Results 1 to 8 of 8
    Senior Member Two Rings tomahawk297's Avatar
    Jul 25 2014
    Mississippi
    Angry Headlight leveling sensor bolt broken off.....
    So apparently I have over tightened the bolt to the headlight leveling sensor and broke it off smooth, any ideas here? The frustration of working in the rain makes me break things
    Oct 16 2008
    South Florida - Ft Lauderdale
    Drill and tap a new hole
    Phil
    Jul 25 2014
    Mississippi
    Phil
    Problem is a drill won't fit back there.
    Oct 16 2008
    Quote Originally Posted by tomahawk297 View Post
    Small one pneumatic should
    Phil
    Oct 24 2015
    Perth, WA
    so is that just two pieces of plastic you want back together?
    My respray thread
    Dec 23 2011
    Mine broke a while back. I just glued it together
    Jul 25 2014
    Mississippi
    Quote Originally Posted by Okedokey View Post
    No it's the metal mount on the sensor that needs to be bolted to the metal, no plastic. I might just clamp it down and try some kind of glue. Any recommendations as far as gluing goes?
    Oct 24 2015
    Perth, WA
    My respray thread
