    Veteran Member Four Rings V8Star's Avatar
    Jun 08 2010
    2.7t Brake vacuum hose / Suction pump for 6spd car
    Looking for the following brake vacuum hose / suction pump.
    This must be from a 6 speed / later manifold car and look like the picture. The hose connects at the fire wall, intake manifold, and throttle inlet hose.
    Part number 078133701AD
    PM me a price and a photo.
    R8 V10 Supercharged
    8V.2 RS3 grocery getter
    A few A4 Avants
    Jun 08 2010
    ttt
    R8 V10 Supercharged
    A few A4 Avants
    Veteran Member Three Rings Wagonholic's Avatar
    Mar 01 2014
    2001 B5 S4 Avant (Laser Red)
    Los Angeles, CA
    If you have the end pieces still, you can make your own using heater hose.
    -Take the check valve that goes into the accordion hose, and put that into the brake booster grommet in the firewall
    -Take the connector from the intake manifold, and put it back in the intake manifold
    -Run a piece of heater hose between the check valve/connector
    -Plug the hole on the bottom of the accordion hose and/or buy an accordion hose that does not come with the hole.
    The early-style S4 hose was like this, and did not have the 3-way connector in the center anyway. Eliminates another common failure part on these cars. The newer style is worse. Most I have seen (including mine) either blow apart, or are glued/zip-tied together. I have since replaced it and it's now problem free.
    Justin
    I have a major problem, I'm a boost addict and a wagon addict
    #toomuchboost #racewagon #becauseracecar
    B5 S4 Avant - Laser Red. 6-speed Manual. 1 of 18. Unleashed by STUKLR
    Going big or going home. Doing a garage build. View my build thread.
    #YEengineering
    Jun 08 2010
    Quote Originally Posted by Wagonholic View Post
    Unfortunately for me I am doing a swap and this hose was never sent with the engine. So I don't have any of the fittings. Thanks for the info, though.
    R8 V10 Supercharged
    A few A4 Avants
    Veteran Member Four Rings treysgreen's Avatar
    Jan 03 2014
    02 A4 1.8t Quattro
    Atlanta
    I'll see what I have in the shop. I likely have the hose you need.
    02 A4 5spd 1.8T Quattro ///
    01 S4 6MT /// - SOLD
    Instagram - s4mods ///
    http://s4mods.com ///
