Results 1 to 24 of 24
    Senior Member Three Rings olethalb's Avatar
    Feb 22 2013
    london ish
    Lots of n00b questions - build starting to start 1.8tqs
    OK little bit of background,
    had bora (jetta) 1.8t's, golf, s3, tt etc etc also b6 for a short time, joined audizine a while back with b7 DTM tfsi quattro running ~360bhp (being euro chp) but sold that and built fastest touran (routan ish) at 400chp and converted to haldex. sold that at the weekend and agreed to buy A4 B5 Quattro
    Now my list of no doubt well covered questions that i've searched for but seems to be a mish mash of info.
    current engine is AEB with k03s from B6 unmapped
    1) can i switch the block for one from a golf (internal waterpump) ?
    2) has anyone - is it possible to update the headlight controls to lose the stalk and use the twist knob from a6 4b/c5 for example?
    3) what sort of work is involved in swapping to me 7.5 - obviously pedal, tb, coils, maf, injectors, engine harness - any wiring required?
    4) after doing a few basic mods i will be looking into a 'BT' ideally topmount to run 400+ chp, i'd rather not buy a kit to keep costs down, i can tig weld stainless / ally so making downpipe / boost pipes / fmic kit etc is not a problem
    so far i'm thinking; internal waterpump block
    tfsi crank
    rods
    stock s3 / tt (k04) pistons
    AEB head
    custom fmic
    as for injectors / turbo / clutch i'm not so sure as there's so many options, it's hard to find a decent tuner in the UK who'll rechip and put a decent map / tune on the old style ecu's
    i apologise for the broadness of question 4, like i say it's only a run around car so want to keep costs to a minimum, tempted to even try ebay china turbo (don't hang me)
    5)what fuel pumps are used on these, i've lost all my 1.8T knowledge messing about with tfsi for so long
    thanks all, please be gentle
    Olly
    Veteran Member Four Rings Avant Nate's Avatar
    Dec 23 2009
    2001 Audi Allroad 6MT,1999 Yukon Denali, 1987 4Runner
    Boulder, CO
    What year and engine stamp did you, or are you going to buy?
    99.5 1.8T QMS: GT2860RS .63 T3, PSI T3 Mani, Turbosmart 38mm EWG, Unitronic 415, Forge 007,Treadstone TR18 FMIC, Walbro e85 450, FSI coil conversion, 3" DIY Magnaflow/Dynomax VT exhaust
    Depo ecodes, DDM slim 6000k, VDO boost gauge, PLX AFR, Greddy profec B EBC,
    H&R sport springs, 034 rear sway, 034 rear diff carrier, A8 fronts,18x8 OZ Superleggera
    Next up E85, efr 7163 or gtx3071r?
    01 allroad 2.7t 6mt, GIAC stage 1
    Feb 22 2013
    london ish
    it's a 99 AEB but i want to change it for internal water pump motor
    Jun 30 2008
    Erie, Pennsylvania
    1) Yes, but you need a bunch of little stuff (coolant hoses, etc, etc) to do it. Best to have a donor car.
    2) I know of no one who has done that. Probably because it would be an absolutely huge amount of work with no real benefit.
    3) There are some guides on this, methinks. Something about changing the cluster makes it tricky without changing the entire dash harness, as I recall.
    4) There are a lot of words here, but no question mark. I'm not exactly sure what your question is. Injectors will depend on your tune, so pick the turbo size and tune first.
    5) Depends on turbo size, injector size, power goals, etc. Check the go-fast vendors and see what they are offering. There are drop-in solutions, or you can DIY some stuff.
    Feb 22 2013
    london ish
    thanks walky talky i did start to ramble
    regards headlight stalk i went to view a 1.8tq a year ago and was set to buy when i noticed the headlight controls on a stalk and it just put me off (wierd i know)
    afaik regarding block swap b6 1.8t is internal pump so could use that? i want electric fan too
    uk has far less bt builds compared to you guys and less DIY builds too - where people are always cagey, would a gt2871r get me 400chp with supporting mods? if that was ok turbo to run i'd then need to figure out 'best' injectors for that set up
    thanks again
    Dec 23 2009
    Boulder, CO
    Do you already have the car in your possession? Because buying a 2001 (assuming euro cars are same as US), would be SO much easier for the things you want to do?
    Veteran Member Four Rings nynoah's Avatar
    Jan 16 2006
    01.5 A4 avant Past cars: 95 S6, 85 Golf II VR6, 2 sciroccos, 92 Corrado VR6, 86 Euro BMW 535 Alpina
    LA CA
    It would be cheaper and smarter to sell your car and buy an AWM B5 A4.
    2001.5 black on black avant 5spd, EFR 6758, Pag Parts band manifold, Vibrant GESI High flow CAT, 2.0L 06A, IE intake manifold, built AEB head, 1000cc Boosted Euro Tune, bosch 044, Ringer Racing stage 3 hybrid Organic/Cerametalic 240mm clutch, S4 interior upgrade, full S4 brakes front and rear with lines, 17in OZ Racing Ultraleggera, 034 HD suspension arms, Stern soft mounts, mirimoto bixenon etc. http://www.audizine.com/forum/showth...s-Build-thread
    Jun 30 2008
    Erie, Pennsylvania
    Quote Originally Posted by olethalb View Post
    No worries, brah. I got you.
    In regards headlight stalk i went to view a 1.8tq a year ago and was set to buy when i noticed the headlight controls on a stalk and it just put me off (wierd i know)
    Yeah, that is weird. Personally, I think the stalk is superior.
    - The paint doesn't wear off and look crappy after some years.
    - I can turn my headlights on/off without my hand leaving the steering wheel.
    - It is an actual, honest-to-goodness physical switch (literally the headlamp current passes right through this stalk switch) instead of some digital input to a computer "module" (like the B6 A4).
    For these reasons, I see the stalk and I'm all like "Yes. This is all well and good." but when I see the rotary switches with all their scratched up plastic and rubberized paint falling off, I'm all like
    Registered User Four Rings
    Feb 08 2011
    B5 A4 2 liter HTA3586r
    Phoenix, Arizona area
    Why do you want to switch to a 06A motor? You aren't going to gain anything unless you looking to built it to a 2.0 stroker seeing the 06A is easier to stroke then the 058.
    Never mind saw this in your post.
    tfsi crank
    rods
    AEB head
    custom fmic
    Sorry but you can't run standard 1.8t pistons with a TFSI crank unless you feel like having the top of your pistons sitting well above the block deck. To use a TFSI 2 liter crank you will need to run aftermarket stroker pistons since they have the pin offset to lower the piston down for the longer stroke, so the overall length of the rod/piston need to be shorter for the longer stroke. Stroker pistons and standard 1.8t pistons are not the same.
    Feb 22 2013
    london ish
    I bought the car yesterday and as for buying a later model there was 2 for sale in the uk and none of them were newer than 2000
    Coming from dtm / b7 rs4 / touran the b5 is a little outdated so would like the later style headlight switch so i can add auto headlights at some point
    Regards block in the uk audi thought it'd be a good idea to extend service intervals so most a4's have suffered oil starvation, the internal pump motors are very readily and cheaply available plus i've worked more on them so feel more at ease, i'm not scared of getting my hands dirty or taking on work etc, thanks for the crank / piston info, the crank idea is not set in stone but possible.
    I'll throw some pics up to stop it getting boring
    And the b5 due to collect tomorrow
    Veteran Member Three Rings Wrath And Tears's Avatar
    Apr 03 2014
    17 GTI Sport
    Pretty sure that's not possible as you would need to add a sunlight sensor, as well as a computer you would have to add to have the sensor turn on the headlights. Then you would need a new dash, or to modify the B5 dash which would look terrible, as well as having to make a switch to plug into the rotary dial and then you would have to run those wires to the correct pins on the ecu or something.
    What I'm trying to say is as far as I know there is nothing pre-existing you could modify on the B5, you would have to add in everything and figure out all the wiring. If you got 200+ hours to throw at it I'm excited for the build thread . I think it's a cool concept and I would love to see everything that's actually involved in making it work.
    2017 MK7 CSGM GTI Sport DSG
    PP (Golf R Brakes, +10HP, VAQ LSD), LP, Kessey
    LW 17" Sparco Assetto Garra's, 034 Res-X resonator Delete
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    tfsi crank
    rods
    AEB head
    custom fmic
    I will answer the quoted questions, so let's see how long I can type before I run out of gas.... And I will preface this by agreeing with nynoah, it will be far cheaper and easier for you to buy an AWM/other 06a/DBW/wideband B5 (don't know Euro engine codes).
    1. Yes, you certainly can swap to an 06a block, and like Walky mentioned, it ain't easy. You will need lots on ancillaries to adapt the engine. To me, it wouldn't be worth the cost. With that said, I am fully considering switching my 2000 to an 06a setup in the future. I am no fan of 058 blocks. I want an internal waterpump, and I don't like the fact 058 blocks have intermediate shafts. 06a's are just nicer, and if you are going to build it, you dont want to deal with an 058 block anyways.
    3. It is a lot of work, especially since you have an AEB car. But, if you are going to switch the engine to an updated style, you are going to want updated engine management and such. In order to get that, a lot of changes will need to be made. But it isn't really that bad, maybe a weekend worth of work. ECU, harness, sensors, cluster, pedals, etc could all be done in a day in fact.
    4. I could almost write a book answering this question, or at least a very long pamphlet, or a small treatise. What you are looking for is what I have, minus a the TFSI crank. I run an AUG block (06a out of a 2001 Passat) with an AEB head. I kept the stock stroke, but put in Mahle Powerpak pistons. I am at about 400chp with a GT2871r, or 320awhp. Well, if you are interested in learning more, click the link in my sig line.
    I would like to write more, but when you say you want to keep costs down, I feel it would all be futile. All of this that you want to do is going to run about $10,000 dollars, not sure what that is in Euros, Pound Sterling, or gold doubloons. But it is a significant investment that will only ever pay dividends in tears, cut fingers, and if you are lucky, plenty of smiles.
    5. Just get a Walbro 255lph fuel pump, unless going over 400awhp.
    The bottom line is, you are going to want another car to swap everything in. And I've checked out UK prices on b5's. They are quite reasonable. But its going to be a lot of work to swap all those parts over. It will also be very expensive. You can spread the cost out over years if you want, it it will be a little easier. You also try to use parts that are more common locally, such as Holset turbos instead of Garrett. Holset was actually an English company before being bought by Cummins.
    2020 SQ7- Wife's ride
    2000 S4- Working?
    Feb 22 2013
    london ish
    wrath and tears - i'll just need to re route wires from column to a dash switch and use a6 4b column contorls / cowling then hook up a relay and use one of the ebay switches for a mk4 golf retrofit, i'm not aftraid of a bit of wiring ;)
    Feb 22 2013
    london ish
    One of these
    Feb 22 2013
    london ish
    Feb 22 2013
    london ish
    apologies for the disjointed reply / pics
    redline thanks for taking the time to reply
    1) yes you explained my feelings better on the 058 vs 06a blocks
    3) i may just buy a B6 1.8t as a parts donor, in the UK the b5 1.8tq are getting hard to find and i'm not sure if i've ever even seen one with later style block / management, as i said there were only 3 for sale in the whole of the uk so buying another one is not an option, besides wheres the fun in that - i like to build things :)
    4) i will check your thread - thanks, when i said keep costs down i didn't mean skrimp but why buy what you can make right? 06a tall block with largeport and rods will cost under £500 / $750 dollars, topmount mani $400, lines i can make myself, intake i can make myself, downpipe i can make myself, intercooler kit again just materails so say £300 dollars for all of the above, that leaves injectors, clutch, turbo and few other bits i'm sure. a complete b6 1.8t with all bits to convert should be under £750 maybe cheaper if i can find one with the oil starvation blocked pickup pipe death.
    5) thanks, thats external walboro right? i'm so rusty on 1.8t it's all ttrs and pump controllers bla bla in tfsi world haha
    Apr 03 2014
    17 GTI Sport
    Has anyone tried putting a b5 passat dash into a A4 yet? Then you would have a spot for the light dial. That kit looks pretty cool.
    Feb 22 2013
    london ish
    I might see if the passat lower knee panel from passat fits, good shout.
    Well i collected it yesterday evening
    And some new wheels
    And popped them on before i got home
    Need proper size tyres and spacers - going through mountains of paperwork today and found this laminated dealership ad
    Feb 22 2013
    london ish
    ok so decided the vce are too small as i got stuck on a speed hump into work so i've bought some bbs ch that should be on route, also i went to see a friend of mine last night who has a double garage full of parts / old projects / failed projects mk1 golf 20v, mk2 golf 20v and mk4 20v 4mo. he dug some bits out but is pulling the cars out today for a proper look.
    so far he has given me an AGU 06a engine, uprated injectors and an ebay turbo :)
    i also removed the after market gearknob and number plate surrounds, excuse the silver gearstick surround the old one was wrapped, i peeled the wrap off but underneath was in bad shape so re wrapped it with all i had to hand.
    Feb 22 2013
    london ish
    I also have this a6 1.8t quattro manual
    Feb 22 2013
    london ish
    Also has this not sure what it is gt30 of some sort not sure if it's worth doing anything with?
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    yeah that is a gt30 it looks like. That's the turbo I'd go with.
    Cool that you have an a6 1.8t quattro. Wish we had those options here
    2000 S4- Working?
    Feb 22 2013
    london ish
    double post
    Feb 22 2013
    london ish
