Results 1 to 20 of 20
    Dec 10 2015
    PDX
    Front Plate Mount Project [Pic Heavy}
    Greetings,
    I think a quick intro is in order. I have been in the VW/Audi scene for a long time, but of my life has been spent mostly on Vortex and FourTitude...and it wasn't until I couldn't find what I wanted on FourTitude that I stumbled onto Audizine. This forum is AMAZING and I've been able to find just about every bit of info for my recently acquired 2014 S4 (CPO). To say this is my dream car would be an understatement!
    As most of you guys, my first order of business as soon as I got the car was to make it more "me," and an ECS intake and AWE exhaust (bought used on this forum) were installed this last weekend. I am still waiting for the ECS RS4 grill, but I've been wrestling with a license plate configuration that wouldn't detract from the front end design of the S4...especially its distinctive grill. There are quite a few mount options out there, and the US Mill Work looks like a very nice product...BUT...it wasn't meeting my needs. I don't like that the plate is flat and doesn't curve with the bumper, and the vertical right side of the plate FEELS in conflict with the lines of the grill. Not finding exactly what I wanted, I decided to build my own.
    Before I go into the build, let me just say I live in Oregon and they unfortunately require a front plate. If you are luck enough to live where this is not the case, good for you. Also, to achieve the design I was after, I need to cut my plate. I am sure this is illegal but I tried to keep the trimming to a minimum so not to attract the attention of local law enforcement. Also, I did the project in a single evening, and the total cost was pretty much free since I had all of the materials already laying around.
    To get a sense of the general shape, I made a template...
    This picture will give you general idea of how much I would have to trim...and I wanted to make sure all the characters were still legible...
    Once I was happy with the general shape, I transferred the template to 16 gauge steel. A huge thanks to my buddy Matt at Land Cruiser NW for letting me use the sheer at his shop...it creates much cleaner lines than just a cutoff wheel.
    Once I had the general shape, the obvious challenge was the get a curvature that would match that of the bumper...
    While I originally thought about using rollers to get the right curvature, I decided against it because it takes some practice to get it right...so I used a pipe bender die that seemed to be perfect...
    Now that I had the general shape for what the license plate would attach to, I needed to mount it to the car. So I took my tow hook, cut it in half, and welded a bung to the end. The bung was a strategic way to be able to tighten and loosen the threads that go in the bumper....which I heard can be a challenge to remove after you leave it for some time...
    Next I made an adapter that would bolt to the newly made tow hook piece, and would be welded to the license plate mount...
    Here you see the everything bolted together up to this point...
    Next, I cut a hole in the license plate bracket using a step drill and lined up with the pieces made to bolt to the car. Once you are happy with the alignment, tack weld it for now...
    Take everything apart for finish welding and metal finish...
    This is where you can take a step back with a beer in hand and enjoy the handy work...
    And now with a coat of paint...
    Make minor cuts to the license plate using some tin snips. You can bend the edges around for a cleaner look...
    Use some stainless hardware and you got yourself a new license plate mount...
    The design likely isn't for everyone, but wanted to throw another alternative out there. If you are so inclined, you may be able to make this work by modifying a US Mill Works design...though I didn't want to spend $, since I had all the materials.
    If there is enough interest, I may be able to produce a few of these after the holidays.
    Veteran Member Four Rings schirm's Avatar
    Apr 23 2009
    1999 bmw z3coup M with 5,000 miles Mint
    Forked River nj
    Nice work man!
    2004 A4 1.8t | Avant | 6MT | Stock | Atlas gray |
    2010 S4 | Ice Silver Metallic | Sport Diff | 6 speed | 19 5-Tri-Spoke Wheels | Audi Drive Select | B&O | Silver/Black Nappa Sport Seats | Navigation Pkg | Brushed Aluminum Trim | APR Stage 2+ | Hoen Xenonmatch Fogs | 034 Motor mounts | Roc Euro | black RS4 Grille |
    Past
    2007 A4 | Revo Sg 2+
    2005 Subaru Legacy GT 365WHP
    Senior Member Two Rings AnotherJake's Avatar
    May 08 2014
    Nissan Frontier
    New Mexico
    Looks cool but I wouldn't have cut my plate.
    Ummmm...Do you have to turn that plate back in to the DMV? Oregon.GOV says "License plates may not be altered and must not be covered by any material that alters their appearance." Good luck man.
    2013 S4 | Volcano Red | Black Leather/Alcantara | MMI 3G+NAV | DSG | B&O | Sports Diff | AWE Boost Gauge | Vag-Com | Stasis Full Exhaust | Roc-Euro Intake | Alu Kruez | CR-15 | Eurocode Sways & End Links | APR Stage 2 | AWE Coldfront | RS4 Grille | ECS Front Rotors | SS Front Brake Lines | Hawk HPS Pads | Neuspeed 18" RSe07 | 034 Trans/Diff/Carrier mounts
    Apr 23 2009
    Forked River nj
    Quote Originally Posted by AnotherJake View Post
    If I got pulled by a dickhead cop for that I would laugh and just take my ticket. I have not been running a front plate in NJ for over 10 years. Never once received a ticket.
    But I do believe you have a less chance of getting a ticket for not having it then cutting one in half. What they don't see they wont notice.
    Past
    Dec 10 2015
    PDX
    In Oregon, you don't have to turn your plates into the DMV...they just stay on the rig. If the next owner asks about, all I know is that it "got destroyed." :)
    Dec 10 2015
    PDX
    Quote Originally Posted by schirm View Post
    So I've taken this gamble many times, and I almost always got bit for not running a plate. It isn't the cops who bust you...but...wait for it...the F'ing parking patrol. I have a Land Cruiser where I was building a front bumper and temporarily displayed the front plate in the front window on the passenger side. The parking patrol not only fined me for an expired meter, but also for not having the front plate "Attached" to the front bumper.
    I fully acknowledge that this is a gamble...but from a "preserving the style of the car" perspective, willing to chance it.
    Veteran Member Four Rings MrFunk's Avatar
    Apr 04 2012
    MSP
    Wow - the work is very detailed... but I must be honest - I don't think it looks very good... The plate cut off looks strange because there is a crease on the top and left, but none on the right and bottom... the cut off Y looks strange... just looks "hacked"...
    Maybe it's just off because it's not symmetrical. I'd have maybe followed the line under the headlight instead of the grill line. With these types of plate holders they never look proper though... i gave up on my US Mill plate and just run none now...
    Nice craftsmanship though!
    Veteran Member Three Rings creativecody's Avatar
    Jul 20 2012
    Seems like a lot of work for basically this....
    http://www.usmillworks.com/audi.html
    And I agree with what someone else said.....is it even legal to cut/manipulate the plate?
    2013 S4
    APR Stage 2+ (Dual Pulley & Ultracharger) | APR CPS v2 | Milltek Resonated | Bilstein PSS10 Coilovers | Eurocode Alu Kreuz, Front/Rear Sways, Front/Rear Endlinks | Eurocode Transmission & Differential Mounts | SPC Control Arms | Stoptech BBK 380mm (front), Stoptech Rotors/Pads (rear), SS Lines | HRE FF01 19x9.5 et45 | Michelin PSS 265/35/19 | ECS Carbon Fiber
    Apr 04 2012
    MSP
    Quote Originally Posted by creativecody View Post
    OP is aware of US Mill plate holder and even commented on it in his post.
    Dec 10 2015
    PDX
    Quote Originally Posted by MrFunk View Post
    Fair enough on the styling. I knew that the design wouldn't be for everyone, but it works for me. I played around with the various car lines to follow, including the bumper line below the headlight, but IF I wanted to keep a matching line with the grill (which was my priority), I would need to even have a steeper line on the right...which would require more cutting of the last character on the plate.
    Feb 23 2009
    Vancouver
    I appreciate that everyone has their own taste, but I never understood how someone thinks this looks good??.....sure you get the full grill visual effect but the off center plate (in my opinion) is such an eye sore on any car..... No symmetry with this look, just seems so out of place.....but again, this is my opinion and to each their own! Good on you for what looks like decent workmanship
    Current : B8.5 S4 6MT under the knife,
    Previous : 955 Porsche Cayenne S, 69 Ford Falcon Futura, B7 TI A4 6MT w/lotsomods, MK4 Jetta 1.8T, w/lotsomods, MK3 GTI VR6SC, 84 gti w/ lotsomods
    Senior : 08 ISF
    Bro : 88 Turbo Supra w/134,000 original km (not miles) & 650hp
    Never ending family resto : 66 Mustang Fastback
    WTB : BMW Z3 M Coupe
    Feb 23 2009
    Vancouver
    Quote Originally Posted by Dimka View Post
    Parking patrol??????? What! They don't have that authority here in Canada......police only
    Senior : 08 ISF
    Aug 15 2014
    Nice! looks good!
    For Sale: Mini Part Out
    Veteran Member Three Rings hotleadsingergu's Avatar
    Jun 18 2015
    Cleveland
    But that's the same as what schirm was saying: what they don't see, they won't think about. No plate at all and almost every cop won't notice. A plate that's in a weird place, a weird shape, or not super visible...and it draws attention. Cutting a pretty large portion of the plate off like that is going to net you a lot of attention.
    Why didn't you just make it a bit wider so you didn't have to cut off part of a letter? That seems like semi-poor planning.
    Jan 07 2011
    2013 C300 4Matic
    you could of gorilla glued a shit load of earth magnets behind the bumper and just slapped on the plate whenever you are parked, and remove it when driving
    Present:
    2009 Audi S5 Phantom Black
    IG: bknewtype
    Apr 23 2009
    Forked River nj
    That is a great idea!
    Past
    Dec 10 2015
    PDX
    Quote Originally Posted by hotleadsingergu View Post
    I actually spent a lot of time prototyping the pattern...the version you see in the pictures is V4. It sounds like I might be the only one on this forum who wants the plate to flow with the lines of the grill (and I'll own being the only one), but making it any wider runs it very close to the headlight washer.
    I'll also report back on how much attention I get from the local cops. I agree that if it isn't there, they won't think about it...but the F'n parking patrol nails me on that shit ALL the time.
    Dec 10 2015
    PDX
    That is a fantastic idea...but I would be far too lazy to do that routine day in and day out.
    By the way...I LOVE the stance on your S! If mine wasn't a company car, I would be definitely looking at bags.
    Veteran Member Four Rings pdqgp's Avatar
    Mar 06 2015
    a 12 Second boat, & Wife's Lincoln
    Columbus, Ohio
    I can appreciate the effort but for $30 off amazon a basic tow hook mount works for me. I thought about the magnet idea but I didn't want to chance losing my plate to someone who wanted to just pluck it off. I don't trust anyone. Ohio is also notorious for front plate tickets and I'm not interested in paying $100 tax for it.
    I fastened mine to the bracket via velcro and the clear/tinted cover with a thin strip of packing tape all the way around the edges to seal it against water and dirt. Works great and holds strong as heck. I like velcro as I don't have to look at any screws or run the risk of them hitting my bumper.
    I also have my bent to angle towards the passenger side vs straight to the front. I don't have a good picture to show it but this angle keeps the plate from covering any of the grill or edges of it. Very clean look. It's not even apparent that it's angled either. Clears the headlight washers too.
    Sorry for the crappy pic but it's all I have handy showing the plate mounted..
    2018 Midnight Black Metallic AWD Infiniti Q50S Red Sport | Burger MS JB4 | 395awhp/430awtq
    2018 Ruby Red Metallic Lincoln MK-C Reserve | AWD 2.3l EcoBoost - Wife's
    2014 Brilliant Black S4 | S-Tronic | 187mm APR Stage 2 Dual Pulley & APR TCU Tunes | APR CPS - SOLD
    Jan 07 2011
    2013 C300 4Matic
    Thank u! Its a lowly a though
    I mean u could just leave it on day in and out and just take it off for pics (:
    Sent from my iPhone 6s
    Present:
    IG: bknewtype
