Results 1 to 8 of 8
    Veteran Member Four Rings f4m0u5's Avatar
    Aug 04 2014
    Gloucester MA USA
    brake booster hose problem help please
    So i was doing a boost leak a feew days ago and realized the part of the brake booster hose.that connects into the accordion hose next to maf seems to not flow air in either direction and looks to be glued?
    Should the piece that goes into the acordion hose let air through one way or the other?? I think mines built up woth shit and sealed
    I can blow through but not suck through thr part of the hose that connects to fire wall. And if i block off the one to the intake manifold i can no longer blow through.
    I can suck but not blow through the one that attaches to intake manifold. But if i block the one to the firewall i can no longer suck any air through.
    Should i order a new suction pump jet and brakebooster hose?
    Aug 04 2014
    Gloucester MA USA
    Looks like a check valve and it shoudlnt be cloged/ glued....
    How could thos effect how my car runs/drives
    Established Member Two Rings bajanavant's Avatar
    Mar 14 2011
    behind the wheel
    If you replace the whole jet pump assembly with one of those valves and a hose going to the intake manifold everything will still function correctly, just plug any holes that are left should only be the one in the intake hose that connects between the y pipe and maf iirc
    Darth Jefe
    Veteran Member Four Rings QuinnsterKID's Avatar
    Mar 02 2010
    1989 Ford Mustang LX 5.0
    Las Vegas
    Id say get the new valves and go with silicone hose and a T fitting. Ive been running mine for months with no issues.
    2012 Moonlight Blue S4 // Black Optics // Intake and Exhaust // Lowered
    2001.5 Nogaro S4 // 6MT // Stage 3 // K04 // E85 // Daz tuned
    2014 Daytona Gray Pearl Q5 TDI // Black Optics // Sport
    2013 Black A4 Sport SOLD
    2008 Ibis White A6 3.2 Quattro SOLD
    2004 Silver USP A4 Avant 6mt SOLD
    2000 Laser Red A4 1.8 Quattro SOLD
    2001 Santorin S4 SOLD
    Mar 14 2011
    behind the wheel
    Quote Originally Posted by QuinnsterKID View Post
    That looks like a good option also might have to try this
    Darth Jefe
    Aug 04 2014
    Gloucester MA USA
    Thanks guys, i ordered a new one.
    But now im wondering if that check valve being glued shut would even be a problem at all. It would technically make the setup work just like the older style hose because the check valve in the suction jet pump still would operate like that yellow/ black valve if placed at the fire wall and the glue would be actimg as your plug fir the accordion hose and just not allowing the suction jet to work but just be used as a check valve.
    Does that sound about right? The car would run/ drive normal woth this valve glued shut?
    What does the suction jet do? I dnt think audi added it for no purpose
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    There are plenty of threads on this if you search
    I prefer to convert to the early style.
    You are correct.
    Plugging that check valve will make it function the same as the early style, but it does not address the vac jet pump/check valve/tee piece that likes to blow apart.
    The vac jet pump is a vac amplifier.
    It gives the booster a lil more vac to work with and might make the pedal a little easier to push for a given amount of braking.
    Not that you will get more braking, just that the pedal might be easier to push for what braking it already had.
    Similar to those sprint booster things for the gas pedal that make your car have more power It doesnt, just takes less pedal.
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesn’t move and it should - WD40.
    Aug 04 2014
    Gloucester MA USA
    Quote Originally Posted by zillarob View Post
    You are correct.
    Thanks alot! Thats what i thought. So i might just keep this this way for now since i jb welded the suction jet together last year and that seems to be holding up nice.
    Im annoyed cause i thought thia. uld have been part of my idle issue haha
