Results 1 to 7 of 7
    Sep 14 2005
    NC
    Possible to paint exhaust tips on ssac??
    Don't want to be ricey if I can't do it. But would rather have black tips. Is it possible to do this??
    Senior Member Three Rings Cairo94507's Avatar
    Dec 22 2015
    San Ramon Valley, CA
    The problem is paint will likely flake, chip or wear off. Have them ceramic coated. Probably $60 for the pair. Plenty of colors, including the range of blacks to choose from. Google ceramic coating in your area and I am sure you will find a shop. Likely a week turn-a-round time. Good luck.
    Aug 06 2008
    Canadia
    Por-15 high temp
    Veteran Member Four Rings QuinnsterKID's Avatar
    Mar 02 2010
    1989 Ford Mustang LX 5.0
    Las Vegas
    I agree with Cairo94507. Just get them jet hot coated. With paint your going to have to scuff the surface and do a lot of prep and eventually it may peel if the prep was not properly done. Powdercoating would also work as the cure temp for powdercoat is around 400 degrees which exhaust tips never see.
    2012 Moonlight Blue S4 // Black Optics // Intake and Exhaust // Lowered
    2001.5 Nogaro S4 // 6MT // Stage 3 // K04 // E85 // Daz tuned
    2014 Daytona Gray Pearl Q5 TDI // Black Optics // Sport
    2013 Black A4 Sport SOLD
    2008 Ibis White A6 3.2 Quattro SOLD
    2004 Silver USP A4 Avant 6mt SOLD
    2000 Laser Red A4 1.8 Quattro SOLD
    2001 Santorin S4 SOLD
    Nov 02 2014
    06 9-3 Aero 2.8T, 96 Miata
    Winchester, VA
    I just want to remove the shitty tags on mine without killing the finish.
    Honestly if you want black, and don't have cats, just don't clean them. ;-)
    Sep 14 2005
    NC
    Yeah maybe I'll look into the ceramic coat. Thanks
    Veteran Member Four Rings bobkatkat's Avatar
    Jun 07 2012
    North of the 49th parallel
    You can paint the tips with Ceramic header paint or Endura Industrial 2k paints. If you prep them properly they will not chip. Even if the do it is easy to touch up.
