if you don't recognize my username, I've done a tip to 6 swap. anyone have any tips to make things easier during reinstall? I've checked all of my lines about 70 times, that's almost not an exaggeration. couple things I'm thinking of doing to make install easier:
1) clutch slave mounted in trans before install. then I'll only have to connect line from master
2) shifter linkage from swap donor not messed with. have the linkage in the shifter box and inserted in boots. planning to connect linkage once trans is within reasonable range
3) axle shafts installed and pinch bolts out of knuckle for extra clearance
4) planning to install the manual trans brace from subframe once trans is in for extra clearance
5) installing oil filter post install for extra clearance
that's all I can think of outside of taking it really slow and steady. checking for clearance and watching for pinch wires/lines
any other tips from those who have done this is greatly appreciated!
