Results 1 to 25 of 25
    Veteran Member Four Rings AudiTechS4's Avatar
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    high rpm shifting problem
    A buddy at work has a 2001 s4 w/ rods and k24's and built heads. He installed a spec clutch/flywheel kit when he installed the engine about 3k miles any thing above 6k rpm its hard to shift . so he pulled the trans and performed the jhm synchro rebuild kit to the trans. Same issue. Any thoughts ? what we did notice was the clutch disc to flywheel has almost 0 play around the outside of the disc to the step of the flywheel. maybe its hanging up...
    2001 Audi S4 Manual - Nogaro Blue/black - Full AWE stg 3 kit w/ manifolds,h&r coilovers,jhm trans rebuild,UUC VM3 exhaust , 2.5" dp's - Needs Love - Got some love now 442awhp and 512 awtq
    2004 Audi S4 Avant manual - Silver/black - 2.7 swapped ,k24's and srm side mounts
    Sep 11 2009
    NE
    That would make some awful noise, I reckon, and quickly grind to clearance anyways. Now, if he wanted to shift quick, he would have to go with some lightweight clutch disc (6 puck), not a full face one, as that's what dictates how quick can synchros speed up/Slow down to allow for shift.
    Anyway, define "slow". When shifting from 1st to 2nd from 6k rpms, the tranny needs to drop about 1/2 of the RPMs in split second, that's not going to happen quick with normal weight clutch disc... 2nd to 3rd is much better since the amount of RPMs to drop is much lower. The time is basically dictated by gearing ratio differences between gears and what RPMs this take place at.
    Aug 04 2013
    Pennsylvania
    My 1-2 shifts are pretty slow, and get slower the higher the RPM's climb. Idk if it's normal or not but I've given up for now. I understand that a full face clutch is heavier and the rpm's dropping and everything but idk. It was never so bad with the stock clutch. I really haven't driven many manual b5's but I've driven a lot of b6 and b7's and I can shift pretty fast without issue in those.
    Initially it was just about impossible for me into any gear at high rpm and it turned out the pressure plate bolts came loose. A cracked pressure plate could cause the same symptoms but I'm sure you examined it closely.
    As far as my own issue is concerned, I think maybe I drove it too long with the pressure plate bolts loose (took awhile with me replacing the clutch slave and master before realizing it must be something with the clutch) and knackered the synchros in my rebuilt transmission
    I'm like a tree. I'm all root
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    Ok the 2-3 shift is slow as in anything above 6k rpm it wont come out of second gear. so if he revs it out to 8k he has to wait till rpms hit 6k befour he can get it out of 2nd and then it shifts into 3rd
    It was slow this morning on the freeway and he did a 3rd gear pull to 7500 and shifted into 4th just fine so its a 2-3 shift. so we did some talking and got some better info
    Original problem - shifting into a higher gear like 2-3 or 3-4 it came out of gear just find but couldnt get it into the higher gear easy. so he did the jhm shift collar and carbon synchros kit (had 1/2 collar lock up) now it seems that hes only having an issue getting out of second gear at a high rpm.
    Veteran Member Four Rings jaychen's Avatar
    Feb 19 2011
    Earth
    Quote Originally Posted by AudiTechS4 View Post
    call Scotty @ advanced.
    he knows 01E's extremely well.
    2000 Achat S4
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    well he pulled the trans back out swapped in the dual mass and all is well. he talked to ecs and they told him only way to get any kind of refund is the send them the entire clutch kit meaning he has to but a new clutch kit and hope he gets a full refund.
    so the clutch disc to flywheel clearance was not enough causing the hang up on shifting.
    Oct 17 2009
    is attached to my house.
    alonE, Pa
    Single flywheel will lock you out at high rpm. I had similar problems on my A4 at the track and it wouldn't come out if gear til nearly 5500 and by that time it would be out of its powerband and need to build boost for the following gear.
    I had less problems with a track density diff mount. Oh. I also broke a trans mount bracket that day as well.
    '02 1.8TQ - Daily sold
    '05 Colorado Z71 Crew Cab
    STEVE
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    I don't see how a singe mass flywheel locks you out of high rpm shifting. This was a case of a machining error
    Feb 05 2014
    BROOKLYN
    The clutch disc was too thick!
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    No the clutch disc is not the problem . if you read what i wrote you can see there the disc is grinding into the flywheel surround. there was almost no wiggle room for the disc
    Feb 19 2011
    Earth
    thanks for posting the cause. clear case of incorrect tolerances. if they don't offer a refund for that I would be going to the ombudsmen (not sure if you have that in your state).
    2000 Achat S4
    Veteran Member Three Rings themadscientist's Avatar
    Oct 10 2010
    Las Vegas
    In the future, if you're trying to differentiate between a synchro and clutch issue, put it in 1st, clutch pedal all the way down, on a perfectly level or slightly downhill surface. Rev it out to redline. If the car creeps forward, even the tiniest bit, you're clutch isn't fully disengaging.
    2005 A4 Avant 1.8t QTM
    Senior Member Three Rings audi-hammer's Avatar
    Aug 28 2009
    Buffalo,NY
    Hmm good to know. Had an issue with a spec clutch grinding gears when revving past 5k and trying to shift into 2nd or 3rd, thought it was the trans at first
    Quote Originally Posted by themadscientist View Post
    Silvia = 02 s4 stageIII
    Nov 04 2013
    stg 3 widebody, 1990 miata, '05 gsxr 1000
    Palo Alto, CA
    glad you sorted it. I'd buy a new kit, and expect a refund (can't imagine they'd be so stupid as to send out clearly incompatable parts and not refund it, assuming both pieces were from ECS and ordered together). I would also be extremely pissed, if they give you any flack on it. Manufacturing defect is one thing, but this looks like it was straight up misengineered -- I would argue there's grounds for them paying for labor as well.
    There are absolutely zero issues associated with my single mass aluminum Fidanza flywheel. been running it for 6 years, love it. $150 to put a brand new wear surface on it is all I've had. Zero chatter with b5 rs4 clutch, some chatter, especially cold, with a pucky race clutch i've got on it now.
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    he talked with spec today - found out they had the wrong disc in the clutch kit. they wont pay for labor but said they can send him the correct disc. meaning they flywheel is all jacked up still and he would have to pull the trans again. I'm pissed off and its not even my car. They are going to gt back to him tomorrow for the final stand by spec. Ill keep you updated
    Feb 05 2014
    BROOKLYN
    Who ever put the clutch in the car should have partial blame. He should have noticed that the disc didn't fit properly. "I still think the disc was to thick".
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    Well you would still be wrong because it works perfect in the stock flywheel that has more radial clearance. Why are you not banned yet.
    He put the clutch in . The disc isn't a press fit into the flywheel it had about 1mm of clearance all the way around the disc. the disc they gave him was .1" to big they gave him a 9.5" disc and it should have been a 9.4" disc.
    Feb 05 2014
    BROOKLYN
    I'm going to assume that you are a man! If this is so, why are you so bent on me being banned. I'm almost certain it's because you hate that I am a better car enthusiast/mechanic than you. I still love you though. It's a new year. If you ever need any help, please don't be afraid to call.
    Nov 02 2014
    06 9-3 Aero 2.8T, 96 Miata
    Winchester, VA
    Quote Originally Posted by WESLIFE View Post
    Proof?
    Feb 19 2011
    Earth
    faw is still jacked up about his 600whp car running 105mph on the big end.
    2000 Achat S4
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    Yes you're far better then me in every way,I've just been a master guild audi tech for 10 years. Just look at your last 20 posts . they really show how much of an enthusiast you are. Weird you talk alot of shit but never post up your sweet whip. Let's see that pile of shit you call a car that you made in a shed! Please post another video of it barely making it down the qt mile.
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    Quote Originally Posted by DieselElectric View Post
    Proof?
    You won't find it . he just talks shit. Hes a bitch , complains and talks shit about everyone else's stuff but never posts hisown.
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    update - he sent the flywheel to spec and they issued a refund to the distributer (not ecs - they are not a distributer of spec) So my buddy contacted ecs and told them spec issued a refund for the flywheel to the distributer. they need to contact the distributor and get the refund for him since they purchased it from the distributer. they guy at ecs doesn't want to help at all it seems like. I cant remember his name , josh or something with their warranty department. hopefully they can get it handled . maybe ECS will chime in
    Established Member Two Rings JaredB5s4's Avatar
    Jan 12 2016
    Kitchener Ontario Canada
    Roasted
    Veteran Member Four Rings Zba's Avatar
    Nov 05 2009
    Denver
    WESLIFE = entertainment
    We'd all be sad if he/she/it left, admit it
