Results 1 to 14 of 14
    Active Member Two Rings 2K1Quattro's Avatar
    May 11 2004
    2008 M3 6 Speed Cab
    Victoria BC
    B7 S4 Display issue after new battery.
    Hey Guys,
    I have a 07 S4 and had a dead battery. I had charged the battery but it wasn't holding a charge, would click but not crank. I replaced the battery and now my central display between the tach and the speedo doesn't work, also the displays below each gauge with the odometer etc are blank and not lighting up at all. The car starts and runs fine, the gauges all work fine, i'm at a loss. Has anyone come across this before? Any help would be great!!
    Cheers,
    Ryan
    Nov 12 2015
    Oregon
    You probably checked this.... if so i apologize. is it a fuse?
    My build log
    May 11 2004
    2008 M3 6 Speed Cab
    Victoria BC
    Checked all the fuses behind the drivers side panel.
    Nov 12 2015
    Oregon
    isnt there a 2nd fuse panel somewhere?
    My build log
    Veteran Member Four Rings JimmyBones's Avatar
    Apr 03 2010
    Northern Virginia
    There is more fuses and relays behind the lower shelf/driver's side kick panel. I don't think that is the issue though.
    Do you have a vagcom? Ross-Tech sells them if you don't have one and it is about the best $350 that you can spend with one of these cars. I would want to scan the 17 - instrument cluster to see what fault codes are present.
    You could also try disconnecting both battery cables, touch the two battery cables together, and reconnecting the battery cables. Sometimes the electrical systems do weird things.
    I have also seen instrument clusters die from low battery voltage too. It was rare but it did happen. That would suck because a new virgin instrument cluster is like $1,200 US Dollars plus 2 hours of dealership labor to replace it because it has to be programmed with the dealership scan tool.
    Feb 24 2010
    And have never been happier
    Quote Originally Posted by 2K1Quattro View Post
    Hey Guys,
    Cheers,
    Ryan
    I apologize and don't mean to come out as wrong here, but as part of troubleshooting, are you talking about the center LCD display? This is the one with temperature, mpg and few other readings? There is a button in the wiper stalk to the right of the steering wheel. It's at the bottom, it turns that center piece on and off. Could that be off? You may already know about it, I just wanted to cross that off (but hope it's that easy, because it's free :)
    Veteran Member Four Rings Silver Streakin's Avatar
    Mar 05 2004
    B8 S4, 17 Expedition EL, 2009 328ix coupe
    NoVA
    Quote Originally Posted by wednesday View Post
    I was thinking the same, but he also mentioned the clock/date and miles/odometer aren't on either.
    2011 S4, 6M, BB/panda, Sport diff, ADS, B&O | UniTronic stage 3 Dual Pulley | MercRacing HX | RocEuro intake | AWE Track & DPs resonated | H&R c/o w/Bilstein B8 rears| 19" VMR 710 & 19" Peelers | 034 trans insert | AK brace | CR15 bar | DEVAL CF Diffuser
    SOLD 2007 S4 DTM, Phantom Black Pearl, manual | JHM | FI | H&R | VMR | 034
    RIP 2001.5 A4 1.8TQMS, Silver/Ebony | APR stage 3 | STaSIS Tracksports | StopTechs
    SOLD 1995 90
    May 11 2004
    2008 M3 6 Speed Cab
    Victoria BC
    Hi Guys,
    Yes you are correct it is that central display. But as also stated above the odometer and clock are also blank. Thank you for everyone's input.
    Cheers,
    Ryan
    Jun 07 2013
    West
    The display has died due to some issues that came up during the battery swap sorry but the only fix is to replace the instrument cluster
    Jul 28 2008
    Everywhere
    Have you tried replacing the ignition switch? Cheaper than a cluster
    Veteran Member Four Rings PetrolDave's Avatar
    Jan 14 2007
    SOLD: 2006 B7 RS4 Avant
    Hampshire, U.K.
    Noticed when starting my B7 that the DIS and the displays in the gauges go blank when cranking, so I was wondering if there is a relay that removes power to them when cranking?
    And if there is that could be the problem???
    Dec 28 2015
    Atlanta GA
    this might be a worthless suggestion but it costs zero - take out the NAV disc and then put it back in. it might reinitialize something or simply knock the system off of top dead center.
    2007 B7 RS4
    prior - 2005 B6 S4
    prior to that - 2004 B6 S4
    Dec 28 2015
    Atlanta GA
    if you have a NAV system that is. if not perhaps there is some other "system reset" for the onboard computer?
    2007 B7 RS4
    prior - 2005 B6 S4
    Established Member Two Rings 2QK4U's Avatar
    Aug 04 2012
    Nevada
    Bumping this old thread. I have this same issue after jumpstarting my 2007 RS4. I have not found a fix yet. Does anyone know if this issue was resolved?
    2007 Audi RS4 - Phantom Black. APR TVS1320 Supercharger. Milltek downpipes & exhaust (100 cell cats, non resonated, valved).
    JHM Stage 3R Series Flywheel, Clutch, Pressure Plate. JHM Short Throw Shifter & linkage. 034 Motor, Torque & Trans Mounts. Apikol Rear Diff Mount.
    Deflapped intake. K&N drop in filter. Decarbed.
