Results 1 to 40 of 74
    Veteran Member Four Rings GRUMPY-S4's Avatar
    Nov 16 2015
    DFW
    Opticoat Roll Call?
    Thinking of pulling the trigger on Opticoat just for the esse of detailing the car. Ive been told you can clean car in under 30 mins and have pro detail results. Thoughts?
    Veteran Member Four Rings theedge111's Avatar
    Apr 15 2009
    Calgary
    Had the original opticoat on my 2014 S4...it was amazing! So easy to clean the car!
    My detailer did the opticoat pro on my S5 it's only been a few months but I'm still very happy!
    Nov 16 2015
    DFW
    Im lazy and hate spending hours washing the car! Did you get wheels done?
    Veteran Member Four Rings b8audis4's Avatar
    Nov 06 2013
    Ohio
    Opticoat is not a miracle product that just allows the dirt to wash off the paint. But it makes it easier to get the dirt off, and will keep the paint from having swirls. Also, you should polish the paint before you get it applied. So it is near perfect paint underneath. Then the couple of microns that was polished off you will add back with the opticoat. And in a couple of years when you get more swirls, you polish again, add opticoat and it is like you are only polishing the opticoat layer so you aren't removing actual paint. I would recommend it for sure. I had it on my paint a couple of years back, and I enjoyed it, but it almost made maintenance too easy so I removed it. I enjoy detailing so I enjoy sealing and waxing my car.
    The wheels I would highly recommend doing.
    2011 Audi S4 - Ibis - Magma - Premium Plus - XPEL - STIR PLUS - Anti Laser Priority - AWE Resonated Exhaust - Ecodes - Alu Kruez - BBS CH-R (Mops)
    Nov 16 2015
    DFW
    Its getting paint correction as part of the process
    Jan 28 2013
    Funny, you mention this.. I have a friend who was nay-saying everything except wax last week. I told him he was living in the past, to which he scoffed at me. Later that day we was over at my house helping me drop off an arcade machine and saw my car. He looked at me and said: "what was that stuff again?" :) Apparently, he was blown away that I could drive around for a week in the rain here and still have a car that didn't look like it had been driven for a week in the rain.
    I think any of the "nano" coating are pretty good at what they do. I have the Opti-gloss (I think it's called now) that I put on this summer and had the opti-coat 2.0 for the last couple of years that I put on when I bought my S4 (2013). No complains from a performance standpoint; it seems like it stays cleaner longer and makes cleaning relatively easy. I don't know that it actually saves you any time when washing, per se. But, "Stuff" seems to sick to the car less. There is a fair amount of prep work that you need/should do. But, All in all, I think I spent about 7-8 hours prepping the car and applying the coating.
    No qualms about recommending the opti-gloss.
    Nov 16 2015
    DFW
    Edge your car looks amazing!
    Nov 28 2015
    Montreal, QC
    Quote Originally Posted by b8audis4 View Post
    that's false. Nano-coating is like 1-2 microns thick. Paint correction can take 2-10 microns to polish to a showroom finish.
    Nano coating is not a miracle product, but more of enhanced product Vs. the traditionnal wax/sealant.
    Nov 06 2013
    Ohio
    Quote Originally Posted by waxxonMTL View Post
    Of course, I am talking a light polish. So if opticoat is 1-2 microns additionally, and I polish the paint, not compound, we are talking around the same thickness. With opticoat, and proper washing you should avoid most swirls.
    Mar 21 2015
    I have C-Quartz and love it. Crap comes off so easy.
    Nov 16 2015
    DFW
    The installer said that I would clean car without water basically... Thoughts?
    Nov 06 2013
    Ohio
    Quote Originally Posted by GRUMPY-S4 View Post
    I am sure you could use a detail spray. And I am sure you could do a touchless wash with mostly a pressure washer, but that is stretching it a bit.
    Nov 16 2015
    DFW
    He told me includes a "kit" of some solutions and clothes and a bucket lol
    Established Member Two Rings Troglodyte's Avatar
    Apr 28 2012
    Northeast
    I have used Opti-Coat (now called Optimum Gloss-Coat I believe) on cars and wheels many times. Protects and lasts a very long time. Not the glossiest or biggest "wow" factor but great protection, especially on wheels. As others have said, you must have perfect paint since you will be sealing in any existing imperfections. Can only remove the product by polishing. Wheels off to do the job right if you decide to do the wheels as well.
    2015 S4 Mythos Black
    Jan 28 2013
    I don't know what your installer means by that. You can certainly clean your car "without water." But, as a practical matter that is complete BS.
    Apr 28 2012
    Northeast
    Quote Originally Posted by Lamprey View Post
    Think he means "waterless" washing technique.
    Jan 28 2013
    My thoughts are that the nano coatings help you keep you car cleaner a bit longer. It doesn't really save any time WASHING the car. But, I don't see the need to ever wax after applying the nano coating, so you save a bit there perhaps. YMMV.
    Veteran Member Three Rings BigBluu's Avatar
    Feb 25 2010
    '15 S4, '17 A3 e-tron, '18 Model 3
    The City
    I've had the pro version on mine for just over a year now and love it! We're finally getting some rain here in CA and it beads like a mofo. Have not washed it in over a month and the top 3/4 of the car still looks relatively clean even with the rain the past couple weeks. With the drought we've been in, I did ONR washes almost exclusively. Very easy with great results. I've only done about 4 or 5 full-on water/soap washes in the first year of ownership. And...knock on wood...not a single swirl mark that I can find yet. I have not put any other paint protectant on it. Highly recommended!
    2015 S4 S-Tronic Prem+ Sepang/Magma Sports Diff / B&O / Carbon Atlas / 034 ECU & TCU Stage 1 / ECS Intake / Alu Kreuz / CR-15 / 034 Trans Mount / 034 Rear Sway / Moog Links (F&R) / H&R OE / VMR V810 (19x9.5/ET40) / Michelin PS 4S / Opti-Coat Pro
    Aug 13 2015
    Cali
    Opticoat Roll Call?
    Just put gloss coat on my car. Did it over two days...day one was wash, paint correct and on the second day I used IPA and put two nice coats over everything (wheels, jams, etc). Used about 8CC total. Really awesome stuff.
    Obviously I've got an S3. Not sure how tapatalk got this thread in my newsfeed. :)
    Nov 16 2015
    DFW
    Nice!!!
    Veteran Member Four Rings pdqgp's Avatar
    Mar 06 2015
    a 12 Second boat, & Wife's Lincoln
    Columbus, Ohio
    Can't comment on Opti but I did the 22PLE Sealant on my own and it was easy.
    Detailing and paint correction isn't difficult. Audi has great clear coats and it's tough to F-it up even if you're a newb at it.
    Get a decent buffer for $250-$300 and the right products and 1-2 days tops.
    My car wasn't horrible when I took delivery of it, but it was bad enough. I took it to about 95% correction shortly after getting it this summer and then hit it again several weeks ago and now she's 99% perfect. I get comments a lot, even today when it was dirty after some rain the black BMW owner next to me could see his car looked like it was washed with a brillo pad whereas mine was a perfectly black mirror with just a hint of rain residue.
    Depends if it's something you enjoy doing it.
    2018 Midnight Black Metallic AWD Infiniti Q50S Red Sport | Burger MS JB4 | 395awhp/430awtq
    2018 Ruby Red Metallic Lincoln MK-C Reserve | AWD 2.3l EcoBoost - Wife's
    2014 Brilliant Black S4 | S-Tronic | 187mm APR Stage 2 Dual Pulley & APR TCU Tunes | APR CPS - SOLD
    Mar 21 2015
    ^ I use 22PLE on top of my C quartz. That bra line is killer though on black.
    Mar 06 2015
    Columbus, Ohio
    Meh....I can live with the line. I can always have it redone to do the entire hood but I don't mind it. It only shows here because I didn't 'detail' out the dust. Even then it's really only visible from the rear.
    Senior Member Three Rings NC_Detail_Garage's Avatar
    Jun 27 2015
    B9 S4
    Charlotte, NC
    I applied gloss cost myself to both our cars and I'm content with it but I wouldn't pay the $800 or so to have a pro do it. I wash my car weekly and after 6 months it's not beading or shining like it used to. I use sonax net shield as a topper which really brings the life back to it. I'm looking at doing cquartz next year.
    Nov 16 2015
    DFW
    Quote Originally Posted by remythepug View Post
    The pro + version is like 1100 to apply, add glass, interior, wheels etc and your looking at $$$$$
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    Anybody compare this with Zaino?
    Senior Member Two Rings DirtyDog--IRL's Avatar
    Mar 31 2015
    Columbus, Ohio
    What a shine! Nice job
    Apr 28 2012
    Northeast
    Quote Originally Posted by S4'ed View Post
    Two different animals. 99% of the look is from the preparation, i.e. polishing. the LSP is meaningless without proper prep.
    Sep 24 2014
    Central NJ
    So I guess I should just continue to use Zaino?
    Mar 06 2015
    Columbus, Ohio
    Quote Originally Posted by DirtyDog--IRL View Post
    Thanks Man! You coming back to Ohio or are you here yet? We'll have to get together again. LOL at the crash bar though.....I need to hit it with some Truck Bed Liner as it's starting to chip.
    Veteran Member Three Rings KRS Aaron's Avatar
    Jan 25 2011
    Evanston, IL
    My Audi dealer didn't listen to me about not washing my car and it's swirl city even with the OptiCoat. As people have mentioned, it's not an invincibility cloak for the car. After the winter, mine has to go back to the detail shop for a redo. Even with the issue, the performance is amazing when the car is clean. I do notice it hits a tipping point where its too dirty for the beading to happen as one might imagine but this point is much further along than when I used to wax the car myself.
    2024 RS6 Performance - Nogaro Blue
    2012 S4 - Nogaro Blue
    2017 Aston Martin V12 Vantage S - Onyx Black
    1994 BMW 850 CSi - Mauritius Blue
    M2 CS Racing
    Mar 06 2015
    Columbus, Ohio
    I stopped. Great stuff but I think the market has caught up with them. I switched over to BLACKFIRE Wet Diamond products. I use several:
    BLACKFIRE Wet Diamond Polymer Spray - By far been the best detail gloss I've used. Meguires Gold Lable is a close second and significantly cheaper too but no where near as slick.
    BLACKFIRE BlackICE Hybrid Montan Sealant - is Incredible for Black cars. I am in sticker shock still but gotta admit I'll buy more when I'm out. Goes a long long way though.
    BLACKFIRE Crystal Seal Paint Sealant - I will say this is far and beyond my favorite product though. goes on like it's petrolum based in appearance but quickly evaporate into an extremely slick and truly wet appearance. I was wowed when I used it as the car actually looks like it does in terms of depth when it's wet.
    100% spot-on. The prep and polish is where the Depth of the color comes from. When looking at most black cars, you will see minor even on new ones, minor spiderwebs. That completely ruins the depth perception. When corrected to be free from the, the color drops down to the depths of your imagination. Words, I know, but when you see it in person you do get a WOW! feeling.
    The great news is once done, just maintain the car properly and once per year you'll need to hit it with a buffer lightly with a simple swirl remover then polish to bring it back to 100%. I do this every year on our black minivan which is now 8yrs old and looks like new despite being our urban assault vehicle known as Satin's Chariot.
    I'm a pic whore. Note the van is done with just off the shelf Meguires stuff too. Nothing fancy.
    Nov 16 2015
    DFW
    Quote Originally Posted by KRS Aaron View Post
    So swirls are inevitable when the dealer washes the car? They have left mine pretty clean but full of water marks the two times they have washed it.
    Mar 21 2015
    Never let them wash your car again.
    Mar 06 2015
    Columbus, Ohio
    absolutely. especially if they use an automated wash system. even hand washing by the lot attendants is likely going to result in brillo pad finishes. Most of the damage is likely done when drying it.
    Nov 16 2015
    DFW
    No washes for me then now that I will have Opticoat. I honestly cant believe how expensive it is to do the whole care
    Nov 16 2015
    DFW
    Now I know. Never again!
    Mar 12 2004
    socal
    I had mine done with opti coat pro plus the first week after buying it. Like everyone has said, makes washing the car completely painless, and I'm looking forward to not having to do my every 6 months full detail/wax job to keep the paint glossy and bright. I had the wheels done at the same time and it is a kwanzaa miracle, brake dust just rinses right off!
    Nov 16 2015
    DFW
    Full car, interior (interior trim, seats, carpet, matts), glass/sunroof, wheels/inside fenders costs about $2K.... Ouchyyy
    Mar 06 2015
    Columbus, Ohio
    That's rediculous.
    Seriously. For $500 including a buffer and all the products you could do it all yourself. Again, easy stuff to do. Sounds like a lot but $500 isn't much considering you'll then own a buffer, the pads and enough product to care for your car or cars for years. PM Me if you want me to break it down for you.
    I've found several local mobile detail shops that I use to detail the inside of our minivan (think kids, wife and minivan) and not much imagination to how dirty it can get. They turn it brand new looking in about 2hrs for $100. I don't even attempt to detail the inside for that value.
    My S4 and any of my cars are always 9/10 inside so I really have nothing to do but wipe and vacuum them.
