Originally Posted by
AvusPdx
I'm about to clock 58k miles, and was curious to see what interval people change out their Trans/Diff oils at? Did you go OEM or Motul/Redline/liquid moly?
I'm planning on changing it out this coming January. And CC next.
What else would you guys recommend replacing/changing around the 60k mark? I'd like to be pro-active on my maintenance as much as I can. I've already done the rotor/brakes this summer.
I can think of:
Brake fluids
Radiator flush
Bushings (suspension)
any electronics/sensors I should replace?
Spark Plugs
Air Filter
CV boots?
I'm planning on tracking my RS4 next summer, and any information would be appreciated.
This is what I have done, and over 100k now.
Transmission - redline @ 100k
Rear end - motul @ 100k
Brake fluid - 70k
Upper control arm bushings (pressed in new ones) @ 100k
Coils and plugs - 1 time (service kit from JHM) @ 75k
Air filter - K&N
Radiator flush - @ 100k
Cv boots - stock
Sensors - stock
Carbon cleaning - too much of that shit!
You still got your PSS9 and like them if I recall your username right? I definitely enjoy mine and might buy for another car as well. Run 6/6 setting I think.
That's all I got for you. I went motul for the rear end as I was told it exceeded the specs/requirements of the redline. The redline has been great in the transmission.
