Florett Silver,black /silver nappa leather, S-tronic ,sport diff,B&O ,tech package ,supercharged badges. All season tires ,cargo net, factory dip stick
    Veteran Member Four Rings GRUMPY-S4's Avatar
    Nov 16 2015
    DFW
    When is the DSG service due? Is there a list of what each service after 5K entails?
    Apr 23 2009
    Forked River nj
    Quote Originally Posted by GRUMPY-S4 View Post
    Google search
    https://www.audiusa.com/content/dam/...-Year-2015.pdf
    Past
    Veteran Member Four Rings vwblackb5's Avatar
    Jun 26 2007
    New Jersey
    I would tell that dealer to go play in traffic for quoting 900$ for an Oil change and a visual inspection.
    FWIW, I would look at the Service Interval document and highlight the major ticks i.e Oil change, plugs, fluid flush (DSG if you have one), etc and then only ask for those items for your quote. Do not mention "10K" or "15K" service. Most dealers or SA's are robots and only see dollar signs when someone says "15K or 10K service". Bring the checklist to your independent shop if that's the route you end up going with.
    Lucky for me, I was able to negotiate to have Audi Care included on my 16'. Good luck
    Here's a link for MY 2016 https://www.audiusa.com/content/dam/...16_updated.pdf
    16 B8.5: S4 | Premium Plus | Ibis White | PNY | PPS | GH2 | 1BL | Black Nappa | CTS
    99.5 B5: K04-015 / GIAC PC-16 / 315cc Genesis / Custom FMIC / 034 TP / TT Downpipe / Jetex Catback / Forge 007P / ECS AFPR @ 2.7Bar / ABD Tuning Intake / Blinktek Heatshield / Koni FSD / Eibach Pro Kit / SouthBend Stage 2 Endurance OFE HD / 312mm Slotted A8 BBK
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    I did audi care for 15k to 45k. Then they changed it going above that and my SA said he would take care of me. I am 500mi away from 55k and curious what this is going to cost me. Anyone know?
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
    Nov 16 2015
    DFW
    I will talk to my indy shop to see how much they charge for these services. Audi care is 850 I think nowadays. Gets me a loaner though which is nice
    Sep 20 2015
    Nokesville, VA
    DSG service isn't until 35,000 miles. Here's the schedule for 2014 MY: https://www.audiusa.com/content/dam/...-Year-2014.pdf.
    Aug 22 2014
    bloomfield,ct
    35K miles or or 4 years what ever comes first0, that is what my dealer said
    Sep 20 2015
    Nokesville, VA
    Quote Originally Posted by vwblackb5 View Post
    Good idea. As far as I can tell, generously, the list is:
    -Oil and filter change
    -Check coolant
    -Replace dust and pollen filter
    - Check and clean plenum drain
    - Check brake pads and fluid
    - Reset service reminder
    My biggest issue is that I don't trust them after quoting more than $900.
    Oct 09 2008
    Quote Originally Posted by chazas View Post
    -Check coolant
    That's a lot of dough for an oil and cabin filter change.
    The Awesome™
    Veteran Member Four Rings pdqgp's Avatar
    Mar 06 2015
    a 12 Second boat, & Wife's Lincoln
    Columbus, Ohio
    Cabin Air Filter is easy. 3 screws and about 5 minutes. I just did mine this week.
    https://youtu.be/LGMKyCaErPA
    2018 Midnight Black Metallic AWD Infiniti Q50S Red Sport | Burger MS JB4 | 395awhp/430awtq
    2018 Ruby Red Metallic Lincoln MK-C Reserve | AWD 2.3l EcoBoost - Wife's
    2014 Brilliant Black S4 | S-Tronic | 187mm APR Stage 2 Dual Pulley & APR TCU Tunes | APR CPS - SOLD
    Sep 20 2015
    Nokesville, VA
    Thanks - the air filter looks easy enough, but I'm mechanically challenged. I called back the Tysons service department and asked them to quote me just oil/filter change, cabin filter change and resetting the service indicator. They quoted $150 (!) for the oil change, $187 (!!) for the cabin filter change, and $70 (!!!) to reset the indicator. Audicare, including tax, was $862.16. Buying it and done. And my car clearly will go nowhere near a dealer for any non-Audicare, non-warranty service....
    Mar 06 2015
    Columbus, Ohio
    You can't really f-up a filter install. Very worst case you could take it to an instant oil change shop to replace the cabin filter (let the flames come at me) but really, you can do it. An oil change.....I'd find a local shop that works on or specializes in German cars and call them. There's nothing difficult about the Audi Oil Change. It's pretty straightforward.
    Mar 21 2015
    You can change the cabin filter now yourself and the dealer can give you the new one to take with you so you can have it to change sooner. It really only takes 10 minutes at the most and you can get one cheap on Amazon.
    Sep 20 2015
    Nokesville, VA
    Thanks, folks. I did get a quote from a good local shop, which will get my business when the warranty is up. They were much less expensive than the standalone dealer quotes, but they weren't cheap - Audi Care is a better deal.
    Veteran Member Four Rings BoostEasy's Avatar
    Aug 07 2013
    2014 S5, S-tronic
    NE
    Audicare is a good deal if you keep the car or it's older and you need the DSG or other more major service. For me, I won't keep the car long enough to hit the DSG service so it wasn't worth it for the oil changes. I do my own oil with the mityvac topsider. No regrets and ultimately easier vs dealing with the dealer for me.
    I generally avoid the dealer if I can and I've had the car for about 26months now, never seen the dealership for anything.
    2014 S5 S-tronic. Phantom Black, 19" AG M590s, Akebono Pads, OEM RS5 Grill, Alu-Kreuz, Black Alcantara, MMI, Quattro Sport Diff, B&O sound, side assist.
    2011 335xi (gone)
    2008 335xi (gone)
    Veteran Member Four Rings B8 S4's Avatar
    Apr 27 2014
    United States
    Why not do the oil change yourself, its one of the easiest things to complete on a car. Save yourself $700
    2013 B8.5 S4 | APR Stage 2 + DSG Tune | APR CPS | AWE Touring + Downpipes | RocEuro | H&R Coils | J-Codes | 15% Tint |
    435I 6MT - Daily
    Jun 26 2007
    New Jersey
    Quote Originally Posted by BoostEasy View Post
    Sounds like you have a lease.. AudiCare adds 1% to Residual value, so it's worth negotiating for it (if you can).
    Veteran Member Three Rings VenturiRS's Avatar
    Dec 27 2008
    Quote Originally Posted by cspcrx View Post
    What is this change you speak of? They changed the price of the 55,65,75 Audicare Package?
    B8.5 Estoril Blue S4 | P+ | DSG | SD | ADS | B&O | CF | Nappa | Advance Key | CF Badges
    Jan 04 2013
    Phoenix, az
    The packages so the savings is not what it used to be.
    Veteran Member Four Rings xuandatou's Avatar
    Oct 17 2012
    NoCal
    the drain plug washer must be made of gold (100th anniversary edition 1 of 5 ever made...)
    2013 S5 Build Thread
    2001 S4 Avant
    2017 Ducati Monster 821
    Instagram
    Gone but not forgotten:
    2011 Q5 2.0T
    2011 A5 2.0T
    2013 S5
    2007 A6 3.2
    Veteran Member Four Rings audistealth's Avatar
    Mar 04 2012
    2012 Audi S4, 2017 Explorer Sport
    Check in the Mid-Atlantic chat thread here. There are a few dozen guys on AZ that could help. A lot of us use Audi Silver Spring. Call ahead and you should get a complimentary loaner.
    I also bought Audi care because of a ridiculous 15k mi quote. Basically, it was a push.
    /// 2012 S4
    RocEuro Intake | AWE/GIAC Stage 2 | 19" Titanium Rotor Wheels 10mm H&R spacers | RS5 BBK & ECS 2pc front/rear wave rotors | Renn RS-51 19x8.5 20.5lbs | JHM LW/HD Pulley | MMI 3G+ rev. G and controls retrofit | vagcom stuff | Jokerz ported coated supercharger | KW V1
    Mid-Atlantic Forum (MD/DC/VA)
    Aug 07 2013
    2014 S5, S-tronic
    NE
    Nope. It was a buy. I just don't drive a lot- about 8-9k a year. So it will take me around 4 years to hit the 35k for DSG service and I only planned on keeping the car for about 3.
    I was aware of the lease residual bump for AC but Audi leases when I bought were so terrible they'd have to do a much better residual to make it worthwhile to me.
    2011 335xi (gone)
    2008 335xi (gone)
    Apr 19 2014
    Long Island
    Quote Originally Posted by VenturiRS View Post
    Yeah I haven't heard anything about changes to audicare
    Mar 21 2015
    Quote Originally Posted by homelessNY_LI View Post
    I think with those 3 upper services they now charge for each service instead of bundling it together.
    Junior Member Two Rings
    May 02 2008
    Home Gym! & 2017 Grand Cherokee Laredo Altitude
    Houston, TX
    For those doing the milestone services outside the stealership, are there any concerns if something happens to your car and then you bring it to the dealership. Can they claim that because you haven't been doing the services with an Audi dealership they might not cover something under the warranty?
    I do the same as others here, I take it to a reputable, well known, Audi shop - not the stealership. Unless I have absolutely no other option (very rare). I am sure it is the same on other states, where you will find good shop outside the dealership, basically consisting on a super good technician that worked at a dealership for a long time, now he has his own shop, uses the discounts/costs from the stealership and has all the good contacts - performing a way better job at a way lower cost than any dealership. Plus they actually car about your car and tell you the truth, no BS.
    S4 2014 - Sold A4 2008 APR STG1 VMR H&R
    Apr 19 2014
    Long Island
    Yeah audi care select changed
    May 02 2008
    Houston, TX
    For OP, I had my 15K service done about a month ago. Called 3 different dealership. They gave me 3 "packages" from $350 all the way to $700. Good luck with that. I had it done for $165 at a local specialist Audi shop. Same service, same everything, better price. I guess the only down is that you don't get a loner(?).
    Apr 05 2014
    Dear burglars, that price is unreasonable to say the least. That's what I would tell that dealer. And find a better dealer to deal with.
    I go to dealer for oil change only (still high but it's a business deduction and I get loaner). No mile marker service scams for me. For 35k I did cabin and air filter myself (get a torx screwdriver) and reset interval using carista.
    If you look in the manual it says something like "the engine in your luxury car is a high performance state of the art design that requires only the most skilled mechanical expertise to service" or some other kind of bullshit.
