Results 1 to 13 of 13
    Junior Member Two Rings
    May 02 2008
    Home Gym! & 2017 Grand Cherokee Laredo Altitude
    Houston, TX
    Need help with tire
    Hey guys, just found out this morning about this weird nail in my rear right tire. So far no air is coming out of the tire - car is actually at the dealer right now getting the windshield replace - so I will know later today if air is getting out during the day. My question is, if I just pull the nail out and no air comes out, would you leave the tire in there? or you would still replace it? tire still pretty good 6.5-7 thread left. Tire is Hankook Ventus V12 255/35/19.
    subir fotos
    S4 2014 - Sold A4 2008 APR STG1 VMR H&R
    Established Member Two Rings kr3w45's Avatar
    Mar 19 2014
    02 a4, 06 a4, 09 a4, yamaha r6
    Boston, MA
    Quote Originally Posted by B7Audi2.0T View Post
    subir fotos
    You must have a slow leak with the nail left in. You can't really repair the sidewall like that. If it were my car I would play it safe and replace the tire
    Automate your Dealership: www.DealerScience.com
    Automotive Technician @ Amherst Autoworks
    B7 A4 - Frankenturbo F23L
    B8 S4 Stage 2
    Veteran Member Four Rings Johnnycash's Avatar
    Jul 31 2014
    2015 Hyundai Genesis. 1995 impala ss
    Mpls, Mn.
    take the nail out and put soapy water on the puncture, you will find out asap if its leaking.
    2011 QGM w/black optics, EPL stg1, HRE p43sc w/pss, b-12pro-kit, 034 trans mount, cts intake, stoptech drilled/slotted, akebonos all around, vmr 710 w/nokian r2s, stock rotor wheels w michelin as3+, autostyle custom floormats, 3m paint protection on entire front.
    Established Member Two Rings djkyky's Avatar
    May 27 2015
    24 Audi Q3
    Estero FL
    The nail probably damaged the cord and as mentioned the sidewall cannot be patched or plugged. If the core is severed it will weaken that area of the tire. My advice is bite the bullet and get a new tire. High speed tire blow outs while exciting are dangerous. Been there.
    Veteran Member Four Rings pdqgp's Avatar
    Mar 06 2015
    a 12 Second boat, & Wife's Lincoln
    Columbus, Ohio
    time for a new tire. I wouldn't ever consider leaving it on my car. Everything rides on your tires.
    2018 Midnight Black Metallic AWD Infiniti Q50S Red Sport | Burger MS JB4 | 395awhp/430awtq
    2018 Ruby Red Metallic Lincoln MK-C Reserve | AWD 2.3l EcoBoost - Wife's
    2014 Brilliant Black S4 | S-Tronic | 187mm APR Stage 2 Dual Pulley & APR TCU Tunes | APR CPS - SOLD
    Feb 04 2014
    Dino GTS
    Seattle & Scottsdale
    Can you replace just one tire in a Quattro Audi?
    I thought you have to buy a set
    Mar 06 2015
    Columbus, Ohio
    Quote Originally Posted by PerimeterJones View Post
    I think they give you 4/32nds forgiveness. IIRC you can buy through tire rack and they will shave it to match the others.
    Jan 22 2013
    '10 S4, '02 Subaru RSTI - EJ207 Swap, '75 BMW 530i Chump Car
    Buy a new one. Why risk it either a) leaving you stranded somewhere or b) having a wrecked cord and coming apart on the freeway?
    2010 Audi S4 || Meteor Grey Pearl || 6MT || Sport Diff || Nav || B&O Sound System || Advanced Key
    VMR 721 19x9.5 w/ Michelin PSS 265/35/19 || 034 Transmission and Rear Diff Mounts || CR-15 Brace
    The ex: 2002 Subaru RSTI || Midnight Black Pearl || JDM STI Swap - EJ207 || 6MT || ST Coilovers || Blouch Dom 1.5XTR Turbo, etc. || Airboy Tuned
    The racekar: 1975 BMW 530i || Classic BMW Paint Scheme || Caged || 5MT Swap || Body Roll
    Senior Member Two Rings Sudz's Avatar
    Apr 19 2014
    Beer Fridge
    Houston, Texas
    On replacing a single tire, it depends on how much wear is on the other tires. I blistered a side wall on a new set of tires last spring, tires had 5k miles and a couple of Auto-X days on them, I was able to replace that single tire. This was at discount tire, they seem pretty strict.
    2004 A4 Avant USP 6mt, Motoza Tuned
    2015 BMW M4, 6mt, Mineral White Metallic, BPMSport Tuned
    2016 Z06/Z07 Vette
    May 02 2008
    Houston, TX
    Thanks for the replies guys. The air in the tire is the same, so that's good for now.
    I will replace the tire, just to be on the safe side. This been the first time of me replacing just one tire on a quattro, I am a little concern. My tires are 6-7 all around hopefully everything will be alright. Called discount tire this morning and they are getting the new tire for me.
    Any other experiences on replacing a single tire on a quattro?
    Senior Member Three Rings GoNavy's Avatar
    Feb 03 2012
    F-14 Tomcat
    Philly/DC
    They 'should' shave the tire down at the place you get it replaced so the tread depth matches the other 3. If I remember correctly you don't want more than 2mm difference.
    2013 S4 - Sprint Blue - 6MT - Carbon Inlays - Fully Loaded Prestige
    Veteran Member Three Rings Audi Advocate's Avatar
    Mar 26 2005
    2012 B8 S4, 2012 A3 Wagon
    Quote Originally Posted by djkyky View Post
    2nd that - don't screw with safety.
    Sidewall damage is a non-starter. Only repair punctures if they are in the flat of the tread. Merry Christmas!
    Current #1 2012 S4 3.0T DSG Technik with Unitronic Stage 1+, Milltek res., KW V2 coilovers, StopTech BBK, Alu Kreuz, H&R Rear Sway, BBS CH-R's, Michelin PS4S, Disabled wink, De-badged, ZIZA LED's, 30% tint and fancy aluminum pedals - Current #2: Wife driven 2012 A3 2.0T Progresiv- stock
    Veteran Member Three Rings dizzlesizzle's Avatar
    Nov 19 2011
    Rhode Island
    Quote Originally Posted by GoNavy View Post
    just curious as to what the issue would be if you have more than 2mm difference? what happens if you decide to drive around with the spare in the trunk for a month?
    --2010 S4, Premium+, Black, 6MT, NAV, B&O, Park Assist, 19" AV-M310 ET35, DTM Style Carbon Fiber Front Lip, VAG, ADS "Lite", ROC-EURO CAI, 5000K HIDs
