Results 1 to 8 of 8
Thread: MIsfire
    Dec 22 2015
    Minnesota
    MIsfire
    Hey everyone, this is my first post here. Ive done some research but can't find anyone with the same problem. I recently got a 2000 a4 1.8t 5 speed as my DD. I had a GIAC stage 1 tune put on about a month ago and starting getting misfires from cylinder 3. I replaced the plugs and coils and it got better but isn't gone. Still multiple random misfires and cylinder 3 misfire. But if I got WOT in 1st 2nd and 3rd it seems to be non existent but say i'm cruising in 2nd at 2200 and go WOT it will hesitate and misfire. same with the rest of the gears. Any advice would be appreciated! I will be putting on exhaust and downpipe this weekend so i'm hoping to get it taken care of. Thanks in advance!
    Dec 22 2015
    Chico, CA U.S.A.
    How are your coil harness/plug wires? Are they brittle and cracking?
    Sent from my SM-N910V using Tapatalk
    Dec 22 2015
    Minnesota
    They appear to be okay, normal wear not cracked or burnt from what I saw.
    Established Member Two Rings StriktlyAudi333's Avatar
    Jul 20 2015
    Mesa, AZ 85207
    Get VAG-COM and study mandatory stoichiometric fuel/air ratio and read your short term fuel trims on live feed."" Once you get VAG-COM you'll run the world like the rest of us
    Veteran Member Four Rings vrmm's Avatar
    Nov 14 2011
    NW
    What's your gap? You should put it to .026-.028
    Dec 22 2015
    Minnesota
    Sorry Ive been away for a little bit, I will invest in a VAG-COM in the future. I set my plug gap to .28 with these new plugs. I now put exhaust and a downpipe and the misfire is still there. I'm thinking ill swap the injector on 3 and see if it follows. Any other thoughts would be appreciated!
    Dec 22 2015
    Minnesota
    Also to note that when i replaced the coil pack on cylinder 3 the misfire seemed to go away for a few days... then came back on the same cylinder.
    Dec 22 2015
    Chico, CA U.S.A.
    I thought my misfire problem was from my plugs and coil packs, but it ended up being my crankshaft position sensor. You can get a new one for under $15 free shipping on eBay. But I bought an upgraded one on ECS Tuning for $55 because it included a protective sleeve. These sensors get hot and start to intermittently fail over time.
