Results 1 to 12 of 12
    Dec 22 2015
    Berkshire
    P2155 injector fault and missfire help please
    Hi new to this forum but in desperate need of some help I found a guy on here who had this fault tried contacting him but no luck.
    The car dies when being driven hard has fault code p2155 supply voltage injector group d! I've also had miss fire cylinder 7,8
    The Ecu was tested and found to be faulty so since been replaced by the dealer car ran fine for a week and now identical faults? No one seems to be able to fix it and it's driving me nuts I mean what's the point in a 4.2 rs4 when I can't boot it haha. Any help would be massively appreciated and hope somebody has had this fault and can tell me what I need to do.
    Stuart
    Account Terminated Four Rings Quattrors4's Avatar
    Sep 15 2009
    twinturbo b7 rs4 v8
    ri
    Change your relays in the front driver side ecu box
    Or you have a faulty injector or wire that is making a short
    Dec 22 2015
    Berkshire
    Thankyou have you ever come across this?
    Sep 15 2009
    twinturbo b7 rs4 v8
    ri
    Quote Originally Posted by Quattrors4 View Post
    yes the relay caused it
    Veteran Member Three Rings Avus RS4's Avatar
    Apr 09 2015
    Niwot, Colorado
    Awesome!
    Thank you for posting the results.
    It seems as though every time I read some faults with our cars, that mine gets the same fault next.
    2007 Avus Silver Rs4
    Bone Stock
    Dec 22 2015
    Berkshire
    Quote Originally Posted by Avus RS4 View Post
    Awesome!
    I'm hoping it works trying new relays tomorrow! Are these the same faults as you've all had I've already had a new Ecu it's getting a bit pricey
    Dec 22 2015
    Berkshire
    Just took out relays I have 645 and then two 614 relays and there is also two smaller 395 relays can anybody tell me what they do and what ones I need to replace for my above problems I can't seem to find and information thanks
    Sep 15 2009
    twinturbo b7 rs4 v8
    ri
    Quote Originally Posted by Poveyrs4 View Post
    , replace both of the 614 for new ones
    how do the relays look?some water coulded got inside
    Dec 22 2015
    Berkshire
    Thanks. They didn't look too bad was bone dry in the box yet when I pushed them they seem to click in better so maybe they are worn and not a great fit fingers crossed they solve my issue
    Sep 15 2009
    twinturbo b7 rs4 v8
    ri
    Yes they can be used enough to give a bad voltage
    Dec 22 2015
    Berkshire
    Well after replacing the relays as they did look a little burnt out! The car drives perfectly until taken above 6k in second gear! After the first few blasts it's was ok but on the third time off driving it hard in 2nd gear it then died the engine light flashes and same issues. Off to main dealer tomorrow but not much hope
    Junior Member One Ring The_chadwick's Avatar
    Jun 15 2021
    Aledo, TX
    I am currently having the same issue you did. We’re you ever able to get this fixed and if so what was the issue. Fingers crossed you even see this since this post is so old.
