2005.5 S4 With upgrades
Audi technician selling my 2005.5 B7 S4 6MT. The current mileage is 157,5XX and will go up slightly as it is still my daily until my new car gets here. The engine was replaced at 120xxx with a used engine from a 2008. I will have to go pull the info out of my file to verify the exact mileage. I have the VIN number from the donor vehicle and I can verify with ELSA that all of the services were performed during it's previous life. The engine had 61,xxx miles on it when installed. During the swap I replaced the front and rear main seals. I have done everything my self since owning the car. Even did a service when the previous owner had it. Also have all of the service records from the day the PDI was performed.
It has Carbon fiber package, bose, rear sunshade package, heated rear seats, RNS-E with ipod and working satellite radio.
I have gone through and replaced all of the buttons but one that were peeling. The leather has been cleaned and conditioned regularly with the Audi leather care kit. Has Audi sport all weather mats in the car and the trunk.
List of upgrades/maintenance items installed
034 intake bellow/boot
034 Density line motor mounts
034 track density trans mount
034 rear diff mount
B5 spring perches up front
10 mm wheel spacers front and rear with extended wheel bolts
JHM plenum spacers
JHM Light weight fly wheel and stage 3 clutch kit
JHM short shift trio package
Fast Intentions 2.5 Catted down pipes
Magnaflow RS4 Catback
Valve cover gaskets replaced less than 10k ago.
Brake fluid flush a year ago
Euro spec headlamps
Fog lamps replaced 2 months ago
Mirimoto 55K bulbs in the headlamps
Mirimoto 35W 55K HID kit in the fogs with the can bus harness
Ziza LED interior kit and tag lamps
Coded and modified the parking lamps so only the fogs are on with the parking lamps
Headlamp washer delete (New bumper installed)
Euro RS4 Black optic center grill
Body color matched reflectors in the front and rear bumpers
Body color matched rear exhaust valence
New Audi windshield installed less then two months ago with new drip moldings and cowl trim
I have always changed the oil every 5k miles and during so it may use 1/2 quart give or take but nothing even close to excessive.
The tires are Michelin Pilot Super Sports with about 6/32 tread remaining. The spare was also replaced with a matching Super Sport.
I have a set of TT-RS brakes that I never got around to installing. They will be included with the car. I have already mocked everything up and know what is needed to install them and can provide that information if needed.
I have the original engine that came out of the car torn down to the block. It suffered a timing chain guide failure. It has been measured and specs out within Audi standards. It goes with the car if the buyer would like it. I was going to build it but never got to it.
The vehicle was in a front end collision on the right front. I was able to drive the car to the dealership. That is how I was able to delete the headlamp washers with a new bumper. Also how I was able to replace the fog lamps and head lamps, install the RS4 grill and engine covers. I installed the laminix on the headlamps and fog lamps when they came out of the box. I was able to do most of the mechanical repairs and sourced the parts myself. I worked directly with the service manager of our dealerships body shop to overlook the body work. It took forever but the gaps are perfect. The lock carrier was replaced along with the auxiliary radiator. It was not punctured but the fins were folded over and I was able to convince the adjuster to replace it. I have pictures of the damage from the accident.
I have owned the car for over two years and I know I am forgetting some things and will be more than happy to answer any questions. Feel free to call or text - Eight 0 Three - 5 Three 0 - Two 6 Two 3
List Date: 12/22/2015
For more info, click here to view the original listing: 2005.5 S4 With upgrades
This item is no longer available.
