Results 1 to 37 of 37
    Established Member Two Rings volkswagensRus's Avatar
    Nov 19 2015
    Buffalo, NY
    $600 to replace 2 control arms/ball joints
    Long story short. Took the car to the local TRUSTED shop for a squeak on the front left, and a BANG on the front right. Guy said it needed ball joints/control arms. The right side needed I believe a rear, the left side a lower front. He quoted me $441+ tax. I get the final bill, $600. He quoted me $200 per control arm. Plus ~$148 labor to install them both. I'm infuriated. Should I be?
    2001 Audi A4 Hibiscus Red Pearl Metallic , quattro, 5spd, Symphony stereo, winter package, 3" 034 catless DP, 2.2" exhaust, white snub nose mount.
    For Sale: 1x oval Borla muffler + piping. 1x rectangular Borla muffler + piping. 1x B5 A4 cat+o2 sensor + wiring.
    FOR SALE: 2 catalytic convertors (one w/ both o2 sensors), Audi B5-a4 cat-back exhaust Borla muffler+resonater
    Veteran Member Three Rings LA4's Avatar
    Jun 16 2013
    E39 540i, NA Miata
    Pennsylvania
    Depends. If he used genuine OEM parts, then $200 per control arm sounds about right for Audi. If he used aftermarket parts then you got boned.
    Why go to a shop for a simple job like a control arm? The uppers I can see being a bitch with the pinch bolt but the lowers are pretty easy.
    1998.5 A4 Quattro 1.8TQM AEB
    Stage 1 GIAC, 710N DV, ECS Snub Mount, ECS SS Brake Lines, A8 Rotors, Bilstein Sports/H&R Springs
    Apr 01 2011
    B5 on jack stands
    charlotte
    You got screwed....
    powered by
    Hot Boi parts
    Stage 2 Banner Advertiser Four Rings Hugh@EuropaParts's Avatar
    Aug 22 2010
    Piscataway, NJ
    Quote Originally Posted by volkswagensRus View Post
    $200 per control arm? We sell an entire 12 piece Meyle HD Kit for $500.00 shipped.
    TL;DR I'd be furious...
    CONTROL ARM KIT (B5/C5, 12-PIECE, MEYLE HD)
    Hugh
    EuropaParts.com, Your Trusted Audi Parts Source
    Facebook: Like Us on Facebook
    Instagram: Follow Us on Instagram
    Nov 19 2015
    Buffalo, NY
    Quote Originally Posted by LA4 View Post
    I'm "OK" with cars... I can do brakes, turbo swaps, head swaps, etc... but ball joints and control arms I've never really messed with. I'm not sure if they are OEM or aftermarket parts. I've heard the uppers are easy but the lowers are a real bitch though. He only charged ~$148 in labor. My good buddy tells me AFTER I start getting the work done he's got the pieces I need for like $180 and he'd install for $100. He said he'd be outraged and wouldn't pay it.
    Veteran Member Three Rings VAGlover's Avatar
    Sep 23 2013
    b6 a4 track rat
    boston
    i bought a kit from a regarded supplier who i shall not name. long story short, i'm replacing all my 1 year old control arms from "regarded supplier" with oem ones. as a vw tech, i do get a discount from audi but they are still expensive. i just spent around 160 for a lower ca. ive been doing this alot with all the aftermarket parts i've put in my car. other than performance parts, keep it oem.
    Jan 30 2007
    2014 Lexus IS350, 1988 Porsche 944, 2008 Porsche Boxster, 2001 Audi TT Quattro
    Greenville, SC
    So the labor sounds reasonable to me. If he truly only replaced 2 upper control arms (of the 4), then $400 for those two sounds steep, even for Audi OEM. E.g. I've seen a whole set of upper (4 arms + hardware) Audi OEM for $550.
    Tom
    2014 Lexus IS350 (present), 1988 Porsche 944 (present), 2008 Porsche Boxster (present), 2001 Audi TT Quattro (present), 2006 Audi S4 (past), 1998 Audi A4 (past), 1975 Audi Fox (past)
    Mar 08 2015
    pa
    https://www.fcpeuro.com ball joints and control arm kits
    Veteran Member Three Rings Wrath And Tears's Avatar
    Apr 03 2014
    17 GTI Sport
    Head swap is like 100000000x harder then control arms. The hardest part of control arms is tightening everything when the car is at droop. Which can be done with a set of car ramps.
    OEM parts are always better, but I'd rather spend a third the money and go aftermarket. As long a the dealer stands behind their product and the warranty is good (like the lifetime from FCP) then I'd rather replace the part a few times and still pay less then OEM. But I have a rack to do all my work on.
    2017 MK7 CSGM GTI Sport DSG
    PP (Golf R Brakes, +10HP, VAQ LSD), LP, Kessey
    LW 17" Sparco Assetto Garra's, 034 Res-X resonator Delete
    Veteran Member Four Rings xalents23's Avatar
    Oct 26 2011
    CA
    All I got to say is
    Jun 16 2013
    E39 540i, NA Miata
    Pennsylvania
    Dude if you can do a head swap you can totally change a control arm. They come as a complete unit so you aren't even pressing out bushings or anything.
    It's basically one bolt and one nut that need to be removed. There are guides and youtube videos everywhere. I've done them and I'm a complete fucktard.
    Jun 16 2013
    E39 540i, NA Miata
    Pennsylvania
    Quote Originally Posted by VAGlover View Post
    Do you really think it's worth it though?? I've done the math and OEM just seems like a complete waste of money.
    The FCP kit is $300 (currently on sale for even less!) For all 8 control arms, outer tie rods, and sway bar links, plus all the hardware. With a lifetime warranty.
    For OEM: If we say $125x4 for the uppers, $160x4 for the lowers, $200 for both sway bar links, and $200 for the tie rods, that's over $1500 total. Those are all conservative estimates to keep this fair since I have no idea how big your dealer discount is.
    Is the OEM part better? Sure. But for me it certainly isn't worth 5x the price. You want to use OEM more power to you, but I'd hardly recommend someone spend $1500 in parts when there is a perfectly acceptable solution for $300. That's just my $0.02, but I'm also really effin' cheap.
    Sep 23 2013
    b6 a4 track rat
    boston
    Idk when you have to replace contrrol arms every 3 months it becomes worth it.
    I'm lowered but just 25.5gtf, and have brutal winters here, but these aftermarket parts don't take to it very wheel
    Sent from my VS985 4G using Tapatalk
    Jun 16 2013
    E39 540i, NA Miata
    Pennsylvania
    First I've heard of someone replacing them every 3 months. 15k miles on mine without any issues. Probably other people on here with way more miles on them.
    Apr 03 2014
    17 GTI Sport
    Idk when you have to replace control arms every 3 months it becomes worth it.
    I can tell you if your aftermarket parts are only lasting 3 months you are messing up the install, guaranteed. That being said its always possible to get a lemon even from the dealer, and some aftermarket companies release terrible quality products.
    Example: My correctly installed super cheap aftermarket control arm is still doing good 10 months later. However my OEM one died a tragic death in 5k miles (2/3 months) due to a manufacturing defect in the ball joint or something. $20 arm versus $120.
    Orange County, CA
    Quote Originally Posted by Wrath And Tears View Post
    I can tell you if your aftermarket parts are only lasting 3 months you are messing up the install, guaranteed. As a tech who installs aftermarket parts on cars day in and day out and have a 2 year 25000 mile warranty on those parts, I know what I am talking about. That being said its always possible to get a lemon even from the dealer, and some aftermarket companies release terrible quality products.
    Agreed.
    B5 Parts For Sale
    Sep 23 2013
    b6 a4 track rat
    boston
    I put 25k a year on my car. I'm a dealer tech, pretty sure I'm installing them correctly. All my issues have been with aftermarket parts.
    Jun 16 2013
    E39 540i, NA Miata
    Pennsylvania
    How are they failing within 3 months (roughly 6k miles with how much you are apparently driving.)
    The bushing deteriorating, ball joint cracking open? I guess I just find it hard to believe that these arms are failing again and again and again.
    Sep 23 2013
    b6 a4 track rat
    boston
    All ball joints. And 3 months was an exageration, the first one failed 9 months after install. Them a couple others failed shortly after.
    Nov 03 2011
    All Over!
    If those arms were genuine Audi, then the overall cost is fair.
    I only fit control arms from Audi. They cost a whole lot more, but having used the aftermarket garbage out there, (yes, including Meyle) I would rather fit genuine items that last ages.
    Than have to replace the same items from the aftermarket, on a regular basis, regardless of warranty. My time is money, and I'd prefer to use it elsewhere.
    1986 Type 85 Audi 90 quattro
    Apr 03 2014
    17 GTI Sport
    This is a joke...hopefully but stop tightening the ball joints with an impact gun. Coworker who was a VW/AUDI dealer tech saw plenty of people destroy ball joints and stuff with an impact gun. I figured it was the bushing failing due to not being installed properly, but if it was the ball joints that does speak to the quality or lack there of. Can you say what company you had issues with? I'd be interested to know.
    Senior Member Two Rings FeebleBiscuit's Avatar
    Mar 30 2014
    2001 S4
    MI
    Well if you use valco arms then every three months you have to change them. But you also only paid 225 for the set.
    https://www.ecstuning.com/Audi-B5_A4...its/ES2609119/
    Vs
    Meyle 600
    https://www.ecstuning.com/Audi-B5_A4...m/Kits/ES3005/
    I bought the Meyle kit 2 years ago 20k miles and I've been to 10 track days on them and all is well. I'm not about to pay 1500 for some control arms.
    Audi
    https://www.ecstuning.com/Audi-B5_A4...its/ES2661077/
    Nov 19 2015
    Buffalo, NY
    So the labor charge, ~$148, was VERY fair I thought. No contest there. But the shop, who I've used on NUMEROUS cars and always had excellent luck with, said they bought the control arms right at $200/piece. He said he couldn't get them directly, and "had to go through a place that went through a place". He wouldn't say what brand they are, but didn't think OEM audi. They have a lifetime warranty. They are both lowers, not uppers.
    EDIT: Ohh ya, and the shop guy is saying he quoted me at $551+ tax originally, not $451+ tax. I know what I heard. If I heard $551+tax I would have taken it home and parked it.
    Senior Member Two Rings nemick's Avatar
    Aug 22 2012
    Indianapolis, IN
    Chances are they totally underestimated the labor if the pinch bolts were a bitch. Probably just jacked up the price of the parts to cover their ass. Still sucks and I'd be pissed.
    Neil M.
    2004 allroad 2.7T TIP
    2001 A4 1.8TQ, TIP
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    The Excalibur bolt alone can be that much if things get sideways.
    Buffalo makes me think you got to pay the salt surcharge.
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesn’t move and it should - WD40.
    Jun 30 2008
    Erie, Pennsylvania
    I've had 4 FCP uppers in my car for 100k miles. No problems. My brother has the same on his A4, but he did have 1 fail. FCP replaced it for free - no questions.
    My lowers are genuine Audi because they had a closeout sale on the 4-piece lower arm "kit" for like $50 way back when. Couldn't pass that up!
    Feb 27 2011
    Winnipeg
    Quote Originally Posted by nemick View Post
    He said both lowers.
    For being arms sourced locally I'd say that's the price you pay, you always pay more for parts sourced by a shop, and around here no shop will install parts you bring them for warranty/wrong parts/low grade crap parts.
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Why the fuck you brought it in, I will never understand. The only times my cars see the inside of a shop is to have an alignment done.
    If you can't replace a suspension component, learn how to. For $600, I would just go buy another B5.
    2020 SQ7- Wife's ride
    2000 S4- Working?
    Veteran Member Four Rings Turbo_B5's Avatar
    Oct 09 2012
    abunch of useless shit
    Notnomde Atrebla Adanac
    x2, expecially the end part.
    EH F0UR 2001 A4 1.8TqM
    = Parked cause its junk.
    2002 Golf TDI
    = FASTER THEN YOUR B5.
    2018 Suzuki GSX-R750
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    1997 A4 1.8TqM SPORT
    @Turbo_B5
    Sep 23 2013
    b6 a4 track rat
    boston
    On the contrary, I do want to put adjustable uppers on when the current ones fail.
    Those are $.
    Nov 19 2015
    Buffalo, NY
    Thats interesting, and believable in the context that you put it... but when he's claiming he NEVER said the estimate was $441.... he's saying he always said $551+tax. Thats bullshit because that that price the car would have sat at home.
    Quote Originally Posted by zillarob View Post
    LOL! True that. Fortunately the Audi's and Volkswagens I've had, have held up VERY well in regards to not rusting.
    Quote Originally Posted by redline380 View Post
    Don't know. I've just never really done suspension work is all.
    To add more to the story. Been speaking with a good buddy of mine who's a Audi guy; lots of s4's, a4's, Volkswagens etc. He said his brother used to work at said shop, and that he quit because they were cheating customers.
    So I got to thinking. My GF took her WELL maintained acura in for a noise, and they gave me the same line. It's a balljoint about to let go.... and when she had it replaced it just "fell out" when they loosened it up. They also quoted her ~$500 to fix the drivers side window motor + regulator as it was acting funky. Took it apart, it was just a rubber seal that was imploded and making it hard to go up/down.
    Another thing. The banging noise is still present on the passenger side front. The guy said it's because whoever installed my struts over tightened them, and they are basically bottoming out and hitting the strut plate when I hit bumps. He said take it back to him. The WHOLE reason I took it in was because the drivers side squeaked (fixed) and the passenger side banged loud on bumps.
    Apr 03 2014
    17 GTI Sport
    Yeah... find a new shop. That's pretty scammy.
    Our shop charges about $150 to R&R the door panel and diag the issue (That's about 1 hour of labor, we are right in the middle labor rate wise for our area, 130-170) Most door panels are like 4-6 screws and some trim panels. $500 is extreme unless it also included replacing a window regulator (parts and labor).
    Nov 19 2015
    Buffalo, NY
    The price of $500 to replace the window motor + regulator on her acura was for everything involved. The motor and regulator are one unit. The kicker is, I can find the motor + regulator for $50 on the low side to $100 on the high side. They said majority price was parts. BUT BUT BUT, the motor was fine.... the reason the window had issues going up/down was due to a rubber piece that fell inside the track. The motor was fine. Makes me wonder if they even opened up the door panel...
    Jun 16 2013
    E39 540i, NA Miata
    Pennsylvania
    It would be cool to have a "trusted Audi shops" by location thread or something.
    I try to avoid taking my car in for anything, but when going for alignments, inspection, etc. it would be comforting knowing that it's an honest shop who knows how to work on VAG cars. I've had my car for around 5 years and still have yet to find a shop that I 100% trust.
    Senior Member Three Rings wolfe2118's Avatar
    Apr 09 2012
    Fort Wayne, IN.
    As an VW tech, you also have a financial interest to keep people coming into the dealership. That's kind of like Ronald McDonald saying "salads really don't fill you up so you had better play it safe and just buy a Big Mac so you aren't hungry again in an hour". Had you left out the VW tech part, there would be no question as to your motives.
    Jun 16 2013
    E39 540i, NA Miata
    Pennsylvania
    Quote Originally Posted by wolfe2118 View Post
    Meh, I completely disagree with his point on using OEM parts (see my post above) but I don't think him being a VW tech has anything to do with it. Let's be realistic, how many B5s are still finding their way into the dealership? It's not like Audi is giving him a cut of every control arm sold for a 20 year old chassis.
    Also, Mcdonalds sells salads and they are actually more expensive than the sandwiches.
    Sep 23 2013
    b6 a4 track rat
    boston
    I'd rather put in a quality part than have a customer come back a year later to replace said part. Not to mention alligning it again.
