Results 1 to 3 of 3
    Senior Member Two Rings drmonkey's Avatar
    Sep 04 2015
    Clear Lake, TX
    2008 Audi A4 Quattro S-Line *sTaSis Package* - Houston, TX
    $12,000
    101XXX miles
    2.0 Quattro
    Current Lien on the title
    Email - [email protected]
    Phone - 713-384-0308
    I'm selling the car as I no longer want the car payments (selling another car as well) and trying to get rid of debt. Car runs perfectly though it could use an alignment but a full alignment would require adjustable control arms. It is time for the maintenance to be done as well.
    - sTaSis ECU
    - sTaSis Exhaust
    - sTaSis 19x9 wheels with 255/30/19 size tires (rear tires are brand new from Tirerack, Fronts are - still in good shape)
    - Lowered on lowering springs (not sure the brand as this was done before I bought the car)
    - Audi R8 coils and NGK spark plugs
    - APR Snub mount
    - AUX in cable for the Symphony II radio - Needs to be programmed with a VAG-COM to work
    - Oil change done with Mobile Synthetic Euro Car Forumula 0W-40.
    - Cam follower changed with oil change - Old one was still in decent shape
    - Checked the Diverter Valve and even though it's the older version it had no tears and was in good shape
    Cons
    - TPMS light is on - The rear passenger sensor is broke (you can hear it when driving slowly)
    - CEL came on for coolant sensor/thermostat - it was for a P2181 - the car has been running cold on the gauge so I'm assuming the Thermostat is stuck open. The light has since gone off in the past couple days
    - The flex pipe was torn up so I cut it out and clamped in a new one but it makes a whistle at higher RPM's. It just needs to be welded in.
    - It's due for routine maintenance (timing belt, water pump, etc.)
    - The usual broken glovebox (I have the repair kit)
    Pictures
    I will upload more later
    Disregard my smoker...
    Senior Member Four Rings JDillon15's Avatar
    Jul 11 2014
    Chicago, IL
    Cool car. Definitely time for some maintenance.
    Moro 06 A4 Quattro| Totaled
    Silver 06 A4 Quattro | Sold
    Legal Advisory for Mec's Cabinet Dec 2014-Present
    *Advised the shit out of legal situations
    *Succeeded like never before and rose to the top like a phoenix from ashes
    *Can Take a ZJ with a poker face
    Sep 04 2015
    Clear Lake, TX
    Bump. More pictures are coming!
